1 Reply Latest reply on May 26, 2006 11:02 AM by Newsgroup_User
    movieclip load order FIFO or FILO
    Level 7
      Hi, I recently purchased Zinc to simply have more control over the window
      (placement, title, icon - that's all I wanted for this project!!) and it is
      causing issues with my program.
      I use the following code to create some movie clips:
      for (var i=0;i<count;i++)
      filePath = pstrFolderPath + swatchNameArray ;
      paLoadedSwatchClips.push(new swatch(this, pobjMainRef, pmcSWFHolder, i,
      filePath, theCounterValues
      The swatch class has the following code that actually creates the clips:
      loadListener.onLoadInit = function(target_mc:MovieClip)
      trace(target_mc + ' is done loading' + ' !! ' + thisRef.pnID);
      var mdm = _global.mdm;
      mdm.Exception.DebugWindow.trace(target_mc + ' is done loading' + ' !! ' +
      thisRef.pnID, mdm.ASYNC)
      thisRef.pmcLoadedClip = target_mc; // Set reference for calling play and
      stop
      thisRef.pobjSetRef.mClipDone();
      // Store height before we put textfield on there
      thisRef.pnMyHeight = target_mc._height;
      thisRef.mCreateCounter(initialCount);
      mcLoader.addListener(loadListener);
      var thePath = _global.mdm.Application.path + swfPath;
      mcLoader.loadClip(swfPath, pmcButton);
      My trace statements in Flash are in order - 0,1,2.....
      I am using Flash MX 2004.
      When I run it through Zinc, and when customer support runs my files, the
      trace statements are reversed - 2,1,0
      I guess I'm wondering if load order has changed since 2004 version... This
      problem is breaking this part of my program when I run it through Zinc, and
      want to know if it is Zinc, or an issue with Flash?
      Any help would be appreciated,
      Jason
        • 1. Re: movieclip load order FIFO or FILO
          Level 7
          Update for anyone who cares...
          It seems flash 7 and 8 are different in how they load movie clips. Using an
          older version of Zinc(which uses player 7) works just fine. Seems to me,
          Flash 8 loads them first in last out, where Flash 7 loads them first in
          first out.
          Good to know for me at least!
          "Jason C Reynolds" <jreynoldsX@Xthewritesource.com> wrote in message
          news:e5753o$lrd$1@forums.macromedia.com...
          > is causing issues with my program.
          > + thisRef.pnID, mdm.ASYNC)
          > stop
          > and want to know if it is Zinc, or an issue with Flash?
          > Jason
