1 Reply Latest reply on May 27, 2006 1:05 PM by Juankpro
    Links between swfs
      HI ALL,
      I am writing a script to communicate between flash and Visual Basic.
      My main problem is that my swf is composed of two swf : Clip1 which contains clip 2.
      and when I want to get a variable of clip 2 (getVariable function) : i get a communication error
      Code in clip 1 to load clip2 : loadMovieNum ("/clip2.swf", 1);
      Inside clip 2 I define a variable abc that I want to access. Abc is declared in clip 2 at _level0
      Does any one have an idea on how to access level from the first swf clip 1 ?
      Thank you .
        • 1. Re: Links between swfs
          Juankpro Level 2
          If you where to run clip2.swf alone, any variable declared in clip2.swf can be referenced as varName or _level0.varName. But if the clip is been loaded from another clip like clip1.swf. Then the variable is not declared on _level0 but on the level specified as the second parameter of the loadMovie method. That is. if you loaded the movie like this: loadMovieNum ("/clip2.swf", 1); then clip2.swf becomes _level1 and not _level0. So if you want to access this variables you need to write _level1.varName
