3 Replies Latest reply on Jun 16, 2016 8:37 AM by Szalam
    rendering interlaced footage, to output in 1080/50i: adjusment layer flicker on fields
    Miron Auslander
      original footage is 25 fps 1080i
      working with adjustment layer and basic coloring effects
      the final output render results in adj layer flicker "on/off" on each field
      the problem was tested on 2 different HP workstations and problem persist.
      working on PCs windows 7.
      i had the exact same problem while using the rotobrush tool.
      i solved the render flickering issue, by pre-composing the designated layer to be roto and changing the comp setting to 50FPS
      rotobrushing in the 50fps comp but rendering the working comp of 25fps.
      problem solved.
      but working with adjustment layers on this project remain an issue.
