1 Reply Latest reply on May 26, 2006 7:29 AM by Scottie_Too_Hottie7
    Scroll Pane Scrollbar Not Working!
      I have a completely empty movie clip in the libary called "chess_ppllist".
      I use the following actionscript to dynamically place the chess_ppllist in a ScrollPane which is on the stage (named sp1), and then to update the content inside when two buttons on the side are pressed.
      NOTE : You will see that the button event handelers are called for button._onPress instead of onPress - this is because i am using a custom button class
      For some reason, the scrollbar on the scrollpane, does not kick in.
      Can someone tell me why how to get the scrollbar to work? As you can see, i have tried the redraw method, but that hasn't worked either.
