5 Replies Latest reply on Jun 11, 2016 4:43 PM by cbishop01
    Adding CHeck box beside another one?
    cbishop01 Level 2
      Hello again.  How can i go about placing a check box beside another one that will do the changes for all documents open?  I'll Paste a pic below to show what i mean.
       w.tabs[1]= w.tabGroup.add ('group');
                  w.tabs[1].add('statictext {text: "Select a change to make"}');
                  w.tabs[1].add ('panel');
              var RunCH1= w.tabs[1].add ('checkbox {text: "Find and Replace"}');
              var RunCH2= w.tabs[1].add ('checkbox {text: "???"}');
              var RunCH3= w.tabs[1].add ('checkbox {text: "???"}');
      The above activates this.  After the ok button is checked.
      myResult = w.show();
             if(myResult == 1 && (RunCH1.value==true)){
                Replace_TXT(" <CR> ", "^p");
                Replace_TXT(" <CR>", "^p");
      I would like the a check box to be added where the Cyan box is at or directly beside the Find and Replace text.  Either or.  I want it to be another check box so that way when it is clicked and the FInd and replace is clicked it will run the command for all documents.
