6 Replies Latest reply on Jun 8, 2016 1:07 AM by Trevorׅ
    Auto-size not refreshing after GREP
    McShaman Level 1
      I have a script where I have text blocks that are populated by data and then those text blocks are distributed vertically. However I have run into an issue where the text blocks are not auto-resizing before the distribution is performed.
      To replicate this issue:
      • Create a new document
      • Draw a text box
      • Enable auto-size on it (height only)
      • Put at least two lines of text in it
      Now run this script:
      var removeBlankParagraphs = function(p_item) {
        app.findGrepPreferences = NothingEnum.nothing;
        app.changeGrepPreferences = NothingEnum.nothing;
        app.findGrepPreferences.findWhat = '(?-m)\\r+$';
        app.changeGrepPreferences.changeTo = '';
        p_item.changeGrep();
      var document = app.activeDocument,
        template = document.pageItems[0],
        pageItem,
        pageItems = [],
        character;
      for (var i = 0; i < 4; i++) {
        pageItem = template.duplicate();
        pageItems.push(pageItem);
        pageItem.lines.lastItem().remove();
        removeBlankParagraphs(pageItem);
      template.remove();
      document.distribute(pageItems, DistributeOptions.VERTICAL_SPACE, undefined, true, 5, pageItems[0]);
      So what is meant to happen here is:
      • The text box is duplicated 4 times
      • The last paragraph is deleted on each duplicate
      • The duplicates are distributed by 5 ruler units
      However if you measure the distance between them they are not 5 ruler units. What seems to be happening here is that the text boxes are not auto-sizing right after the last paragraph is removed... It resizes after the distribute function.
      How do I fix this?
