14 Replies Latest reply on Dec 21, 2017 6:50 AM by Eric Lipton Ice
    BOOK PDF spreads_almost works
    Fran7201
      I am using the BOOK function for the first time, though I am a veteran (15+ years) user of InDesign. I have successfully set up the sections, each as a separate, multi-page document. Everything is working beautifully, except when I go to create a PDF intended to allow the user to print in spreads. (The SPREADs box is checked.) And while the inner pages of each document export as spreads, a section that ends with an even page number (left-hand page) does not combine as a spread with the first page of the next section (right-hand page). The result is lots of successful spreads, but with several single pages in between some sections—but only where sections end on an even-numbered page and another begins with an odd-numbered page. Is it possible to get these two pages from the different sections to connect as one spread so that the final document is one continuous book of spreads throughout?
      Here are the specs I set up for each document/section:
      1. Page numbering is set for each document to begin where the previous section left off.
      2. No chapter numbering on any document.
      3. No variable text in any document.
      4. 500 pages total.
      5. I am using the PDF from BOOK function in the BOOK flyout menu.
      6. Again, SPREADS is checked and am exporting for a PRINT PDF.
      I thought that this problem would be a common user error, but cannot find any thread that covers the problem. Seems like a simple problem with an equally simple answer. I hope that is the case. Thank you.
        • 1. Re: BOOK PDF spreads_almost works
          BarbBinder Adobe Community Professional
          That's because the first page of a chapter is a one-page spread, and is the last page, if it ends on a left page—so it's doing what you asked.
          If you uncheck print spreads when you make the pdf the thumbnails will show up correctly based on how you set it up. Then the user can decide which page(s) to print. If they want the spread that contains 4–5, then they can pick that page range in the print dialog box.
          • 2. Re: BOOK PDF spreads_almost works
            Salah Fadlabi Level 5
            My suggestion is to export all pages of the book as pdf pages and not spreads, then after that create a new indesign documnet with facing pages and with numbers pages of the book then run MultiPageImorter script.
            Zanelli Releases MultiPageImporter for Importing both PDF and INDD Files
            • 3. Re: BOOK PDF spreads_almost works
              Fran7201 Level 1
              Thank you for such quick responses. Both suggestions seem like good solutions. I will try both, but it makes sense just to leave the document as single pages and let the user decide which portions to print rather than force the user to print spreads they do not need. Good, logical suggestion. I suspected that what I was asking the book to do was not possible without a work-around or a special script. Thanks again. Both are great answers!
              • 4. Re: BOOK PDF spreads_almost works
                mikebikel
                I'm having the same issue. I'm afraid neither 'solution' being proposed addresses the fundamental issue with the -export book as PDF- function. If the export worked properly, 'doing what I asked' exporting spreads, the verso ending a chapter would be properly mated with the recto opening the next chapter.
                Like a book.
                Because that's what's being exported.
                A book. In spreads.
                Further, the 'solution' suggests a 'user' in the equation 'printing'.
                There is no "user" choosing which page(s) to print.
                The export is a book in spreads. No user. No printing. Just a book, paginated entirely in spreads.
                Basic stuff.
                This question has not yet been answered.
                • 5. Re: BOOK PDF spreads_almost works
                  Basic stuff.
                  For print work you would never export as spreads because it would make the printer's page imposition job overly difficult if not impossible—no printer would want reader spreads. In AcobatPro you can setup the document's initial view as facing pages—Two-up Continuous (Cover Page), which will display single pages as spreads:
                  • 6. Re: BOOK PDF spreads_almost works
                    The answer to the question, Mike, is to forgo exporting as spreads and instead export as pages. Acrobat can handle the spread view as per Rob's post directly above. This will give you "just a book, paginated entirely in spreads." I recognize the temptation to use the spread option, but that is not the solution for your scenario.
                    • 7. Re: BOOK PDF spreads_almost works
                      Also, Acrobat's initial view setting works for AcrobatPro and Reader, but most browser PDF plugins don't honor the 2-up view, so for web display you're out-of-luck.
                      PDF is still primarily a print format. This is a common 8-up, 16 page press signature. You can see why the printer needs pages, except for the center spread none of the pages match up as spreads in the imposition:
                      • 8. Re: BOOK PDF spreads_almost works
                        mikebikel Level 1
                        Rob's post is more on-point, if a bodged solution, though I'm not suggesting that this PDF ever go to a printer for imposition. As a book designer, I understand imposition. My need is for client review, and possibly posting to the web.
                        Having never explored any Initial View properties beyond Magnification, I admit to having missed the Page Layout option for Two-Up Continuous (Cover Page). Works nicely, particularly for the 1pt rule that runs the gutter and delineates pages for a more clear sense of inner margins.
                        That written, as Rob's follow-up suggests, the method isn't robust, rather, it's breakable. That makes it less useful, and reliable since there's no way to control a user's software install.
                        It would be useful if Adobe built the solution into the Export Book as PDF function in a way that worked as expected, and wasn't breakable.
                        • 9. Re: BOOK PDF spreads_almost works
                          If your client is using Acrobat Reader the initial view setting would always work because it is set in the PDF and Reader will honor it—I've never seen 2-up work in a browser.
                          PDF has never been reliable for screen display because as you noted there's no way to control the end reader software. It's more than just spread vs. page, there's also color management, zoom magnification, ability to handle transparency correctly, line anti-aliasing, etc. Reader, OSX Preview, other 3rd party readers, and a browser could all handle the display differently.
                          • 10. Re: BOOK PDF spreads_almost works
                            If you really needed to export Books as spreads you could setup the chapters to break on right pages. Something like this—16 pages split into two with the chapter 1 break at page 7 and the chapter 2 starting as a spread with page 8 on the left:
                            The book exported as spreads:
                            • 11. Re: BOOK PDF spreads_almost works
                              mikebikel Level 1
                              Thanks for apply some thought to this.
                              Yes, you could force it. However, for instance, the folios in my prelim section are numbered in lowercase roman numerals, and have a given running head, whereas the folios and running heads in my chapters differ, using Arabic figures and chapter titles on recto. This solution will require less-than-neat section management, creating place-holder recto master pages based on next chapter styles. This runs counter to the internal logic of book set-up, auto- page numbering, etc. etc.
                              Again, Adobe fixing the Export Book as PDF -in spreads- to work properly is one for the suggestion box, if anyone is listening.
                              • 12. Re: BOOK PDF spreads_almost works
                                InDesign Feature Requests
                                • 13. Re: BOOK PDF spreads_almost works
                                  gabrielbajada
                                  This is an issue for me as well. I've been working with InDesign since it was launched and was using Pagemaker and Quark XPress before that.
                                  The reason I'd like to export as spreads is that when viewing the PDF in a browser, the single page two-up cover page option won't work.
                                  Basic stuff.
                                  • 14. Re: BOOK PDF spreads_almost works
                                    Eric Lipton Ice Level 1
                                    this is a script i made a few months ago. Works with CS6.
                                    Try it, think its what you're looking for...
                                    kind regards, Eric
                                    Copy and paste in applesript:
                                    -- pdf plaatsen op enkele pag incl. afloop
                                    set thePDF to (choose file)
                                    tell application "Adobe Acrobat Pro"
                                        open thePDF with invisible
                                        set pageCount to number of pages of document 1
                                        set {x1, y1, x2, y2} to bleed box of page 1 of document 1 -- pag met afloop en zndr snij
                                        set {bbBreedte, bbHoogte} to {(x2 - x1), (y1 - y2)}
                                        set {x5, y5, x6, y6} to trim box of page 1 of document 1 -- pag zndr afloop en zndr snij
                                        set {tbBreedte, tbHoogte} to {(x6 - x5), (y5 - y6)}
                                        close document 1
                                    end tell
                                    tell application "Adobe InDesign CS6"
                                        activate
                                        set newDoc to make document
                                        set horizontal measurement units of view preferences of newDoc to millimeters
                                        set vertical measurement units of view preferences of newDoc to millimeters
                                        set page width of document preferences of newDoc to (bbBreedte / 72) * 25.4
                                        set page height of document preferences of newDoc to (bbHoogte / 72) * 25.4
                                        zoom window 1 of newDoc given fit spread
                                        set pages per document of document preferences of newDoc to (pageCount as number)
                                        repeat with i from 1 to pageCount
                                            set active spread of window 1 to parent of page i of newDoc
                                            set page number of PDF place preferences to i
                                            set PDF crop of PDF place preferences to crop bleed
                                            -- PDF crop (crop art/crop PDF/crop trim/crop bleed/crop media/crop content visible layers/crop content all layers) : The type of cropping to apply.
                                            set transparent background of PDF place preferences to false
                                            place thePDF on page i of newDoc
                                        end repeat
                                        set page width of document preferences of newDoc to (tbBreedte / 72) * 25.4
                                        set page height of document preferences of newDoc to (tbHoogte / 72) * 25.4
                                        set pageWidth to page width of document preferences of document 1
                                        set pageHeight to page height of document preferences of document 1
                                        set mgDialog to make dialog with properties {name:"Wilt u het document als spreads?"}
                                        tell mgDialog
                                            tell (make dialog column)
                                                tell (make border panel)
                                                        make static text with properties {static label:"Pagina's als spread  ", min width:140}
                                                    end tell
                                                        set mgKeuze to make radiobutton group
                                                        tell mgKeuze
                                                            set a to make radiobutton control with properties {static label:" Op volgorde   ", min width:110}
                                                            set b to make radiobutton control with properties {static label:" Op inslag   ", min width:110}
                                                            set checked state of a to true
                                                        end tell
                                                    end tell
                                                end tell
                                                set mgResult to show mgDialog
                                                if mgResult is true then
                                                    set mgRadioButton to selected button of mgKeuze
                                                    destroy mgDialog
                                                else
                                                    error number -128
                                                end if
                                                if mgRadioButton is 0 then
                                                    tell newDoc
                                                        set i to 1 -- start oneven pagina's
                                                        repeat until i > (count pages)
                                                            tell page i to tell page item 1 to set geometric bounds to {-3, 0, (pageHeight + 3), (pageWidth + 3)}
                                                            set i to i + 2
                                                        end repeat
                                                        set i to 2 -- start even pagina's
                                                            tell page i to tell page item 1 to set geometric bounds to {-3, -3, (pageHeight + 3), pageWidth}
                                                            set i to i + 2
                                                        end repeat
                                                        set properties of document preferences to {facing pages:true}
                                                        set properties of view preferences to {ruler origin:page origin}
                                                    end tell
                                                else if mgRadioButton is 1 then
                                                    tell newDoc
                                                        set nmbPages to count pages
                                                        set x to 1
                                                        repeat nmbPages times
                                                            set layout window 1's active page to page x
                                                            do script "app.menuActions.itemByID(6160).invoke();" language javascript
                                                            set x to (x + 1)
                                                        end repeat
                                                            set i to i + 2
                                                        end repeat
                                                            set i to i + 2
                                                        end repeat
                                                        set y to 1
                                                        repeat (nmbPages / 2) / 2 times
                                                            move last page to before page y -- binding left align
                                                            move last page to after page (y + 2) -- binding left align
                                                            set y to (y + 4)
                                                        end repeat
                                                    end tell
                                                end if
                                            end tell
                                        end tell
                                    end tell
