5 Replies Latest reply on Jun 10, 2016 8:57 AM by BradSmithSC
    Show/hide multiple fields on drop-down choice using if else
    BradSmithSC
      Goal is to show or hide three fields depending on a drop-down choice. Show if X, hide if Y.
      Getting a syntax error on line 6 when adding to the mouse-up trigger of the dropdown field.
      Are multiple actions allowed for each if condition?
      if(event.target.value = "Yes")
        getField("Top_inches").display = display.visible;
        getField("Top_numerator").display = display.visible;
        getField("Top_denominator").display = display.visible;
      else
        getField("Top_inches").display = display.hidden;
        getField("Top_numerator").display = display.hidden;
        getField("Top_denominator").display = display.hidden;
        • 1. Re: Show/hide multiple fields on drop-down choice using if else
          You have at least two syntax errors. The first is that you used the wrong operator for the comparison. It's "==", not "=" (that is the value assignment operator).
          The second is that you didn't put the code blocks inside curly brackets.
          So your code should be:
          if (event.target.value == "Yes") {
              this.getField("Top_inches").display = display.visible;
              this.getField("Top_numerator").display = display.visible;
              this.getField("Top_denominator").display = display.visible;
          } else {
              this.getField("Top_inches").display = display.hidden;
              this.getField("Top_numerator").display = display.hidden;
              this.getField("Top_denominator").display = display.hidden;
          • 2. Re: Show/hide multiple fields on drop-down choice using if else
            PS. If you're getting an error message please post it in full. It is very helpful in finding and fixing problems with the code.
            • 3. Re: Show/hide multiple fields on drop-down choice using if else
              BradSmithSC Level 1
              Thanks for the quick response Try67.
              Got this script on the mouse-up trigger. However, the fields do not immediately show/hide when a choice is selected in the drop-down field. Instead, the user selects the drop-down choice, clicks off the drop-down field, only when re-selecting the drop-down field do the other fields show/hide. The animation below illustrates this behavior.
              Since this drop-down is just a yes/no choice, it seems using a single checkbox may return better user experience as shown in this animation. However, if more than a yes/no choice was needed what would be a best practice for a drop-down field?
              The three fields are collecting a measurement. A hyphen and slash help clarify the desired data. Can text & image visibility be modified with JavaScript?
              The error msg was just 'syntax error' in the JavaScript Editor window footer with a line reference. Appreciate you mentioning full error details should be posted whenever available.
              • 4. Re: Show/hide multiple fields on drop-down choice using if else
                If you want the code to run as soon as a selection is made I recommend moving it to the field's custom validation script.
                You will need to adjust the first line to:
                if (event.value == "Yes") {
                Also, you should make sure that the "Commit selected value immediately" option is ticked, under the field's Properties - Options tab.
                Why not simply include the hyphen and the slash, and the rest of the text, into a single field? Seems to me it will make your code much more simple.
                • 5. Re: Show/hide multiple fields on drop-down choice using if else
                  BradSmithSC Level 1
                  We're trying to get our field reps to populate forms electronically. One reason focusing so intently on creating a smooth user experience. Partially explains my irreverently high nit-pick level
                  Noticing odd form behavior. The drop-down must first get the focus then the choices are available. Seems like user must select the field twice. Feels a tad clumsy.
                  Yeah, a single field would sure be simpler. In this case, these three fields are converted into a decimal. The calculated size ensures the correct PartID is entered which corresponds to material quantity needs.
                  In this animation, at the bottom is a description builder which stitches together certain fields. This gets copied into a work order notes field.
