Expand my Community achievements bar.
Connection failure while setting up Cold Standby when the primary and the standby instances are in different servers
Avatar
Level 1
I was trying to set up Cold Standby in which primary instance is in one server and standby instance is in another server. After making the configuration changes and starting the servers the cold standby log in primary server is showing: '<Ip_Address_of_Primary_Instance_Server>:<Port_No>' which is not in the allowed IP Ranges! Request will be ignored. And the Cold Standby log in standby instance is showing: org.apache.jackrabbit.oak.plugins.segment.standby.client.StandbyClient Failed synchronizing state. Network Firewall is allowed from any port to any port and in the server side the ports are active as well. Can anyone tell me the reason behind the failure to setup the connection?
