1 Reply Latest reply on Jun 15, 2016 3:25 AM by Willi Adelberger
    Indesign Crash
    alexwow2016
      Running Adobe InDesign CC 2015.3 release build is 11.3.0.34  x64 Build running on Windows 7.
      This is a new install.
      Randomly crashes will produce a pop saying Indesign stopped working , sometimes the program will just freeze and not responding.
      Solution is to end task then restart it again.
      Windows logs produced below
      Faulting application name: InDesign.exe, version: 11.3.0.34, time stamp: 0x56d9d456
      Faulting module name: PDF.RPLN, version: 11.3.0.34, time stamp: 0x56d9d93d
      Exception code: 0xc0000005
      Fault offset: 0x00000000000c7cfe
      Faulting process id: 0x21ec
      Faulting application start time: 0x01d1c6dcadfcb94e
      Faulting application path: C:\Program Files\Adobe\Adobe InDesign CC 2015\InDesign.exe
      Faulting module path: C:\Program Files\Adobe\Adobe InDesign CC 2015\Required\PDF.RPLN
      Report Id: 12e9f363-32d9-11e6-8087-64006a69e5cb
      thereafter restarting 20mins later produced
      The program InDesign.exe version 11.3.0.34 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Action Center control panel.
      Process ID: 272c
      Start Time: 01d1c6e68bcc1e73
      Termination Time: 35
      Application Path: C:\Program Files\Adobe\Adobe InDesign CC 2015\InDesign.exe
      Report Id:
      Any ideas on how to fix this problem?
      thanks
