4 Replies Latest reply on Jun 8, 2016 8:37 AM by cbishop01
    Text Variable "Date" question?
    cbishop01 Level 2
      how can i get my output and created date to look like my Modified date? The below is how it looks in the script now.  I just like the look of the Modification date string. If its not possible to make them look that way no big deal I'm just curious.
      Date Modified:    June 7, 2016 3:52 PM
      Date Output:    06/06/16
      Date Created:    06/06/16
        • 1. Re: Text Variable "Date" question?
          cbishop01 Level 2
          This is the code i'm using the R5 and 6 are exactly the same other than the different Cell Numbers.
          var cell3OfColumn2insertionPoint1 = myTable.columns[1].cells[3].insertionPoints[0];
          var R4 = cell3OfColumn2insertionPoint1.textVariableInstances.add(LocationOptions.AFTER, cell3OfColumn2insertionPoint1);
          R4.associatedTextVariable = doc.textVariables.itemByName("Modification Date");
          R5.associatedTextVariable = doc.textVariables.itemByName("Output Date");
          R6.associatedTextVariable = doc.textVariables.itemByName("Creation Date");
          • 2. Re: Text Variable "Date" question?
            vinothr Level 3
            You can use the Date class to get what you want but please note the following:
            var date = new Date();
            date.toDateString:                    Wed Jun 08 2016
            date.toLocaleDateString:         Wednesday, June 08 2016
            date.toLocaleString:                Wednesday, June 08 2016 08:25:58
            date.toGMTString:                   Wednesday, 08 Jun 2016 02:55:58 GMT
            date.toLocaleTimeString:        08:25:58
            date.toTimeString:                    08:25:58 GMT+0530
            date.toUTCString:                    Wednesday, 08 Jun 2016 02:55:58 GMT
            date.toString:                          Wed Jun 08 2016 08:25:58 GMT+0530
            date.getDate():                        8 (1 - 31)
            date.getMonth():                      5 (0-11)
            date.getFullYear():                  2016
            date.getTime():                      1465354558248
            You should choose between whether you want local or UTC/GMT time.
            Your function should look like:
            function getFormattedDateString() {
            var month = ["Jan", "Feb", "Mar", "Apr", "May", "Jun", "July", "Aug", "Sep", "Oct", "Nov", "Dec"];
            // Handle zero prefix
            var formatDate = ("0" + date.getDate()).substr(-2);
            var formatHour = ("0" + date.getHours()).substr(-2);
            var formatMin = ("0" + date.getMinutes()).substr(-2);
            var formatSec = ("0" + date.getSeconds()).substr(-2);
            // Handle AM/PM time period
            var period = (date.getHours() < 12)?"AM":"PM";
            return month[date.getMonth()] +" " + formatDate + ", " + date.getFullYear() + " " + formatHour + ":" + formatMin + " " + period;
            • 3. Re: Text Variable "Date" question?
              vinothr Level 3
              The above script function is to get custom format string from Date object.
              Another easy option is:
              In order to change format of Modification Date variable you can do below:
              Via Script
              var md = doc.textVariables.itemByName("Modification Date");
              md.variableOptions.format = "MMMM dd, yyyy hh:mm a";
              Via UI
              Go to Type->Text Variables -> Define
              Select Modification Date and click Edit button.
              In the Date Format, enter the following:
              Now, all text variable instances of Modification Date will have your desired format.
              • 4. Re: Text Variable "Date" question?
                cbishop01 Level 2
                Both these are correct i wish i could mark correct for both.
