4 Replies Latest reply on Jun 8, 2016 1:11 AM by Laubender
    Variable Font Properties Inside a Table Cell
    mechaichezilla Level 1
      the following code works fine inside a text area:
      with(textArea.insertionPoints) {
           for ( var iStringSection = 0; iStringSection < stringsAndStyles.length; iStringSection++ ) {
                lastItem().properties = {
                     contents: stringsAndStyles[iStringSection].contents,
                     fontStyle: stringsAndStyles[iStringSection].fontStyle
      The font style changes correctly for every string segment. But if I try the same with a table cell (just replacing textArea with the current cell, the rest stays the same), the fontstyle will not change between the string segments. Is there a different approach to achieve variable font styles inside a table cell? Without using a new paragraph, the font is supposed to change on the same line.
      Thanks a lot!
