1 Reply Latest reply on Jun 8, 2016 12:37 AM by brunoj62734382
    buttons desappear when i set the size of the alert window
    brunoj62734382
      Good morning all,
      My question of the day :
      My project works fine (onclick-button name or ID ), but now i would like to set the height of the alert window containing my set of buttons.
      i set the window location at the top of the screen like this:
      win.frameLocation = [800,0];
      then my buttons are created dynamically (the number of buttons can change)
      i set the size of the window for exemple with:
      win.size = [1024, 50];
      but the buttons desappear ...
      i tried to place the code before or after the button creation , but it doesn't work...
      well.. before i dive in a "no ending" exploration due to my poor knowledge in js , could you give me a track or a direction to explore ...
      Thank you !
      the code:
      var mainFolder = "myBibScript"; // nom du dossier pricipale (root folder of the project)
      var mainPath = "/Volumes/myTools/scripts - macros/jsPalette/myBibScript/" ; // chemin du dossier pricipale (path)
      var scriptFolder= new Folder(mainPath+"scpt/");  // dossier des scripts dans le dossier principale (scripts folder in the root folder)
      var files = scriptFolder.getFiles("*.*");
      var ui = // dialog resource object
          "dialog {\
              gButtons: Group { \
                  orientation: 'row', alignment: 'right'\
      var win = new Window(ui);
      //positionne la fenêtre (window position)
      //color background
      g = win.graphics;
      myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [0.45, 0.75, 0.75, 1]);
      g.backgroundColor = myBrush;
      win.scptFiles = new Array();        //  tableau des fichiers scripts
      myScriptName= new Array();      //  tableau des noms des scripts
      // boucle le dossier des scripts (loop  the scripts folder)
      var counter = 0;
          for (var loop=0; loop < files.length; loop++) {                             // Add items dynamically
              var f = files[loop];
              if (typeof f.open == "undefined")    continue;                           // Skip folder
              if ( -1 != f.fsName.indexOf(".DS_Store"))    continue;              // Skip Mac's hidden file
      var fName=f.fsName.substring(scriptFolder.fsName.length+1);      //extract filename only
      var fNameShort =fName.replace(".jsx", "");                                     // nom sans l'extension (remove extension)
      // creation des icones boutons (create icon buttons)
      var f = File(mainPath+"/img/"+fNameShort+".jpg")
      var myBtn=win.gButtons.add("iconbutton" , undefined , ScriptUI.newImage(f),{style: "toolbutton" , toggle: false});
      //remplissage du tableau de "title" avec l'index (counter) des boutons créés
      // i use numbers for "titles" in place of names to have a short line displayed
      win.scptFiles[counter++] = myBtn
         myScriptName[counter]=fNameShort
         myBtn.title=counter
      myBtn.size = [48, 38];
      win.gButtons.children[counter-1].onClick = gButtonsOnClick
      function gButtonsOnClick() {
      var myScriptTitle=this.title;        // index du bouton cliqué
      myScriptFile=myScriptName[myScriptTitle]          // nom de l'image/script correspondant à l'index
      win.close()
      var idAdobeScriptAutomationScripts = stringIDToTypeID( "AdobeScriptAutomation Scripts" );
          var desc635 = new ActionDescriptor();
          var idjsCt = charIDToTypeID( "jsCt" );
          desc635.putPath( idjsCt, new File( scriptFolder+"/"+myScriptFile+".jsx") );
          var idjsMs = charIDToTypeID( "jsMs" );
          desc635.putString( idjsMs, """[ActionDescriptor]""" );
      executeAction( idAdobeScriptAutomationScripts, desc635, DialogModes.NO);
      win.show();
