5 Replies Latest reply on Nov 22, 2016 10:46 AM by kerrishotts
    Phonegap Cloud build uses old IOS binary.
    topitsky
      When I try to connect it to iTunes it just says that the binary is invalid. Anyway to fix this?
        • 1. Re: Phonegap Cloud build uses old IOS binary.
          kerrishotts Adobe Employee
          Can you post the exact error message? What steps are you following when submitting to Apple?
          • 2. Re: Phonegap Cloud build uses old IOS binary.
            JuanCAlpizar
            I'm having the same issue and so far I'm clueless about what's wrong about it. The first time I uploaded the binary through the app loader you can download from the iTunes connect website, on the "build" section. That one uploaded correctly, but then when I needed to make a modification and upload it, it rejected it with the "The Binary is invalid" message.
            Here's the complete log the app loader is generating:
            [2016-11-21 15:56:15 CST] <main>  INFO: Transporter is searching for updated software components.
            [2016-11-21 15:56:17 CST] <main>  INFO: Transporter is up-to-date.
            [2016-11-21 15:56:17 CST] <main>  INFO: MD5 checksum calculation in the transporter will be skipped.
            [2016-11-21 15:56:17 CST] <main>  INFO: Logging level set to eXtreme
            [2016-11-21 15:56:17 CST] <main>  INFO: Logging configured successfully.
            [2016-11-21 15:56:17 CST] <main> DEBUG: Attempting refresh of configuration data from https://contentdelivery.itunes.apple.com/transporter/Defaults.properties
            [2016-11-21 15:56:17 CST] <main> DEBUG: Configuration refresh successful.
            [2016-11-21 15:56:17 CST] <main> DEBUG: Saving configuration to local path: /Users/andressalas/.itmstransporter/Defaults.properties
            [2016-11-21 15:56:17 CST] <main>  INFO: iTMSTransporter : iTunes Store Transporter [1.9.1]
            [2016-11-21 15:56:17 CST] <main>  INFO: OS identifier: Mac OS X 10.10.5 (x86_64); jvm=24.80-b07; jre=1.7.0-internal-root_2015_01_13_21_57-b00
            [2016-11-21 15:56:17 CST] <main>  INFO: Memory: [JVM] 36M free, 60M total, 910M max [System] (Physical) 76M free, 8192M total (Swap) 788M free, 6144M total
            [2016-11-21 15:56:17 CST] <main>  INFO: Client: Application Loader 3.1 (670)
            [2016-11-21 15:56:17 CST] <main>  INFO: Upload mode selected.
            [2016-11-21 15:56:17 CST] <main> DBG-X: Memory: [JVM] 36M free, 60M total, 910M max [System] (Physical) 76M free, 8192M total (Swap) 788M free, 6144M total
            [2016-11-21 15:56:17 CST] <main> DBG-X: Memory: [JVM] 26M free, 60M total, 910M max [System] (Physical) 73M free, 8192M total (Swap) 788M free, 6144M total
            [2016-11-21 15:56:17 CST] <main> DBG-X: Using operation named: authenticateForSession
            [2016-11-21 15:56:17 CST] <main> DBG-X: Apple's web service operation input parameters:
            [2016-11-21 15:56:17 CST] <main> DBG-X:   parameter Application = iTMSTransporter
            [2016-11-21 15:56:17 CST] <main> DBG-X:   parameter BaseVersion = 1.8.3
            [2016-11-21 15:56:17 CST] <main> DBG-X:   parameter Client = Application Loader
            [2016-11-21 15:56:17 CST] <main> DBG-X:   parameter ClientVersion = 3.1 (670)
            [2016-11-21 15:56:17 CST] <main> DBG-X:   parameter OSIdentifier = Mac OS X 10.10.5 (x86_64); jvm=24.80-b07; jre=1.7.0-internal-root_2015_01_13_21_57-b00
            [2016-11-21 15:56:17 CST] <main> DBG-X:   parameter Password = **hidden value**
            [2016-11-21 15:56:17 CST] <main> DBG-X:   parameter TransporterArguments = -m upload -u info@intouchdev.com -p **hidden value** -f /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/31E564B5-1597-4FC7-AEA7-9805E849CA34/117 2555383.itmsp -checksumValidation false -indicator true -v eXtreme -Dtransporter.client=Application Loader -Dtransporter.client.version=3.1 (670)
            [2016-11-21 15:56:17 CST] <main> DBG-X:   parameter Username = info@intouchdev.com
            [2016-11-21 15:56:17 CST] <main> DBG-X:   parameter Version = 1.9.1
            [2016-11-21 15:56:17 CST] <main> DBG-X:   parameter iTMSTransporterMode = upload
            [2016-11-21 15:56:17 CST] <main>  INFO: id = 20161121155617-090
            [2016-11-21 15:56:18 CST] <main> DBG-X: Apple's web service operation return value:
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter SessionId = **hidden value**
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter SharedSecret = **hidden value**
            [2016-11-21 15:56:18 CST] <main> DBG-X: Using operation named: authenticateForTransportDiscovery
            [2016-11-21 15:56:18 CST] <main> DBG-X: Apple's web service operation input parameters:
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter Application = iTMSTransporter
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter BaseVersion = 1.8.3
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter Client = Application Loader
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter ClientVersion = 3.1 (670)
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter OSIdentifier = Mac OS X 10.10.5 (x86_64); jvm=24.80-b07; jre=1.7.0-internal-root_2015_01_13_21_57-b00
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter TransporterArguments = -m upload -u info@intouchdev.com -p **hidden value** -f /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/31E564B5-1597-4FC7-AEA7-9805E849CA34/117 2555383.itmsp -checksumValidation false -indicator true -v eXtreme -Dtransporter.client=Application Loader -Dtransporter.client.version=3.1 (670)
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter Username = info@intouchdev.com
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter Version = 1.9.1
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter iTMSTransporterMode = upload
            [2016-11-21 15:56:18 CST] <main>  INFO: id = 20161121155618-420
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter PreferredTransports = [Aspera, Signiant, DAV]
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter TransportHosts.Aspera = [vgr104.apple.com:33001, vgr106.apple.com:33001, vgr103.apple.com:33001, vgr105.apple.com:33001]
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter ApplicationSettings = {ShouldPricingTabBeDisplayed=true, IsVendorIDEditablePreferenceEnabled=true, SkipValidateProductErrors=true, SkipValidateFirenzeSPIUsage=false, MZWebServiceTimeOut=900, SkipValidatePurpleSPIUsage=false, IsDisplayArtistVisible=false, ITunesCrashLogServiceAddress=https://contentdelivery.itunes.apple.com/WebObjects/MZLabelService.woa/json/MZITunesProduc erService, IsEnabledForMasteredForItunes=false, MZWebServiceValidateSoftwareSPIUsageMaximumSize=1048576, IsISBNOptional=true, PerformServerVerification=true, VerifyZipIntegrity=true, BookSeriesSequenceNumberFormatter=#.#;0;#0.#, IsPublicationDateOptional=false, softwareUserGuideFilePath=https://help.apple.com/itc/apploader/, AllowPublicationPreorderWithoutAssets=false, ITunesSoftwareServiceAllowedPlatforms=[{sdkID=com.apple.platform.iphoneos, validationMethod=ios, xmlID=ios, platformDirectory=iPhoneOS.platform, serverID=Purple, type=1, displayName=iOS App, platformCriteria={plistEntries={LSRequiresIPhoneOS=, MinimumOSVersion=}}}, {sdkID=com.apple.platform.macosx, validationMethod=osx, xmlID=osx, platformDirectory=MacOSX.platform, serverID=Firenze, type=2, displayName=macOS App, platformCriteria={plistEntries={LSMinimumSystemVersion=}}}, {validationMethod=iap, serverID=InAppPurchase, type=3, displayName=In-App Purchase}, {sdkID=com.apple.platform.appletvos, validationMethod=ios, xmlID=appletvos, platformDirectory=AppleTVOS.platform, serverID=AppleTVOS, type=4, displayName=Apple TV OS, platformCriteria={plistEntries={UIDeviceFamily=3}}}, {sdkID=com.apple.platform.watchos, validationMethod=ios, platformDirectory=WatchOS.platform, type=6, displayName=watchOS, platformCriteria={}}], TerritoriesAllowedToAlterPlusQuality=[JP]}
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter TransportHosts.Signiant = [sgr204.apple.com:44001]
            [2016-11-21 15:56:18 CST] <main> DBG-X:   parameter TransportHosts.DAV = [itmsdav.apple.com:443]
            [2016-11-21 15:56:18 CST] <main>  INFO: Examining the package at: /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/31E564B5-1597-4FC7-AEA7-9805E849CA34/117 2555383.itmsp
            [2016-11-21 15:56:18 CST] <main>  INFO: Ensuring that package has well formed metadata file...
            [2016-11-21 15:56:18 CST] <main> DEBUG: Getting case-sensitive metadata xml filename...
            [2016-11-21 15:56:18 CST] <main>  INFO: Gathering the list of valid files from the package ...
            [2016-11-21 15:56:18 CST] <main> DEBUG:   metadata.xml will be verified by Apple's web service to determine if it is a valid file.
            [2016-11-21 15:56:18 CST] <main> DEBUG:   ScoresandLines.ipa will be verified by Apple's web service to determine if it is a valid file.
            [2016-11-21 15:56:18 CST] <main>  INFO: Finished gathering the list of valid files from the package.
            [2016-11-21 15:56:18 CST] <main> DEBUG:   Case-sensitive metadata filename is: metadata.xml
            [2016-11-21 15:56:19 CST] <main>  INFO: Performing authentication of package 1172555383.itmsp ...
            [2016-11-21 15:56:19 CST] <main> DBG-X: Memory: [JVM] 32M free, 61M total, 910M max [System] (Physical) 63M free, 8192M total (Swap) 788M free, 6144M total
            [2016-11-21 15:56:19 CST] <main> DBG-X: Deflated 598 bytes to 444
            [2016-11-21 15:56:19 CST] <main> DBG-X: Using operation named: validateMetadata
            [2016-11-21 15:56:19 CST] <main> DBG-X: Apple's web service operation input parameters:
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter Application = iTMSTransporter
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter BaseVersion = 1.8.3
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter Client = Application Loader
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter ClientVersion = 3.1 (670)
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter Files = [metadata.xml, ScoresandLines.ipa]
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter Metadata = <?xml version="1.0" encoding="UTF-8"?>
            <package version="software5.2" xmlns="http://apple.com/itunes/importer">
                <software_assets apple_id="1172555383"
                    bundle_short_version_string="1.0.1"
                    bundle_version="1.0.1"
                    bundle_identifier="com.intouchdev.scores-and-lines">
                    <asset type="bundle">
                        <data_file>
                            <file_name>ScoresandLines.ipa</file_name>
                            <checksum type="md5">999dd69f59a307812fb3d0f848e6bca5</checksum>
                            <size>11693892</size>
                        </data_file>
                    </asset>
                </software_assets>
            </package>
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter MetadataChecksum = 2efc7f88d4f4ab53182e9195ee0b41d2
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter MetadataCompressed = (suppressed)
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter OSIdentifier = Mac OS X 10.10.5 (x86_64); jvm=24.80-b07; jre=1.7.0-internal-root_2015_01_13_21_57-b00
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter PackageName = 1172555383.itmsp
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter PackageSize = 11694490
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter TransporterArguments = -m upload -u info@intouchdev.com -p **hidden value** -f /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/31E564B5-1597-4FC7-AEA7-9805E849CA34/117 2555383.itmsp -checksumValidation false -indicator true -v eXtreme -Dtransporter.client=Application Loader -Dtransporter.client.version=3.1 (670)
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter Username = info@intouchdev.com
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter Version = 1.9.1
            [2016-11-21 15:56:19 CST] <main> DBG-X:   parameter iTMSTransporterMode = upload
            [2016-11-21 15:56:19 CST] <main>  INFO: id = 20161121155619-853
            [2016-11-21 15:56:20 CST] <main> DBG-X: Apple's web service operation return value:
            [2016-11-21 15:56:20 CST] <main> DBG-X:   parameter ApplicationSettings = {ShouldPricingTabBeDisplayed=true, IsVendorIDEditablePreferenceEnabled=true, SkipValidateProductErrors=true, SkipValidateFirenzeSPIUsage=false, MZWebServiceTimeOut=900, SkipValidatePurpleSPIUsage=false, IsDisplayArtistVisible=false, ITunesCrashLogServiceAddress=https://contentdelivery.itunes.apple.com/WebObjects/MZLabelService.woa/json/MZITunesProduc erService, IsEnabledForMasteredForItunes=false, MZWebServiceValidateSoftwareSPIUsageMaximumSize=1048576, IsISBNOptional=true, PerformServerVerification=true, VerifyZipIntegrity=true, BookSeriesSequenceNumberFormatter=#.#;0;#0.#, IsPublicationDateOptional=false, softwareUserGuideFilePath=https://help.apple.com/itc/apploader/, AllowPublicationPreorderWithoutAssets=false, ITunesSoftwareServiceAllowedPlatforms=[{sdkID=com.apple.platform.iphoneos, validationMethod=ios, xmlID=ios, platformDirectory=iPhoneOS.platform, serverID=Purple, type=1, displayName=iOS App, platformCriteria={plistEntries={LSRequiresIPhoneOS=, MinimumOSVersion=}}}, {sdkID=com.apple.platform.macosx, validationMethod=osx, xmlID=osx, platformDirectory=MacOSX.platform, serverID=Firenze, type=2, displayName=macOS App, platformCriteria={plistEntries={LSMinimumSystemVersion=}}}, {validationMethod=iap, serverID=InAppPurchase, type=3, displayName=In-App Purchase}, {sdkID=com.apple.platform.appletvos, validationMethod=ios, xmlID=appletvos, platformDirectory=AppleTVOS.platform, serverID=AppleTVOS, type=4, displayName=Apple TV OS, platformCriteria={plistEntries={UIDeviceFamily=3}}}, {sdkID=com.apple.platform.watchos, validationMethod=ios, platformDirectory=WatchOS.platform, type=6, displayName=watchOS, platformCriteria={}}], TerritoriesAllowedToAlterPlusQuality=[JP]}
            [2016-11-21 15:56:20 CST] <main> DBG-X:   parameter CPUToken = a7925c9d-9aa4-45cc-a33e-514ad64c39cf/1479765379790
            [2016-11-21 15:56:20 CST] <main> DBG-X:   parameter AssetsToDescribe = [{UTI=com.apple.ipa, Role=source, ShouldDescribeAsset=true, Filename=ScoresandLines.ipa}]
            [2016-11-21 15:56:20 CST] <main> DBG-X:   parameter FileSizes = {ScoresandLines.ipa=11693892}
            [2016-11-21 15:56:20 CST] <main> DBG-X:   parameter Checksums = {ScoresandLines.ipa=999dd69f59a307812fb3d0f848e6bca5}
            [2016-11-21 15:56:20 CST] <main> DBG-X:   parameter Success = true
            [2016-11-21 15:56:20 CST] <main> DBG-X:   parameter FilesToUpload = [metadata.xml, ScoresandLines.ipa]
            [2016-11-21 15:56:20 CST] <main> DBG-X:   parameter MinimumFileSizeThresholdForCheckum = 104857600
            [2016-11-21 15:56:20 CST] <main> DBG-X:   parameter ProviderNameForToken = VZ36LY45R6
            [2016-11-21 15:56:20 CST] <main>  INFO: The list of files requested for upload by Apple is: [metadata.xml, ScoresandLines.ipa].  These are the files that will be uploaded.
            [2016-11-21 15:56:20 CST] <main>  INFO: Starting media analysis of assets
            [2016-11-21 15:56:20 CST] <main> DEBUG: Handling asset: filename=ScoresandLines.ipa,uti=com.apple.ipa,role=source,describe=true
            [2016-11-21 15:56:20 CST] <main> DEBUG: Using container type tool name and version: iOS App Describer:1.25
            [2016-11-21 15:56:20 CST] <main> DEBUG: Using path: /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/31E564B5-1597-4FC7-AEA7-9805E849CA34/117 2555383.itmsp/ScoresandLines.ipa
            [2016-11-21 15:56:21 CST] <main> DBG-X: Asset description: <?xml version="1.1" encoding="UTF-8"?>
            <!DOCTYPE plist PUBLIC "-//Apple//DTD PLIST 1.0//EN" "http://www.apple.com/DTDs/PropertyList-1.0.dtd">
            <plist version="1.0">
            <dict>
              <key>dev-tools-info</key>
              <dict>
              <key>platforms</key>
              <dict>
              <key>AppleTVOS.platform</key>
              <dict>
              <key>paths</key>
              <array/>
              </dict>
              <key>MacOSX.platform</key>
              <dict>
              <key>paths</key>
              <array/>
              </dict>
              <key>WatchOS.platform</key>
              <dict>
              <key>paths</key>
              <array/>
              </dict>
              <key>iPhoneOS.platform</key>
              <dict>
              <key>paths</key>
              <array/>
              </dict>
              </dict>
              <key>search-method</key>
              <integer>-2</integer>
              <key>search-method-string</key>
              <string>No suitable search paths found</string>
              </dict>
              <key>os-version</key>
              <string>10.10.5</string>
              <key>product-errors</key>
              <array>
              <dict>
              <key>code</key>
              <integer>-21023</integer>
              <key>message</key>
              <string>Developer tools could not be found. Be sure Xcode is installed and try again.</string>
              <key>userInfo</key>
              <dict>
              <key>NSLocalizedDescription</key>
              <key>NSLocalizedFailureReason</key>
              <string>Unable to validate your application.</string>
              </dict>
              </dict>
              </array>
              <key>product-metadata</key>
              <dict/>
              <key>tool-path</key>
              <string>/Users/andressalas/.itmstransporter/softwaresupport/bin/Frameworks/ITunesSoftware Service.framework</string>
              <key>tool-version</key>
              <string>1.9.784</string>
            </dict>
            </plist>
            [2016-11-21 15:56:21 CST] <main> DEBUG: Asset successfully described: com.apple.jingle.leghorn.software.AbstractSoftwareDescriber$1@2fb222d2
            [2016-11-21 15:56:21 CST] <main> DBG-X: Deflated 1915 bytes to 741
            [2016-11-21 15:56:21 CST] <main>  INFO: Asset media analysis has completed
            [2016-11-21 15:56:21 CST] <main> DBG-X: Memory: [JVM] 13M free, 77M total, 910M max [System] (Physical) 27M free, 8192M total (Swap) 788M free, 6144M total
            [2016-11-21 15:56:21 CST] <main> DBG-X: Using operation named: lookupTransportDiagnostic
            [2016-11-21 15:56:21 CST] <main> DBG-X: Apple's web service operation input parameters:
            [2016-11-21 15:56:21 CST] <main> DBG-X:   parameter Application = iTMSTransporter
            [2016-11-21 15:56:21 CST] <main> DBG-X:   parameter BaseVersion = 1.8.3
            [2016-11-21 15:56:21 CST] <main> DBG-X:   parameter Client = Application Loader
            [2016-11-21 15:56:21 CST] <main> DBG-X:   parameter ClientVersion = 3.1 (670)
            [2016-11-21 15:56:21 CST] <main> DBG-X:   parameter OSIdentifier = Mac OS X 10.10.5 (x86_64); jvm=24.80-b07; jre=1.7.0-internal-root_2015_01_13_21_57-b00
            [2016-11-21 15:56:21 CST] <main> DBG-X:   parameter TransporterArguments = -m upload -u info@intouchdev.com -p **hidden value** -f /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/31E564B5-1597-4FC7-AEA7-9805E849CA34/117 2555383.itmsp -checksumValidation false -indicator true -v eXtreme -Dtransporter.client=Application Loader -Dtransporter.client.version=3.1 (670)
            [2016-11-21 15:56:21 CST] <main> DBG-X:   parameter Username = info@intouchdev.com
            [2016-11-21 15:56:21 CST] <main> DBG-X:   parameter Version = 1.9.1
            [2016-11-21 15:56:21 CST] <main> DBG-X:   parameter iTMSTransporterMode = upload
            [2016-11-21 15:56:21 CST] <main>  INFO: id = 20161121155621-878
            [2016-11-21 15:56:24 CST] <main> DBG-X: Apple's web service operation return value:
            [2016-11-21 15:56:24 CST] <main> DBG-X:   parameter SigniantLoggingLevel = OFF
            [2016-11-21 15:56:24 CST] <main> DBG-X:   parameter ApplicationSettings = {ShouldPricingTabBeDisplayed=true, IsVendorIDEditablePreferenceEnabled=true, SkipValidateProductErrors=true, SkipValidateFirenzeSPIUsage=false, MZWebServiceTimeOut=900, SkipValidatePurpleSPIUsage=false, IsDisplayArtistVisible=false, ITunesCrashLogServiceAddress=https://contentdelivery.itunes.apple.com/WebObjects/MZLabelService.woa/json/MZITunesProduc erService, IsEnabledForMasteredForItunes=false, MZWebServiceValidateSoftwareSPIUsageMaximumSize=1048576, IsISBNOptional=true, PerformServerVerification=true, VerifyZipIntegrity=true, BookSeriesSequenceNumberFormatter=#.#;0;#0.#, IsPublicationDateOptional=false, softwareUserGuideFilePath=https://help.apple.com/itc/apploader/, AllowPublicationPreorderWithoutAssets=false, ITunesSoftwareServiceAllowedPlatforms=[{sdkID=com.apple.platform.iphoneos, validationMethod=ios, xmlID=ios, platformDirectory=iPhoneOS.platform, serverID=Purple, type=1, displayName=iOS App, platformCriteria={plistEntries={LSRequiresIPhoneOS=, MinimumOSVersion=}}}, {sdkID=com.apple.platform.macosx, validationMethod=osx, xmlID=osx, platformDirectory=MacOSX.platform, serverID=Firenze, type=2, displayName=macOS App, platformCriteria={plistEntries={LSMinimumSystemVersion=}}}, {validationMethod=iap, serverID=InAppPurchase, type=3, displayName=In-App Purchase}, {sdkID=com.apple.platform.appletvos, validationMethod=ios, xmlID=appletvos, platformDirectory=AppleTVOS.platform, serverID=AppleTVOS, type=4, displayName=Apple TV OS, platformCriteria={plistEntries={UIDeviceFamily=3}}}, {sdkID=com.apple.platform.watchos, validationMethod=ios, platformDirectory=WatchOS.platform, type=6, displayName=watchOS, platformCriteria={}}], TerritoriesAllowedToAlterPlusQuality=[JP]}
            [2016-11-21 15:56:24 CST] <main> DBG-X:   parameter AsperaLoggingLevel = OFF
            [2016-11-21 15:56:24 CST] <main> DBG-X:   testing host/port: vgr105.apple.com/33001
            [2016-11-21 15:56:26 CST] <aspera.util.SelectThread>  INFO: The upload of the file named /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/f002a2c0-0f34-4b38-83f3-7c0d276c0d116165 034951959949007dir/5aedbaf8-5806-4c16-a47b-07ef8cfad9ef5415784195769763849.txt has started.
            [2016-11-21 15:56:26 CST] <aspera.util.SelectThread>  INFO:      File: /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/f002a2c0-0f34-4b38-83f3-7c0d276c0d116165 034951959949007dir/5aedbaf8-5806-4c16-a47b-07ef8cfad9ef5415784195769763849.txt 11/11, 100% completed
            [2016-11-21 15:56:26 CST] <aspera.util.SelectThread>  INFO: The status is FINISHED for the file named /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/f002a2c0-0f34-4b38-83f3-7c0d276c0d116165 034951959949007dir/5aedbaf8-5806-4c16-a47b-07ef8cfad9ef5415784195769763849.txt.
            [2016-11-21 15:56:27 CST] <main>  INFO: The session's final state is Complete
            [2016-11-21 15:56:27 CST] <main>  INFO: Number of files transferred: 1 .  Names of files transferred:
            [2016-11-21 15:56:27 CST] <main>  INFO:     /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/f002a2c0-0f34-4b38-83f3-7c0d276c0d116165 034951959949007dir/5aedbaf8-5806-4c16-a47b-07ef8cfad9ef5415784195769763849.txt - Complete
            [2016-11-21 15:56:27 CST] <main> DEBUG: Using token file path /Users/andressalas/.itmstransporter/UploadTokens/Starks-MacBook-Pro.local_VZ36LY45R6_1172 555383.itmsp.token
            [2016-11-21 15:56:27 CST] <main> DEBUG: Attempting exclusive file lock on token file
            [2016-11-21 15:56:27 CST] <main> DEBUG: Set token: a7925c9d-9aa4-45cc-a33e-514ad64c39cf/1479765379790
            [2016-11-21 15:56:27 CST] <main> DBG-X: Memory: [JVM] 49M free, 77M total, 910M max [System] (Physical) 20M free, 8192M total (Swap) 788M free, 6144M total
            [2016-11-21 15:56:27 CST] <main> DBG-X: Deflated 598 bytes to 444
            [2016-11-21 15:56:27 CST] <main> DBG-X: Using operation named: validateAssets
            [2016-11-21 15:56:27 CST] <main> DBG-X: Apple's web service operation input parameters:
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter Application = iTMSTransporter
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter BaseVersion = 1.8.3
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter CPUToken = a7925c9d-9aa4-45cc-a33e-514ad64c39cf/1479765379790
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter Client = Application Loader
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter ClientVersion = 3.1 (670)
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter Files = [metadata.xml, ScoresandLines.ipa]
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter MetadataChecksum = 2efc7f88d4f4ab53182e9195ee0b41d2
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter MetadataCompressed = (suppressed)
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter OSIdentifier = Mac OS X 10.10.5 (x86_64); jvm=24.80-b07; jre=1.7.0-internal-root_2015_01_13_21_57-b00
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter PackageName = 1172555383.itmsp
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter PackageSize = 11694490
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter Transport = Aspera
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter TransporterArguments = -m upload -u info@intouchdev.com -p **hidden value** -f /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/31E564B5-1597-4FC7-AEA7-9805E849CA34/117 2555383.itmsp -checksumValidation false -indicator true -v eXtreme -Dtransporter.client=Application Loader -Dtransporter.client.version=3.1 (670)
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter Username = info@intouchdev.com
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter Version = 1.9.1
            [2016-11-21 15:56:27 CST] <main> DBG-X:   parameter iTMSTransporterMode = upload
            [2016-11-21 15:56:27 CST] <main>  INFO: id = 20161121155627-947
            [2016-11-21 15:56:28 CST] <main> DBG-X: Apple's web service operation return value:
            [2016-11-21 15:56:28 CST] <main> DBG-X:   parameter ErrorMessage = ERROR ITMS-90168: "The binary you uploaded was invalid.
            (1102)
            [2016-11-21 15:56:28 CST] <main> DBG-X:   parameter CPUToken = a7925c9d-9aa4-45cc-a33e-514ad64c39cf/1479765379790
            [2016-11-21 15:56:28 CST] <main> DBG-X:   parameter AssetsToDescribe = [{UTI=com.apple.ipa, Role=source, ShouldDescribeAsset=true, Filename=ScoresandLines.ipa}]
            [2016-11-21 15:56:28 CST] <main> DBG-X:   parameter FileSizes = {ScoresandLines.ipa=11693892}
            [2016-11-21 15:56:28 CST] <main> DBG-X:   parameter Checksums = {ScoresandLines.ipa=999dd69f59a307812fb3d0f848e6bca5}
            [2016-11-21 15:56:28 CST] <main> DBG-X:   parameter Errors = [ERROR ITMS-90168: "The binary you uploaded was invalid."]
            [2016-11-21 15:56:28 CST] <main> DBG-X:   parameter ErrorCode = 1102
            [2016-11-21 15:56:28 CST] <main> DBG-X:   parameter Success = false
            [2016-11-21 15:56:28 CST] <main> DBG-X:   parameter FilesToUpload = [metadata.xml, ScoresandLines.ipa]
            [2016-11-21 15:56:28 CST] <main> DBG-X:   parameter MinimumFileSizeThresholdForCheckum = 104857600
            [2016-11-21 15:56:28 CST] <main> ERROR: ERROR ITMS-90168: "The binary you uploaded was invalid."
            [2016-11-21 15:56:28 CST] <main> DBG-X: The error code is: 1102
            [2016-11-21 15:56:28 CST] <main>  INFO: Done performing authentication.
            [2016-11-21 15:56:28 CST] <main> DBG-X: Returning 1
            Package Summary:
            1 package(s) were not uploaded because they had problems:
              /var/folders/_9/2mtcv98n3svc3_c2mqjfz4cm0000gn/T/31E564B5-1597-4FC7-AEA7-9805E849CA34/117 2555383.itmsp - Error Messages:
            • 3. Re: Phonegap Cloud build uses old IOS binary.
              Upgrade your version of Application Loader. You can do that by downloading the newest version of Xcode.
              • 4. Re: Phonegap Cloud build uses old IOS binary.
                JuanCAlpizar Level 1
                I thought version 3.1 was the latest, where can I check for the newest one?
                • 5. Re: Phonegap Cloud build uses old IOS binary.
                  The version on my machine is 3.6.
                  Download Xcode from the App Store, and your version will be updated to the latest version.
