4 Replies Latest reply on Jun 14, 2016 3:02 PM by LKN Ann
    What are the correct settings to edit SnagIt screen capture video in Premiere
    LKN Ann
      Help? I am pretty new to this & trying to create a screen capture video tutorial using SangIt 12.3.2, editing it in Premiere Elements 12 & adding narration, and saving it to my PC to use in emails and on a website.  It plays/looks fine in Premiere, but when I render/save it to my PC, the resulting video looks jittery.  Can anyone tell me what settings & formats I need to change? Or, if this can be done at all?
        • 1. Re: What are the correct settings to edit SnagIt screen capture video in Premiere
          Screen grab software can use some pretty odd codecs and frame rates.
          You'll need to open a sample of the video in the free download Media Info and then post the report here. You may need to run the video through a program like Handbrake to make it editable.
          • 2. Re: What are the correct settings to edit SnagIt screen capture video in Premiere
            LKN Ann Level 1
            Results:
            General
            Complete name                            : C:\Shared\RE Marketing\BombBomb\Videos\Front_Demo.mp4
            Format                                   : MPEG-4
            Format profile                           : Base Media / Version 2
            Codec ID                                 : mp42 (mp41/isom)
            File size                                : 2.20 MiB
            Duration                                 : 22s 819ms
            Overall bit rate                         : 810 Kbps
            Encoded date                             : UTC 2016-06-13 18:42:14
            Tagged date                              : UTC 2016-06-13 18:42:14
            Video
            Format                                   : AVC
            Format/Info                              : Advanced Video Codec
            Format profile                           : Baseline@L4
            Format settings, CABAC                   : No
            Format settings, ReFrames                : 2 frames
            Format settings, GOP                     : M=1, N=10
            Codec ID                                 : avc1
            Codec ID/Info                            : Advanced Video Coding
            Source duration                          : 22s 819ms
            Bit rate                                 : 806 Kbps
            Width                                    : 1 800 pixels
            Height                                   : 1 080 pixels
            Display aspect ratio                     : 5:3
            Frame rate mode                          : Variable
            Frame rate                               : 10.000 fps
            Color space                              : YUV
            Chroma subsampling                       : 4:2:0
            Bit depth                                : 8 bits
            Scan type                                : Progressive
            Bits/(Pixel*Frame)                       : 0.041
            Stream size                              : 2.19 MiB (99%)
            Source stream size                       : 2.19 MiB (99%)
            Audio
            Format                                   : AAC
            Format/Info                              : Advanced Audio Codec
            Format profile                           : LC
            Codec ID                                 : 40
            Duration                                 : 22s 245ms
            Bit rate mode                            : Constant
            Bit rate                                 : 1 378 bps
            Nominal bit rate                         : 96.0 Kbps
            Channel(s)                               : 1 channel
            Channel positions                        : Front: C
            Sampling rate                            : 44.1 KHz
            Frame rate                               : 43.066 fps (1024 spf)
            Compression mode                         : Lossy
            Stream size                              : 3.74 KiB (0%)
            • 3. Re: What are the correct settings to edit SnagIt screen capture video in Premiere
              There are a couple of issues here.
              One is that the video is at 10 fps, which is highly non-standard for editable video. The other is that the video is 1800x1080 pixels in size, which is also highly non-standard.
              Premiere Elements is not going to give you a project setting to match that frame size -- but, with Handbrake, you'll at least be able to convert it to 1920x1080 with some letterboxing and a more standard 30 fps frame rate.
              • 4. Re: What are the correct settings to edit SnagIt screen capture video in Premiere
                LKN Ann Level 1
                Thanks for the Handbrake suggestion. After much trial & error, I was able to make it work. After editing in Premiere and adding narration, I rendered it as AVCHD1080p60 to my PC then ran that file through Handbrake to convert to MP4/Normal and it was nice and smooth.
