1 Reply Latest reply on Jun 6, 2006 5:33 PM by C. Agruss (Adobe)
    Installation problems (NO REPLY)
    eanticev
      I had problems running the installer. It would show a blank window instead of the installer...
      This is a problem with either your DirectX installation on windows or with the bundled JRE... the solution i used was to unpack the entire installation file (it's an archive and you can extract it's contents), then go into the "windows" folder and add modify the line:
      lax.nl.java.option.additional=
      to
      lax.nl.java.option.additional=-Dsun.java2d.d3d=false -Dsun.java2d.noddraw=true
      in the file: "FlexBuilder2_Installer.lax"
      once i did that the installer rendered fine. I hope no one else has this problem, and if you do that my little fix helps out.
      Happy flexing.
