7 Replies Latest reply on Dec 6, 2016 12:44 PM by christiang7637298
    Can't stop sound using javascript.
    carsonandrew2
      Hello I'm trying to use javascript to start a sound and then stop it when a button is pressed.
      I've tried everything and still can't get it to work.
      using html5 canvas
        • 1. Re: Can't stop sound using javascript.
          Colin Holgate MVP & Adobe Community Professional
          createjs.Sound.stop() should stop all sounds. It should be able to take the id of the sound too, if you want to stop a particular sound:
          createjs.Sound.stop(soundID)
          • 2. Re: Can't stop sound using javascript.
            christiang7637298
            Thanks Colin,
            For some reason the stop always stops all the audio and not just the one I have the ID listed for.
            Is anyone else having an issue with this?
            I can start the sounds individually and stop ALL the sounds but what I really need is to stop just one sound.
            I have two buttons (4 if you count the start and stop buttons).
            var jsObject = this;
            jsObject.audioBtnPlay.addEventListener("click", audioCtrlPlay.bind(jsObject));
            jsObject.audioBtnPause.addEventListener("click", audioCtrlPause.bind(jsObject));
            jsObject.audioBtnPlay2.addEventListener("click", audioCtrlPlay2.bind(jsObject));
            jsObject.audioBtnPause2.addEventListener("click", audioCtrlPause2.bind(jsObject));
            jsObject.audioBtnPlay.visible = true;
            jsObject.audioBtnPause.visible = false;
            createjs.Sound.registerSound("sounds/musicfile.mp3", "sound_id");
            createjs.Sound.registerSound("sounds/audioTwo.mp3", "sound_id2");
            function audioCtrlPlay() {
              createjs.Sound.play("sound_id");
              jsObject.audioBtnPlay.visible = false;
              jsObject.audioBtnPause.visible = true;
            function audioCtrlPause() {
              createjs.Sound.stop("sound_id");
            function audioCtrlPlay2() {
              createjs.Sound.play("sound_id2");//
              jsObject.audioBtnPlay2.visible = false;
              jsObject.audioBtnPause2.visible = true;
            function audioCtrlPause2() {
              createjs.Sound.stop("sound_id2");
              jsObject.audioBtnPlay2.visible = true;
              jsObject.audioBtnPause2.visible = false;
            Please don't tell me it's just be who has this issue.
            Cheers,
            Christian
            • 3. Re: Can't stop sound using javascript.
              ClayUUID Adobe Community Professional
              Incorrect. Sound.stop() performs a global stop only. To "stop" a specific sound, you have to set the paused property on it.
              Is there a pause() method? · Issue #200 · CreateJS/SoundJS · GitHub
              • 4. Re: Can't stop sound using javascript.
                Would you use setPaused(boolean)? Actually, reading about it, it seems there's a neat way to do getters and setters, if I read this right:
                  Object.defineProperty(this, "paused", {
                  get: this.getPaused,
                  set: this.setPaused
                That way you can read or set the paused state just by talking to 'paused' instead of using setPaused(boolean) and getPaused().
                • 5. Re: Can't stop sound using javascript.
                  No, you wouldn't use setPaused(boolean). You'd do what I just said-- set the value of the .paused property directly to true or false.
                  In fact, in the linked discussion gskinner explicitly says "we deprecated setPaused/getPaused". So nobody even think about using those.
                  • 6. Re: Can't stop sound using javascript.
                    I was saying that you don't need to do setPaused(boolean) because the internal SoundJS code I showed takes care of that for you.
                    • 7. Re: Can't stop sound using javascript.
                      christiang7637298 Level 1
                      Thanks very much. This is great.
