1 Reply Latest reply on May 28, 2006 12:21 AM by running2046
    bug?use Flex Builder 2.0 Plug-in Beta 3 with MyEclipse
    running2046
      Open jsp and mxml at the same time ,the myeclipse closedown itself,and can't open the jsp in myeclipse forever,the errors is the same.
      why?
        • 1. bug?use Flex Builder 2.0 Plug-in Beta 3 with MyEclipse
          running2046 Level 1
          http://www.javaworld.com.tw/jute/user/download/154879/aaaaa.bmp
          this is the cut screen pic and the log
          !ENTRY org.eclipse.osgi 2006-05-28 14:57:47.296
          !MESSAGE While loading class "com.adobe.flexbuilder.util.ResourceLocalizer", thread "Worker-2" timed out waiting (5000ms) for thread "main" to finish starting bundle "com.adobe.flexbuilder.project". To avoid deadlock, thread "Worker-2" is proceeding but "com.adobe.flexbuilder.util.ResourceLocalizer" may not be fully initialized.
          !STACK 0
          java.lang.Exception: Generated exception.
          at org.eclipse.core.runtime.adaptor.EclipseClassLoader.findLocalClass(EclipseClassLoader.jav a:108)
          at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:33 7)
          at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:389)
          at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:350)
          at org.eclipse.osgi.framework.adaptor.core.AbstractClassLoader.loadClass(AbstractClassLoader .java:78)
          at java.lang.ClassLoader.loadClass(ClassLoader.java:251)
          at java.lang.ClassLoader.loadClassInternal(ClassLoader.java:319)
          at com.adobe.flexbuilder.project.internal.FlexProjectCore$1.run(Unknown Source)
          at org.eclipse.core.internal.jobs.Worker.run(Worker.java:76)
          !ENTRY org.eclipse.ui 4 4 2006-05-28 15:15:38.265
          !MESSAGE Unhandled event loop exception
          !ENTRY org.eclipse.ui 4 0 2006-05-28 15:15:38.515
          !MESSAGE Not implemented (java.lang.reflect.InvocationTargetException)
          !STACK 0
          org.eclipse.swt.SWTError: Not implemented (java.lang.reflect.InvocationTargetException)
          at org.eclipse.swt.SWT.error(SWT.java:2968)
          at org.eclipse.swt.SWT.error(SWT.java:2865)
          at org.eclipse.swt.awt.SWT_AWT.new_Frame(SWT_AWT.java:141)
          at com.genuitec.eclipse.webdesigner2.designeditor.MSHTMLViewer.createControl(MSHTMLViewer.ja va:300)
          at com.genuitec.eclipse.webdesigner2.designeditor.MSHTMLViewer.<init>(MSHTMLViewer.java:257)
          at com.genuitec.eclipse.webdesigner2.designeditor.MSHTMLViewer.<init>(MSHTMLViewer.java:229)
          at com.genuitec.eclipse.webdesigner2.designeditor.DesignEditSubsystem.createDesignViewer(Des ignEditSubsystem.java:183)
          at com.genuitec.eclipse.webdesigner2.WebDesigner2.createDesignViewer(WebDesigner2.java:135)
          at com.genuitec.eclipse.webdesigner2.HTMLMultiPageEditorPart.createDesignerControls(HTMLMult iPageEditorPart.java:504)
          at com.genuitec.eclipse.webdesigner2.HTMLMultiPageEditorPart.createDesignPage(HTMLMultiPageE ditorPart.java:480)
          at com.genuitec.eclipse.webdesigner2.HTMLMultiPageEditorPart.createPages(HTMLMultiPageEditor Part.java:260)
          at org.eclipse.ui.part.MultiPageEditorPart.createPartControl(MultiPageEditorPart.java:241)
          at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:609)
          at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:384)
          at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:552)
          at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:283)
          at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:126 )
          at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFo lder.java:269)
          at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder .java:65)
          at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStack Presentation.java:391)
          at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1102)
          at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1051)
          at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1256)
          at org.eclipse.ui.internal.PartStack.add(PartStack.java:442)
          at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:109)
          at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:60)
          at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:212)
          at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:202)
          at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:758)
          at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:665)
          at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:628)
          at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2360)
          at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2295)
          at org.eclipse.ui.internal.WorkbenchPage.access$9(WorkbenchPage.java:2287)
          at org.eclipse.ui.internal.WorkbenchPage$9.run(WorkbenchPage.java:2273)
          at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:69)
          at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2268)
          at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2249)
          at org.eclipse.ui.ide.IDE.openEditor(IDE.java:371)
          at org.eclipse.ui.ide.IDE.openEditor(IDE.java:334)
          at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:251)
          at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:131)
          at org.eclipse.jdt.internal.ui.actions.OpenActionUtil.open(OpenActionUtil.java:49)
          at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:169)
          at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:153)
          at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.ja va:222)
          at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:198)
          at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExpl orerActionGroup.java:296)
          at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.ja va:869)
          at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:741)
          at org.eclipse.core.internal.runtime.InternalPlatform.run(InternalPlatform.java:1044)
          at org.eclipse.core.runtime.Platform.run(Platform.java:783)
          at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:44)
          at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:148)
          at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:739)
          at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:968)
          at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1067)
          at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:243)
          at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:238)
          at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:277)
          at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
          at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:843)
          at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:3125)
          at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:2758)
          at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1699)
          at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1663)
          at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:367)
          at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:143)
          at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:103)
          at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:226)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:376)
          at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:163)
          at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
          at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
          at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
          at java.lang.reflect.Method.invoke(Method.java:585)
          at org.eclipse.core.launcher.Main.invokeFramework(Main.java:334)
          at org.eclipse.core.launcher.Main.basicRun(Main.java:278)
          at org.eclipse.core.launcher.Main.run(Main.java:973)
          at org.eclipse.core.launcher.Main.main(Main.java:948)
          Caused by: java.lang.reflect.InvocationTargetException
          at sun.reflect.NativeConstructorAccessorImpl.newInstance0(Native Method)
          at sun.reflect.NativeConstructorAccessorImpl.newInstance(NativeConstructorAccessorImpl.java: 39)
          at sun.reflect.DelegatingConstructorAccessorImpl.newInstance(DelegatingConstructorAccessorIm pl.java:27)
          at java.lang.reflect.Constructor.newInstance(Constructor.java:494)
          at org.eclipse.swt.awt.SWT_AWT.new_Frame(SWT_AWT.java:139)
          ... 77 more
          Caused by: java.awt.HeadlessException
          at java.awt.GraphicsEnvironment.checkHeadless(GraphicsEnvironment.java:159)
          at java.awt.Window.<init>(Window.java:317)
          at java.awt.Frame.<init>(Frame.java:419)
          at java.awt.Frame.<init>(Frame.java:384)
          at sun.awt.EmbeddedFrame.<init>(EmbeddedFrame.java:82)
          at sun.awt.EmbeddedFrame.<init>(EmbeddedFrame.java:79)
          at sun.awt.EmbeddedFrame.<init>(EmbeddedFrame.java:67)
          at sun.awt.windows.WEmbeddedFrame.<init>(WEmbeddedFrame.java:47)
          at sun.awt.windows.WEmbeddedFrame.<init>(WEmbeddedFrame.java:44)
          ... 82 more
