6 Replies Latest reply on Jun 20, 2016 4:19 PM by Kevin Parrott
    Illustrator Script Auto refreshing using timer
    karthickm50893796 Level 1
      How to run a script in timing base. for example i want to run a script 24/7 with out double click.. below attach its just a rough sketch of what i think!!Screen Shot 2016-06-14 at 3.41.36 PM.png
      when i paste my completed files to conversion folder then .PNG Conversion script need to run automatically, if there no files in conversion folder the .PNG Conversion script should stop .... Script need to active when System on..
        • 1. Re: Illustrator Script Auto refreshing using timer
          Kevin Parrott Level 2
          try using on idle script
          something like this should get you started
          on idle
               set FolderPath to alias "Path to conversion folder"
              set ConVert_Folder to (FolderPath) as alias
              -- DO YOUR THING --
              tell application "Finder"
                  move items of ConVert_Folder to folder "Path to output folder" with replacing
              end tell
              return 600 -- come back and do it again in 10 minutes (adjust as necessary)
          end idle
          • 2. Re: Illustrator Script Auto refreshing using timer
            on idle
            -- DO YOUR THING --
            end tell
            end idle
            Hi  Kevin Parrott
            Thanks for your fast and furious reply,
            I just try this method ( did i want to save this a application format )
            your commands please
            set FolderPath to alias "Macintosh HD:conversion folder"
            tell application "Finder" to set fileName to name of theFile
            tell (info for theFile) to set {_Name, _Extension} to {name, name extension}
            set fileName to text 1 thru ((get offset of "." & _Extension in _Name) - 1) of _Name
            set fullPath to (saveLocation & fileName)
            set extension to "_HQPNG.png"
            set VectorPath to fullPath & extension
            tell application "Adobe Illustrator"
            open theFile without dialogs
            activate
            export current document to file VectorPath as PNG24 with options {class:PNG24 export options, transparency:true, horizontal scaling:416.67, vertical scaling:416.67, saving as HTML:false}
            end tell
            move items of ConVert_Folder to folder "Macintosh HD:output folder" with replacing
            end tell
            return 10
            end idle
            Karthick
            • 3. Re: Illustrator Script Auto refreshing using timer
              sorry, save as an application, stay open after run handler
              • 5. Re: Illustrator Script Auto refreshing using timer
                Hi Kevin Parrott
                please check below script in your system pls
                activate
                end tell
                end tell
                return 10
                end idle
                Thanks | Karthick
                • 6. Re: Illustrator Script Auto refreshing using timer
                  your code will fail because the variable theFile at the beginning has nothing to reference to, you'll also need
                  to put in a repeat loop to go through all files etc.
