5 Replies Latest reply on Apr 26, 2006 1:25 PM by Will Stumpf
    Email Link
    GHub
      I'm using this code to open email off the button, but nothing is coming up...do I need to put anything in the window & what should my variables be set at? thanks
      on(release) {
      getURL("mailto:test@email.com");
        • 1. Re: Email Link
          Will Stumpf
          Hello GHub, the code you have should work, are you sure you have it on the MC? because that could be your problem.
          You also could try useing single quotes instead of double like so:
          on(release) {
          getURL('mailto:name@website.com');
          hopefully that will work
          Will Stumpf
          www.willstumpf.com
          • 2. Re: Email Link
            GHub Level 1
            thanks for the reply...tried the single quotes, didn't make a difference...not sure what you mean by the "MC"
            Variables: my options are 1 of the following, should I choose one specifically?
            Don't Send
            Send using GET
            Send Using POST
            • 3. Re: Email Link
              Will Stumpf Level 1
              MC = MovieClip.
              Ok thats strange that the single quotes didnt work or the double.
              For the variables i dont think it really matters what you do, so thats up to you.
              if you want to try something else you could try this
              give your the movie clip or button that you are using a instance name of whatever you want i will use "button" for this but you can change it.
              and then on the keyframe not the button put this in the actions panel.
              button.onRelease = function() {
              hope that helps
              Will Stumpf
              www.willstumpf.com
              • 4. Re: Email Link
                GHub Level 1
                Thanks for the responses Will
                The problem seemed to be I had the first letter in the email in caps...don't know why this was a problem but it works now, thanks again
                • 5. Re: Email Link
                  Will Stumpf Level 1
                  sure no problem
