6 Replies Latest reply on Jun 24, 2016 11:02 AM by cbishop01
    Help with Progress Bar.
    cbishop01 Level 2
      Hi I've tried to add a few different progress bars to this script and i keep getting errors.  Can someone help please?   I have it right now placed at the beginning of the Script but i've had it at the end as well with no luck.  Below is the Code.
         #targetengine "AutoStartScript"
      // Save and open information
          app.addEventListener( "beforeSave" , doTextFrameOnPageOne );
          app.addEventListener( "beforeSave" , doZeroPoint );
          app.addEventListener( "afterOpen" , doZeroPoint );
      // -----------------> Progress Bar<-------------------
          app.scriptPreferences.enableRedraw = true
          var found = Array(50);
          var w = new Window('palette');
              w.add ("progressbar", undefined, start, stop);
              w.pbar = w.add('progressbar', undefined, 0, found.length);
              w.pbar.preferredSize.width = 300;
              w.show();
          for(var i = found.length-1;i>-1;i--){
              w.pbar.value = found.length-i;
              $.sleep(20);
       // Reset the Zero Point on documents.
          function doZeroPoint()
                 app.documents[0].zeroPoint = [0,0];
      // Create New Layer
          function addLayer(doc, name) {
          try{
                  var layer = doc.layers.itemByName(name);
                  if(layer && layer.isValid) {
                           return layer;
                      } else {
                  var myLayer = doc.layers.add();
                  myLayer.name = name;
                      return myLayer;
            } catch(e) {
      // Create Text Frame
          function addTextFrame(doc, layer, name) {
              var myBlendingSettings = { blendMode : BlendMode.OVERLAY };
              var myTransparencySettings = { blendingSettings : myBlendingSettings };
              var tf = doc.textFrames.itemByName(name);
              if(tf && tf.isValid) {
                  tf.remove();
              tf = doc.textFrames.add(layer, LocationOptions.UNKNOWN, {name: name, fillColor :"Yellow", fillTint: 20, transparencySettings : myTransparencySettings, geometricBounds: ['0in','-5.45in','1.45in','-.75in'] });
                    return tf;
      // Create Table
          function addTable(tf) {
              var myTable = tf.texts[0].tables.add
                       // Number of Rows and Columns.
                        bodyRowCount : 6 ,
                        columnCount : 2
          return myTable;
          function addVariable(doc, name, value) {
              var v = doc.textVariables.itemByName(name);
              if(v && v.isValid)
                  return;
              v = doc.textVariables.add({name:name, variableType:VariableTypes.CUSTOM_TEXT_TYPE});
              v.variableOptions.contents =  value;
          function doTextFrameOnPageOne(event)
              var doc = event.target;
              if(!(doc && doc.constructor.name == "Document")) {
                  return;
      // Create New Layer
              var myLayer = addLayer(doc, "SaveInfo");
              var columnOneContentsArray = [
                   "Document:" ,
                   "User Name:",
                   "Computer Name:",
                   "Date Modified:",
                   "Date Output:",
                   "Date Created:",
                   "Output Date:"
              var columnTwoContentsArray = [
              var tf = addTextFrame(doc, myLayer, "SaveInfo");
      // Table Properties
              var myTable = addTable(tf);
                  setColumnWidthsAndAlignments(myTable)
          function setColumnWidthsAndAlignments(tableObj)
              var myWidths=[1.35, 3.32];
              var myAlignments=[Justification.LEFT_ALIGN,Justification.LEFT_ALIGN];
              var numberOfColumns=tableObj.columns.count();
              for (c=0;c<numberOfColumns;c++)
                  myTable.columns[c].width=myWidths[c];
                  myTable.columns[c].cells.everyItem().texts.everyItem().justification=myAlignments[c];
      // Create New Text Variables and Variable Options.
              var md = doc.textVariables.itemByName("Output Date");
                  md.variableOptions.format = "MMMM dd, yyyy hh:mm a";
              var md = doc.textVariables.itemByName("Creation Date");
                  tv = doc.textVariables.item("Users Name");
                  !tv.isValid && tv = doc.textVariables.add({name:"Users Name", variableType:VariableTypes.CUSTOM_TEXT_TYPE});
                  tv.variableOptions.contents =  String( getAppUserName() );
                  tvL = doc.textVariables.item("CLN");
                  !tvL.isValid && tvL = doc.textVariables.add({name:"CLN", variableType:VariableTypes.CUSTOM_TEXT_TYPE});
                  tvL.variableOptions.contents =  String( getLogInUserName() );
      // Placing Text variable information in tables
              var R1, R2, R3, R4, R5, R6;
                  myTable.columns[0].contents = columnOneContentsArray;
                  myTable.columns[1].contents = columnTwoContentsArray;
              var cell0OfColumn2insertionPoint1 = myTable.columns[1].cells[0].insertionPoints[0];
              var R1 = cell0OfColumn2insertionPoint1.textVariableInstances.add(LocationOptions.AFTER, cell0OfColumn2insertionPoint1);
                  R1.associatedTextVariable = doc.textVariables.itemByName("File Name");
              var cell1OfColumn2insertionPoint1 = myTable.columns[1].cells[1].insertionPoints[0];
              var R2 = cell1OfColumn2insertionPoint1.textVariableInstances.add(LocationOptions.AFTER, cell1OfColumn2insertionPoint1);
                  R2.associatedTextVariable = doc.textVariables.itemByName("Users Name")
              var cell2OfColumn2insertionPoint1 = myTable.columns[1].cells[2].insertionPoints[0];
              var R3 = cell2OfColumn2insertionPoint1.textVariableInstances.add(LocationOptions.AFTER, cell2OfColumn2insertionPoint1);
                  R3.associatedTextVariable = doc.textVariables.itemByName("CLN");
              var cell3OfColumn2insertionPoint1 = myTable.columns[1].cells[3].insertionPoints[0];
              var R4 = cell3OfColumn2insertionPoint1.textVariableInstances.add(LocationOptions.AFTER, cell3OfColumn2insertionPoint1);
                  R4.associatedTextVariable = doc.textVariables.itemByName("Modification Date");
              var cell4OfColumn2insertionPoint1 = myTable.columns[1].cells[4].insertionPoints[0];
              var R5 = cell4OfColumn2insertionPoint1.textVariableInstances.add(LocationOptions.AFTER, cell4OfColumn2insertionPoint1);
                  R5.associatedTextVariable = doc.textVariables.itemByName("Output Date");
              var cell5OfColumn2insertionPoint1 = myTable.columns[1].cells[5].insertionPoints[0];
              var R6 = cell5OfColumn2insertionPoint1.textVariableInstances.add(LocationOptions.AFTER, cell5OfColumn2insertionPoint1);
                  R6.associatedTextVariable = doc.textVariables.itemByName("Creation Date");
      //  Computer User Name
              function getLogInUserName()
               var userNameOSX = $.getenv("USER");
               var userNameWindows = $.getenv("USERNAME");
                  if(userNameWindows == null){return userNameOSX}
                  else{return userNameWindows};
      // Application Name
              function getAppUserName()
                  return app.userName;
      Thank you for any help you can give.  I got the above "Progress Bar" from ScriptUI for dummies I believe its from Peter.
