12 Replies Latest reply on Jun 17, 2016 1:32 AM by Johnwhite
    How to define my color?
    Johnwhite Level 1
      Hi experts,
      I have a script:
      app.findObjectPreferences = null;
      app.findObjectPreferences.fillColor = "MARKUP";
      app.changeObjectPreferences.fillColor = "Black";
      app.changeObject();
      app.findObjectPreferences.strokeColor = "MARKUP";
      app.changeObjectPreferences.strokeColor = "Black";
      app.changeObject();
      for find and change object color, but if the docs which has no such as color name in the swatch, the script will run into error, so, how can I define if no such as color, script continue? how can make the script as below working?
      myColor = myDoc.colors.name("MARKUP");
      if (!cmyColor) continue;
      app.findObjectPreferences.fillColor = myColor;
      app.changeObjectPreferences.fillColor = "Black;
      app.changeObject();
      app.findObjectPreferences.strokeColor = myColor;
      app.changeObject();
      thanks
      Regard
      John
        • 1. Re: How to define my color?
          milligramme Level 3
          Hi
          you can fix some part of this script.
          var myColor = myDoc.swatches.item("MARKUP");
          if (!myColor.isValid){
            alert("NO SWATCH");
            exit();
          now you can't exit if the document don't have 'MARKUP' swatch.
          but this code wont work in my InDesign CC, I found same issue
          [JS CS4] findObjectPreferences.fillColor error |Adobe Community https://forums.adobe.com/thread/583184
          I very much regret to say I don't have any idea to solve this problem.
          thank you
          mg
          • 2. Re: How to define my color?
            Johnwhite Level 1
            Thank you mg
            so I changed it into like this:
            alert("NO SWATCH");
            exit();
            app.changeObject();
            app.changeObjectPreferences.strokeColor = "Red";
            app.changeObject();
            but I got error.
            How can I fix?
            thanks
            regard
            John
            • 3. Re: How to define my color?
              Ravindra_KCS Level 1
              Hi John,
              You can use try catch for this as follows..
              try{
                  app.findObjectPreferences.fillColor = "Markup1";
                  app.changeObjectPreferences.fillColor = "Test";
                  app.changeObject();
                 catch(err)
                      app.findObjectPreferences.strokeColor = "Markup";
                      app.changeObject();
              Thanks and Regards
              Ravindra
              • 4. Re: How to define my color?
                Johnwhite Level 1
                Thank you Ravindra
                I have tried, but not work.
                thank you so much.
                regard
                John
                • 5. Re: How to define my color?
                  Kai Rübsamen Level 4
                  Does anybody get here a result?
                  I tried it with swatch (not just the name) or color and get always an error!
                  It doesn’t also work, if I use the swatch by its index, instead of the name.
                  There were some posts in the forum about some bugs in CS 4/5, but it seems, that is broken in CC too?
                  Kai
                  • 6. Re: How to define my color?
                    milligramme Level 3
                    Hi
                    I tested with following test-script on InDesign CS5/CC
                    CC partly works, CS5 not work for me.
                    findObjectPreferences.fillColor/strokeColor should be passed by `string`
                    var doc = app.activeDocument;
                    var c = doc.swatches.item("MARKUP");
                      if (!c.isValid){
                        alert("NO SWATCH");
                        exit()
                    // swatch index
                    var m = doc.swatches.itemByName("MARKUP").index;
                    var b = doc.swatches.item("Black").index;
                    $.writeln(app.version);
                    var props = ['strokeColor', 'fillColor'];
                    for (var i=0, len=props.length; i < len ; i++) {
                      app.findObjectPreferences = NothingEnum.nothing;
                      var prop = props[i];
                      $.writeln(prop);
                      // work for me in CC by string
                      // not work in CS5 by string
                      try {
                        $.writeln(">> " + "MARKUP".constructor.name);
                        app.findObjectPreferences[prop]   = "MARKUP";
                        app.changeObjectPreferences[prop] = "Black";
                        $.writeln("DONE!!");
                      catch(x_x){
                        $.writeln([x_x.message,x_x.line,$.stack].join("\n"));
                      // not work by swatch index
                      try {
                        $.writeln(">> " + doc.swatches[m]);
                        $.writeln(">> " + doc.swatches[m].constructor.name);
                        app.findObjectPreferences[prop] = doc.swatches[m];
                        app.changeObjectPreferences[prop] = doc.swatches[b];
                      catch(x_x){
                      // not work by swatch name
                      try {
                        $.writeln(">> " + doc.swatches.item("MARKUP"));
                        $.writeln(">> " + doc.swatches.item("MARKUP").constructor.name);
                        app.findObjectPreferences[prop] = doc.swatches.item("MARKUP");
                        app.changeObjectPreferences[prop] = doc.swatches.item("Black");
                      catch(x_x){
                      doc.changeObject();
                    thank you
                    mg.
                    • 7. Re: How to define my color?
                      Hm! Doesn’t work here: 11.2.0.99, OS 10.9.5
                      Kai
                      • 8. Re: How to define my color?
                        Johnwhite Level 1
                        yes! not work.
                        John
                        • 9. Re: How to define my color?
                          milligramme Level 3
                          oh sorry!
                          tried again, doesn't work.
                          9.3.0.106
                          osx 10.9.5
                          I guess it worked after find object operating in GUI.
                          • 10. Re: How to define my color?
                            John, what’s the goal? Only "MARKUP" or, "Mark-up", "Mark_UP" … which kind of objects? Example!
                            If FC does’t work, loop through all objects and check, if your color = your Color.
                            Kai
                            • 11. Re: How to define my color?
                              Here is an idea, that includes also the previous question "MARKUP, markup, MARK-UP, MARK_UP":
                              app.doScript(main, ScriptLanguage.JAVASCRIPT , [], UndoModes.ENTIRE_SCRIPT, "Replace Colors");
                              function main() {
                              var curDoc = app.activeDocument;
                              var allSwatches = curDoc.swatches;
                              var allPItems = curDoc.allPageItems;
                              var colorsToRemove = [];
                              for (var i = 0; i < allSwatches.length; i++) {
                                var curSwatch = allSwatches[i];
                                var curSwatchName = curSwatch.name;
                                var colorToFind = curSwatchName.search(/Mark[-_]?UP/i);
                                if (colorToFind != -1) {
                              colorsToRemove.push(curSwatch.name);
                              alert("Found color names:\r" + colorsToRemove.join("\r"));
                              for (i = 0; i < allPItems.length; i++) {
                                var curItem = allPItems[i];
                                var fColorName = curItem.fillColor.name;
                                var sColorName = curItem.strokeColor.name;
                                for (var j = 0; j < colorsToRemove.length; j++) {
                              var curColorName = colorsToRemove[j];
                              if (fColorName == curColorName) {
                              curItem.fillColor = "Black";
                              if (sColorName == curColorName) {
                              curItem.strokeColor = "Black";
                              btw: the syntax highlighting destroyed the code
                              Kai
                              • 12. Re: How to define my color?
                                Johnwhite Level 1
                                great!
                                thanks Kai
                                thank so much.
                                regard
                                John
