19 Replies Latest reply on Jun 15, 2016 6:53 AM by trshaner
    Fantastic performance increase
    SteenHK63 Level 1
      On my ThinkPad P70 with Quadro  M300M graphics card I just discovered a huge performance gain by turning off "use graphics processor" under preferences - performance. Just thought I'd let you know. It seems everything is affected by this.
        • 1. Re: Fantastic performance increase
          Akash Sharma Adobe Employee
          Hi SteenHK ,
          This means your Graphics card is not compatible with Photoshop because it is either not supported or is outdated.
          Please refer Troubleshoot Photoshop graphics hardware (GPU) and video card issues
          Regards,
          Akash
          • 2. Re: Fantastic performance increase
            SteenHK63 Level 1
            Hi Akash
            The Quadro M300M is the newest of all the Quadro laptop cards, that might
            be why it's not supported. Hope it will be soon.
            Best regards
            Steen
            • 3. Re: Fantastic performance increase
              Rikk Flohr - CM Adobe Employee
              It may be that your Quadro simply has an outdated driver. Go to the video card manufacturer's website and download the latest driver and install it. Turn on your GPU and see if your performance improves.  Your card's manufacturer may still have updates to do if this doesn't fix it.
              • 4. Re: Fantastic performance increase
                SteenHK63 Level 1
                Hi Rikk
                I am checking for new drivers every 2 weeks, because the graphics card is
                bran new. But still this has not helped. But turning it of in Lightroom,
                helps definitely.
                Br, Steen
                • 5. Re: Fantastic performance increase
                  trshaner Adobe Community Professional & MVP
                  Are you using LR 6.6 or CC 2015.6 and the below graphics driver?
                  Quadro Desktop/Quadro Notebook Driver Release 367 WHQL368.39June 7, 2016
                  • 6. Re: Fantastic performance increase
                    SteenHK63 Level 1
                    I am using latest Lightroom version 2015.6 Release, just checked.
                    Ther driver you send URL for, is not a partner (Lenovo) certified driver
                    and therfore it cannot be installed with my Thinkpad P70. But there was
                    a new driver in the Lenovo updates for the P70.
                    This driver seems to work better than the previous in general. But with
                    the adjustment brush tool it definitely seems slower with the graphics
                    driver enabled in LR.
                    De bedste hilsener / Best regards
                    Steen Knarberg
                    STEEN KNARBERG PHOTOGRAPHY
                    Dybsøvej 72, DK-4700 Næstved
                    Produktfoto | Packshots | Reportage | Panorama |
                    Portrætter | Profil | Luftfoto | Videoproduktion |
                    Se mere på www.steenknarberg.com
                    Edited by moderator Geoff Walker to remove contact details.....
                    Please do not post phone and email as that can lead to spam, etc.
                    • 7. Re: Fantastic performance increase
                      SteenHK63 Level 1
                      After a reboot and some aditional work I can say that the latest
                      certified Lenovo driver 10.18.13.5474, dated 07/02/2016 works very good
                      and fluently, also with the Adjustment brush...
                      Steen Knarberg
                      • 8. Re: Fantastic performance increase
                        SteenHK63 Level 1
                        After working some time in LR things start to slow down again, also
                        using the adjustment brush, which does not update the strokes in real
                        time. However a restart of LR solves this for some time, approx editing
                        of 2 to 3 images.
                        Disabling "Use graphics processor" solves this, even though there seems
                        to be a small decrease in overall performance.
                        If this behavior is due to the Quadro M3000M driver or LR I don't know.
                        Steen Knarberg
                        • 9. Re: Fantastic performance increase
                          Are you using an external monitor or the laptops LCD display only?
                          Your P70 laptop has two graphics adapters: Intel Intergrated Graphics and Discrete Nvidia Graphics adapter. Scroll down to section titled 'NVIDIA Optimus Technology' here: https://download.lenovo.com/pccbbs/mobiles/n1cdh07w.txt
                          You may need to change the BIOS setting as outlined here to use the Nvidia Discrete Graphics adapter: Using nvidia display adapter sted integrated graphics with onlocation
                          • 10. Re: Fantastic performance increase
                            SteenHK63 Level 1
                            While doing the tests today I have only used the internal LCD.
                            As I wrote the decrease in performance is gradual in the way that if LR is
                            restarted performance is fine and then after some editing fex using the
                            brush for 3-4 images in large areas, then the brush starts to lag
                            considerably. If I then restart LR everything is fine again.
                            To me it seems as if something in Lightroom is causing this, some kind of
                            bottleneck issue..
                            Best regards
                            Steen
                            • 11. Re: Fantastic performance increase
                              It sounds like the GPU or CPU may be over-heating from intensive usage during LR editing. You can download the free CPU HardwareMonitor and check  the CPU and GPU temperature while working in LR.
                              DOWNLOADING HWMONITOR_1.29.EXE | CPUID
                              • 12. Re: Fantastic performance increase
                                SteenHK63 Level 1
                                No, I'm sure that's not the case, it would be very obvious from the sound
                                of the fan, which really talks when rendering 4k video fex. Using LR
                                doesn't raise fan noise at all..
                                If it was overheating, taking a pause would help out, but it doesn't. Only
                                remedy is to restart LR.
                                The M3000M card is one of the high end cards and should easily cope with LR
                                editing.
                                I think it's a LR compatability issue of some kind with this new card that
                                Adobe should look into with Nvidia. Not be negative, but we've seen issues
                                before.
                                Thanks, Steen
                                • 13. Re: Fantastic performance increase
                                  Do me a favor. Enable GPU inside LR Preferences, go to Help> System Info and paste the below info into a reply:
                                  Lightroom version: CC 2015.6 [ 1078672 ]
                                  License: Creative Cloud
                                  Operating system: Windows 7
                                  Version: 6.1
                                  Application architecture: x64
                                  System architecture: x64
                                  Logical processor count: 8
                                  Processor speed: 2.7 GHz
                                  Built-in memory: 12247.1 MB
                                  Real memory available to Lightroom: 12247.1 MB
                                  Real memory used by Lightroom: 1087.4 MB (8.8%)
                                  Virtual memory used by Lightroom: 1123.7 MB
                                  Memory cache size: 168.0 MB
                                  Maximum thread count used by Camera Raw: 8
                                  Camera Raw SIMD optimization: SSE2
                                  System DPI setting: 120 DPI
                                  Desktop composition enabled: Yes
                                  Displays: 1) 2560x1440
                                  Input types: Multitouch: No, Integrated touch: No, Integrated pen: Yes, External touch: No, External pen: Yes, Keyboard: No
                                  Graphics Processor Info:
                                  Quadro 600/PCIe/SSE2
                                  Check OpenGL support: Passed
                                  Vendor: NVIDIA Corporation
                                  Version: 3.3.0 NVIDIA 354.56
                                  Renderer: Quadro 600/PCIe/SSE2
                                  LanguageVersion: 3.30 NVIDIA via Cg compiler
                                  • 14. Re: Fantastic performance increase
                                    SteenHK63 Level 1
                                    Comming here:
                                    Operating system: Windows 10
                                    Version: 10.0
                                    Built-in memory: 16250.0 MB
                                    Real memory available to Lightroom: 16250.0 MB
                                    Real memory used by Lightroom: 4083.4 MB (25.1%)
                                    Virtual memory used by Lightroom: 4188.4 MB
                                    Memory cache size: 3886.2 MB
                                    Camera Raw SIMD optimization: SSE2,AVX,AVX2
                                    System DPI setting: 168 DPI (high DPI mode)
                                    Displays: 1) 3840x2160
                                    Quadro M3000M/PCIe/SSE2
                                    Version: 3.3.0 NVIDIA 354.74
                                    Renderer: Quadro M3000M/PCIe/SSE2
                                    Application folder: C:\Program Files\Adobe\Adobe Lightroom
                                    Library Path: F:\Lightroom DB P70\Lightroom 2 Catalog-2-2-2-2.lrcat
                                    Settings Folder: C:\Users\info\AppData\Roaming\Adobe\Lightroom
                                    Installed Plugins:
                                    1) ColorChecker Passport
                                    2) Export to Autopano Giga 3
                                    3) Export To Helicon Focus
                                    4) Facebook
                                    5) PhotoFrame
                                    6) Piwigo
                                    7) ProShow
                                    8) ProShow Web
                                    Config.lua flags: None
                                    Adapter #1: Vendor : 10de
                                        Device : 13fa
                                        Subsystem : 222d17aa
                                        Revision : a1
                                        Video Memory : 4011
                                    Adapter #2: Vendor : 8086
                                        Device : 191b
                                        Revision : 6
                                        Video Memory : 80
                                    Adapter #3: Vendor : 1414
                                        Device : 8c
                                        Subsystem : 0
                                        Revision : 0
                                        Video Memory : 0
                                    AudioDeviceIOBlockSize: 1024
                                    AudioDeviceName: Speaker/HP (Realtek High Definition Audio)
                                    AudioDeviceNumberOfChannels: 2
                                    AudioDeviceSampleRate: 44100
                                    Build: LR5x102
                                    Direct2DEnabled: false
                                    GL_ACCUM_ALPHA_BITS: 16
                                    GL_ACCUM_BLUE_BITS: 16
                                    GL_ACCUM_GREEN_BITS: 16
                                    GL_ACCUM_RED_BITS: 16
                                    GL_ALPHA_BITS: 0
                                    GL_BLUE_BITS: 8
                                    GL_DEPTH_BITS: 24
                                    GL_GREEN_BITS: 8
                                    GL_MAX_3D_TEXTURE_SIZE: 4096
                                    GL_MAX_TEXTURE_SIZE: 16384
                                    GL_MAX_TEXTURE_UNITS: 4
                                    GL_MAX_VIEWPORT_DIMS: 16384,16384
                                    GL_RED_BITS: 8
                                    GL_RENDERER: Quadro M3000M/PCIe/SSE2
                                    GL_SHADING_LANGUAGE_VERSION: 4.50 NVIDIA
                                    GL_STENCIL_BITS: 8
                                    GL_VENDOR: NVIDIA Corporation
                                    GL_VERSION: 4.5.0 NVIDIA 354.74
                                    GPUDeviceEnabled: false
                                    OGLEnabled: true
                                    GL_EXTENSIONS: GL_AMD_multi_draw_indirect
                                    GL_AMD_seamless_cubemap_per_texture GL_AMD_vertex_shader_viewport_index
                                    GL_AMD_vertex_shader_layer GL_ARB_arrays_of_arrays GL_ARB_base_instance
                                    GL_ARB_bindless_texture GL_ARB_blend_func_extended GL_ARB_buffer_storage
                                    GL_ARB_clear_buffer_object GL_ARB_clear_texture GL_ARB_clip_control
                                    GL_ARB_color_buffer_float GL_ARB_compatibility
                                    GL_ARB_compressed_texture_pixel_storage GL_ARB_conservative_depth
                                    GL_ARB_compute_shader GL_ARB_compute_variable_group_size
                                    GL_ARB_conditional_render_inverted GL_ARB_copy_buffer GL_ARB_copy_image
                                    GL_ARB_cull_distance GL_ARB_debug_output GL_ARB_depth_buffer_float
                                    GL_ARB_depth_clamp GL_ARB_depth_texture GL_ARB_derivative_control
                                    GL_ARB_direct_state_access GL_ARB_draw_buffers GL_ARB_draw_buffers_blend
                                    GL_ARB_draw_indirect GL_ARB_draw_elements_base_vertex
                                    GL_ARB_draw_instanced GL_ARB_enhanced_layouts GL_ARB_ES2_compatibility
                                    GL_ARB_ES3_compatibility GL_ARB_ES3_1_compatibility
                                    GL_ARB_explicit_attrib_location GL_ARB_explicit_uniform_location
                                    GL_ARB_fragment_coord_conventions GL_ARB_fragment_layer_viewport
                                    GL_ARB_fragment_program GL_ARB_fragment_program_shadow
                                    GL_ARB_fragment_shader GL_ARB_framebuffer_no_attachments
                                    GL_ARB_framebuffer_object GL_ARB_framebuffer_sRGB
                                    GL_ARB_geometry_shader4 GL_ARB_get_program_binary
                                    GL_ARB_get_texture_sub_image GL_ARB_gpu_shader5 GL_ARB_gpu_shader_fp64
                                    GL_ARB_half_float_pixel GL_ARB_half_float_vertex GL_ARB_imaging
                                    GL_ARB_indirect_parameters GL_ARB_instanced_arrays
                                    GL_ARB_internalformat_query GL_ARB_internalformat_query2
                                    GL_NV_internalformat_sample_query GL_ARB_invalidate_subdata
                                    GL_ARB_map_buffer_alignment GL_ARB_map_buffer_range GL_ARB_multi_bind
                                    GL_ARB_multi_draw_indirect GL_ARB_multisample GL_ARB_multitexture
                                    GL_ARB_occlusion_query GL_ARB_occlusion_query2
                                    GL_ARB_pipeline_statistics_query GL_ARB_pixel_buffer_object
                                    GL_ARB_point_parameters GL_ARB_point_sprite
                                    GL_ARB_program_interface_query GL_ARB_provoking_vertex
                                    GL_ARB_robust_buffer_access_behavior GL_ARB_robustness
                                    GL_ARB_sample_shading GL_ARB_sampler_objects GL_ARB_seamless_cube_map
                                    GL_ARB_seamless_cubemap_per_texture GL_ARB_separate_shader_objects
                                    GL_ARB_shader_atomic_counters GL_ARB_shader_bit_encoding
                                    GL_ARB_shader_draw_parameters GL_ARB_shader_group_vote
                                    GL_ARB_shader_image_load_store GL_ARB_shader_image_size
                                    GL_ARB_shader_objects GL_ARB_shader_precision GL_ARB_query_buffer_object
                                    GL_ARB_shader_storage_buffer_object GL_ARB_shader_subroutine
                                    GL_ARB_shader_texture_image_samples GL_ARB_shader_texture_lod
                                    GL_ARB_shading_language_100 GL_ARB_shading_language_420pack
                                    GL_ARB_shading_language_include GL_ARB_shading_language_packing
                                    GL_ARB_shadow GL_ARB_sparse_buffer GL_ARB_sparse_texture
                                    GL_ARB_stencil_texturing GL_ARB_sync GL_ARB_tessellation_shader
                                    GL_ARB_texture_barrier GL_ARB_texture_border_clamp
                                    GL_ARB_texture_buffer_object GL_ARB_texture_buffer_object_rgb32
                                    GL_ARB_texture_buffer_range GL_ARB_texture_compression
                                    GL_ARB_texture_compression_bptc GL_ARB_texture_compression_rgtc
                                    GL_ARB_texture_cube_map GL_ARB_texture_cube_map_array
                                    GL_ARB_texture_env_add GL_ARB_texture_env_combine
                                    GL_ARB_texture_env_crossbar GL_ARB_texture_env_dot3 GL_ARB_texture_float
                                    GL_ARB_texture_gather GL_ARB_texture_mirror_clamp_to_edge
                                    GL_ARB_texture_mirrored_repeat GL_ARB_texture_multisample
                                    GL_ARB_texture_non_power_of_two GL_ARB_texture_query_levels
                                    GL_ARB_texture_query_lod GL_ARB_texture_rectangle GL_ARB_texture_rg
                                    GL_ARB_texture_rgb10_a2ui GL_ARB_texture_stencil8 GL_ARB_texture_storage
                                    GL_ARB_texture_storage_multisample GL_ARB_texture_swizzle
                                    GL_ARB_texture_view GL_ARB_timer_query GL_ARB_transform_feedback2
                                    GL_ARB_transform_feedback3 GL_ARB_transform_feedback_instanced
                                    GL_ARB_transform_feedback_overflow_query GL_ARB_transpose_matrix
                                    GL_ARB_uniform_buffer_object GL_ARB_vertex_array_bgra
                                    GL_ARB_vertex_array_object GL_ARB_vertex_attrib_64bit
                                    GL_ARB_vertex_attrib_binding GL_ARB_vertex_buffer_object
                                    GL_ARB_vertex_program GL_ARB_vertex_shader
                                    GL_ARB_vertex_type_10f_11f_11f_rev GL_ARB_vertex_type_2_10_10_10_rev
                                    GL_ARB_viewport_array GL_ARB_window_pos GL_ATI_draw_buffers
                                    GL_ATI_texture_float GL_ATI_texture_mirror_once GL_S3_s3tc
                                    GL_EXT_texture_env_add GL_EXT_abgr GL_EXT_bgra GL_EXT_bindable_uniform
                                    GL_EXT_blend_color GL_EXT_blend_equation_separate
                                    GL_EXT_blend_func_separate GL_EXT_blend_minmax GL_EXT_blend_subtract
                                    GL_EXT_compiled_vertex_array GL_EXT_Cg_shader GL_EXT_depth_bounds_test
                                    GL_EXT_direct_state_access GL_EXT_draw_buffers2 GL_EXT_draw_instanced
                                    GL_EXT_draw_range_elements GL_EXT_fog_coord GL_EXT_framebuffer_blit
                                    GL_EXT_framebuffer_multisample GL_EXTX_framebuffer_mixed_formats
                                    GL_EXT_framebuffer_multisample_blit_scaled GL_EXT_framebuffer_object
                                    GL_EXT_framebuffer_sRGB GL_EXT_geometry_shader4
                                    GL_EXT_gpu_program_parameters GL_EXT_gpu_shader4
                                    GL_EXT_multi_draw_arrays GL_EXT_packed_depth_stencil GL_EXT_packed_float
                                    GL_EXT_packed_pixels GL_EXT_pixel_buffer_object GL_EXT_point_parameters
                                    GL_EXT_polygon_offset_clamp GL_EXT_post_depth_coverage
                                    GL_EXT_provoking_vertex GL_EXT_raster_multisample GL_EXT_rescale_normal
                                    GL_EXT_secondary_color GL_EXT_separate_shader_objects
                                    GL_EXT_separate_specular_color GL_EXT_shader_image_load_formatted
                                    GL_EXT_shader_image_load_store GL_EXT_shader_integer_mix
                                    GL_EXT_shadow_funcs GL_EXT_sparse_texture2 GL_EXT_stencil_two_side
                                    GL_EXT_stencil_wrap GL_EXT_texture3D GL_EXT_texture_array
                                    GL_EXT_texture_buffer_object GL_EXT_texture_compression_dxt1
                                    GL_EXT_texture_compression_latc GL_EXT_texture_compression_rgtc
                                    GL_EXT_texture_compression_s3tc GL_EXT_texture_cube_map
                                    GL_EXT_texture_edge_clamp GL_EXT_texture_env_combine
                                    GL_EXT_texture_env_dot3 GL_EXT_texture_filter_anisotropic
                                    GL_EXT_texture_filter_minmax GL_EXT_texture_integer GL_EXT_texture_lod
                                    GL_EXT_texture_lod_bias GL_EXT_texture_mirror_clamp
                                    GL_EXT_texture_object GL_EXT_texture_shared_exponent GL_EXT_texture_sRGB
                                    GL_EXT_texture_sRGB_decode GL_EXT_texture_storage GL_EXT_texture_swizzle
                                    GL_EXT_timer_query GL_EXT_transform_feedback2 GL_EXT_vertex_array
                                    GL_EXT_vertex_array_bgra GL_EXT_vertex_attrib_64bit
                                    GL_EXT_import_sync_object GL_IBM_rasterpos_clip
                                    GL_IBM_texture_mirrored_repeat GL_KHR_context_flush_control GL_KHR_debug
                                    GL_KHR_robust_buffer_access_behavior GL_KHR_robustness
                                    GL_KTX_buffer_region GL_NV_bindless_multi_draw_indirect
                                    GL_NV_bindless_multi_draw_indirect_count GL_NV_bindless_texture
                                    GL_NV_blend_equation_advanced GL_NV_blend_equation_advanced_coherent
                                    GL_NV_blend_square GL_NV_command_list GL_NV_compute_program5
                                    GL_NV_conditional_render GL_NV_conservative_raster
                                    GL_NV_conservative_raster_dilate GL_NV_copy_depth_to_color
                                    GL_NV_copy_image GL_NV_deep_texture3D GL_NV_depth_buffer_float
                                    GL_NV_depth_clamp GL_NV_draw_texture GL_NV_ES1_1_compatibility
                                    GL_NV_ES3_1_compatibility GL_NV_explicit_multisample GL_NV_fence
                                    GL_NV_fill_rectangle GL_NV_float_buffer GL_NV_fog_distance
                                    GL_NV_fragment_coverage_to_color GL_NV_fragment_program
                                    GL_NV_fragment_program_option GL_NV_fragment_program2
                                    GL_NV_fragment_shader_interlock GL_NV_framebuffer_mixed_samples
                                    GL_NV_framebuffer_multisample_coverage GL_NV_geometry_shader4
                                    GL_NV_geometry_shader_passthrough GL_NV_gpu_program4
                                    GL_NV_gpu_program4_1 GL_NV_gpu_program5 GL_NV_gpu_program5_mem_extended
                                    GL_NV_gpu_program_fp64 GL_NV_gpu_shader5 GL_NV_half_float
                                    GL_NV_light_max_exponent GL_NV_multisample_coverage
                                    GL_NV_multisample_filter_hint GL_NV_occlusion_query
                                    GL_NV_packed_depth_stencil GL_NV_parameter_buffer_object
                                    GL_NV_parameter_buffer_object2 GL_NV_path_rendering
                                    GL_NV_path_rendering_shared_edge GL_NV_pixel_data_range
                                    GL_NV_point_sprite GL_NV_primitive_restart GL_NV_register_combiners
                                    GL_NV_register_combiners2 GL_NV_sample_locations
                                    GL_NV_sample_mask_override_coverage GL_NV_shader_atomic_counters
                                    GL_NV_shader_atomic_float GL_NV_shader_atomic_fp16_vector
                                    GL_NV_shader_atomic_int64 GL_NV_shader_buffer_load
                                    GL_NV_shader_storage_buffer_object GL_NV_texgen_reflection
                                    GL_NV_texture_barrier GL_NV_texture_compression_vtc
                                    GL_NV_texture_env_combine4 GL_NV_texture_multisample
                                    GL_NV_texture_rectangle GL_NV_texture_shader GL_NV_texture_shader2
                                    GL_NV_texture_shader3 GL_NV_transform_feedback GL_NV_transform_feedback2
                                    GL_NV_uniform_buffer_unified_memory GL_NV_vertex_array_range
                                    GL_NV_vertex_array_range2 GL_NV_vertex_attrib_integer_64bit
                                    GL_NV_vertex_buffer_unified_memory GL_NV_vertex_program
                                    GL_NV_vertex_program1_1 GL_NV_vertex_program2
                                    GL_NV_vertex_program2_option GL_NV_vertex_program3 GL_NV_viewport_array2
                                    GL_NVX_conditional_render GL_NVX_gpu_memory_info GL_NVX_nvenc_interop
                                    GL_NV_shader_thread_group GL_NV_shader_thread_shuffle
                                    GL_KHR_blend_equation_advanced GL_KHR_blend_equation_advanced_coherent
                                    GL_SGIS_generate_mipmap GL_SGIS_texture_lod GL_SGIX_depth_texture
                                    GL_SGIX_shadow GL_SUN_slice_accum GL_WIN_swap_hint WGL_EXT_swap_control
                                    Steen Knarberg
                                    [personal information deleted by host]
                                    • 15. Re: Fantastic performance increase
                                      SteenHK63 Level 1
                                      Hi!
                                      I have attached the HW monitor data for editing of 5 images with the
                                      adjustment brush in auto mask mode. It does not look like any
                                      overheating or other stressed hardware issues. In the last 2-3 images
                                      the brush started to lag considerably..
                                      Steen Knarberg
                                      {Personal information removed by Moderator}
                                      • 16. Re: Fantastic performance increase
                                        The Nvidia M3000M GPU is being used and NOT the Intel Integrated GPU, so that's good!.
                                        I tested this using an Adjustment Brush with +1.0 Exposure on a set of 10 images that were already edited. After I applied the Adjustment Brush to about 5 image files it started to lag badly, so I can duplicate what you are seeing. On my system it happens with GPU enabled or disabled and appears to be a memory leak.I have 12GB of memory and as you can see below the Adjustment Brush edits left 2,208 MB Available. Simply "browsing" image files in the Develop module will cause the memory leak. Open Task Manager as below and set to 'Always On Top' and watch the 'Available' number as you use the Adjustment Brush or browse images in the Develop module. The only way to recover the used memory is to close and relaunch LR. This is probably due to changes added in LR 6.6 and CC 2015.6 for faster Develop module browsing. It now caches the preview for the image file on either side of the currently viewed file.
                                        It has already been reported here so hopefully a 6.6.1 fix in in the works:
                                        Lightroom 2015.6 Extremely Slow | Photoshop Family Customer Community
                                        • 17. Re: Fantastic performance increase
                                          I forgot to add that at the Photoshop Family forum it was discovered you can recover memory without restarting LR. Simply "minimize LR, wait 2-3 seconds, and then "maximize" LR. It's a little quicker than closing and restarting LR.......at least until a fix is available.
                                          • 18. Re: Fantastic performance increase
                                            SteenHK63 Level 1
                                            Again not to sound negative, but when do Lightroom users get a version
                                            without bugs of some kind? I can't remember when that last happened.
                                            I pay my monthly creative suite fee and I would expect that what I get for
                                            that is tested and working fully in a production environment, if not 100%
                                            then just 99 or maybe 98. But a memory leak causing serious lag and slow
                                            downs , thats not ok. Adobe user's are not test labs.
                                            Can't forget last time we had the trouble with the preview in develop
                                            module. It took more than 3 months to solve. And when I first wrote about
                                            it, nobody at adobe had noticed it.
                                            So get on that horse and fix the bugs please.
                                            Thanks, Steen.
                                            • 19. Re: Fantastic performance increase
                                              My sentiments as well! BTW I am not an Adobe employee. The ACP title just means Adobe has recognized my user-to-user contributions. All I can do is make suggestions and the place to do it is on the Photoshop Family feedback forum. I suggest adding your 'Me To' vote below so it gets more attention. At this moment there are only 5 people claiming they have this "issue" and 18 simply 'Following' the post. I just added my vote so now it's 6........
