16 Replies Latest reply on Jun 7, 2016 8:00 AM by Abambo
    InDesign TIFF problem
    john_1985
      Hello,
      I am using InDesign (Adobe InDesign CC 2015 11.0.0.72 Build) to create a new document in
      which I want to import a TIFF file with ZIP (deflate) compression (My software created this TIFF file).
      But ID gives me the following error when I try to add the image to the document:
      “Error encountered while reading TIFF image. Image may be damaged or incompatible. Resave the image with different settings and try again.”
      I am developing a Java program that uses the latest version of JAI image io (jai_imageio.jar) and I tried all versions of this jar out there.
      I have written a small test application to verify that TIFF files with ZIP compression (deflate) generated with JAI image io cannot be opened in InDesign.
      If I use other compression schemes it works fine.
      If I resave the generated TIFF file with Photoshop, also using ZIP compression... then it will open correctly in InDesign.
      Looking at the file info -> raw data in Photoshop for both files I see that the resaved file has some settings changed, such as the compression.
      For the original it has this value: <tiff:Compression>32946</tiff:Compression>
      And for the resaved file: <tiff:Compression>8</tiff:Compression>
      But I think these mean the same.
      Clearly I am missing something here.
      So here is my question:
      What can I do to be able to generate TIFF files with ZIP compression that open correctly in Adobe InDesign?
      Regards,
      Jan
