2 Replies Latest reply on Jun 20, 2016 4:47 AM by ArieKant
    What am I doing wrong with my search form?
    ArieKant
      Hello,
      First of all, hopefully you can bare with me, I am a beginner with building apps ............ ;-)
      I am trying to make a app where you can find a number in a search field.
      Everything works OK in a browser,Searchform (try 25388258 as an example) but when I build in into an app on https://build.phonegap.com I get an error:
      net::ERR_FILE_NOT_FOUND (file:///app3/www/zoeken.php)
      I think I know what's going wrong but have no idea how to solve it ...... ;-)
      From the index.html I use a AJAX call to get to the data a zoeken.php. I have onclick="findBondsnummer()" in the search button and this function look like this:
      function findBondsnummer() {
          var local_storage_id = localStorage.getItem('local_storage_id');
          var bondsnummer      = document.getElementById('opzoekveld').value;
          if(document.getElementById('details_alle_deelnemers').style.display=='block') {
            document.getElementById('details_alle_deelnemers').style.display='none';
          if(document.getElementById('details_zoeken').style.display=='none') {
            document.getElementById('details_zoeken').style.display='block';
          if (local_storage_id != '') {
              if (window.XMLHttpRequest) { // Create the object for browsers
                  xmlhttp = new XMLHttpRequest();
              } else { // Create the object for browser versions prior to IE 7
                  xmlhttp = new ActiveXObject("Microsoft.XMLHTTP");
              xmlhttp.onreadystatechange=function() { // If server is ready with the response
                  if (xmlhttp.readyState == 4) { // If everything is Ok on browser
                      if(xmlhttp.status == 200) { // Update the div with the response
                          document.getElementById("details_zoeken").innerHTML = xmlhttp.responseText;
              // Send the selected option id to the php page
              xmlhttp.open("GET","http://www.speelsterkte.nl/app3/www/zoeken.php?local_storage_ID="+local_storage_id+"&bondsnummer="+bondsnummer,true);
              xmlhttp.send();
          } else {
              alert ('AJAX local storage is niet gevuld oftewel LEEG');
      And zoeken.php looks like this:
      <?PHP
      if(isset($_POST['ToevoegenSubmitButton'])) {
          $local_id = $_POST['local_id'];
          $bondsnummer = $_POST['bondsnummer'];
          $geslacht = $_POST['geslacht'];
          $achternaam = $_POST['achternaam'];
          $enkel = $_POST['enkel'];
          $dubbel = $_POST['dubbel'];
          $query  = "SELECT local_storage_id FROM tennisrating_users WHERE local_storage_id = $local_id AND bondsnummer = $bondsnummer";
          $result = mysqli_query($conn, $query) or die("Error: ".mysqli_error($conn));
          $row_cnt = mysqli_num_rows($result);
          // echo "<br /><br />row count = " . $row_cnt;
          // INVOEGEN IN DATABASE
          if($row_cnt == 0) {
              // DEZE GEBRUIKER VOEGT DEZE TENNISSER VOOR HET EERST TOE
              mysqli_query($conn, "INSERT INTO tennisrating_users (local_storage_id, bondsnummer, geslacht, naam, datum) VALUES ('$local_id', '$bondsnummer', '$geslacht', '$achternaam', NOW())");
              // VOOR DE ZEKERHEID OOK EEN NIEUW RECORD TOEVOEGEN AAN DE TABEL TENNISRATING_RATING
              mysqli_query($conn, "INSERT INTO tennisrating_rating (bondsnummer, enkel, dubbel, enkel_verschil, dubbel_verschil, datum) VALUES ('$bondsnummer', '$enkel', '$dubbel', 0.0000, 0.0000, NOW())");
              header("Location: http://speelsterkte.nl/app3/www/index.html");
              exit;
          } else { // DE GEZOCHTE TENNISSER KOMT AL VOOR IN DE USERS TABEL DUS ER HOEFT NIKS MEER GEDAAN TE WORDEN
              exit;
      <?php
      if ($mysql_bondsnummer == "v>") {
          echo "<h3 style='padding-left:2%;'>Number not found, try again</h3>";
      } else {
          <table cellpadding="0" cellspacing="0" border="1">
              <tr>
                  <td width="100%" colspan="2" style="background-color: #16A085"><h3><?php echo $mysql_achternaam; ?> (<?php echo $mysql_geslacht; ?>) - <?php echo $bondsnummer; ?></h3></td>
              </tr>
              <tr>
                  <td width="50%" style="text-align: left; background-color: #16A085;">Enkel</td>
                  <td width="50%" style="text-align: right; background-color: #16A085; padding-right: 1%;"><h4><?php echo $mysql_enkel; ?></h4></td>
              </tr>
              <tr>
                  <td width="50%" style="text-align: left; background-color: #16A085; padding-bottom: 5px;">Dubbel</td>
                  <td width="50%" style="text-align: right; background-color: #16A085; padding-bottom: 5px; padding-right: 1%;"><h4><?php echo $mysql_dubbel; ?></h4></td>
              </tr>
          </table>
          <form action='<?PHP echo htmlspecialchars($_SERVER[PHP_SELF]); ?>' method='post' class='contactForm' style='padding: 0 1%;'>
              <fieldset>
                  <input type="hidden" style="padding-left:1%;" name="local_id" value="<?php echo $local_storage_id; ?>">
                  <input type="hidden" style="padding-left:1%;" name="bondsnummer" value="<?php echo $bondsnummer; ?>">
                  <input type="hidden" style="padding-left:1%;" name="geslacht" value="<?php echo $mysql_geslacht; ?>">
                  <input type="hidden" style="padding-left:1%;" name="achternaam" value="<?php echo $mysql_achternaam; ?>">
                  <input type="hidden" style="padding-left:1%;" name="enkel" value="<?php echo $mysql_enkel; ?>">
                  <input type="hidden" style="padding-left:1%;" name="dubbel" value="<?php echo $mysql_dubbel; ?>">
                  <div class="formSubmitButtonErrorsWrap">
                      <input type="submit" class="buttonWrap button button-orange contactSubmitButton" name="ToevoegenSubmitButton" value="TOEVOEGEN" />
                  </div>
              </fieldset>
          </form>
      <?php } ?>
      As you can see, when the ToevoegenSubmitButton is clicked, the PHP script if(isset($_POST['ToevoegenSubmitButton'])) { ... } is fired.
      But in the app it fires also action of the form.
      How do I get this PHP code for ToevoegenSubmitButton to work without the app trying to do the action of the form?
      Kind regards,
      Arie
        • 1. Re: What am I doing wrong with my search form?
          shotts@adobe Adobe Employee
          So, it looks to me like you're trying to push HTML into your app from a PHP script. Inserting HTML like this is almost certainly going to cause issues because the app's origin is file://, but relative URIs in your returned HTML aren't going to be expecting that. I'm guessing that's the issue with the form action -- instead of returning "http://path/to/your/script.php", it's just generating "script.php", which, when submitted, will try to load from "file://.../script.php".
          In short, don't do things this way. There's all sorts of problems by doing so (security, usability, head-meets-desk moments). Use a local user interface (use JavaScript for a dynamic interface) that communicates with your backend using a webservice (can be PHP) that returns JSON objects. Don't forget to make sure that communication is over HTTPS, of course.
          • 2. Re: What am I doing wrong with my search form?
            ArieKant Level 1
            Hi, tnx for answering !
            But as you can predict, I do more with PHP and MySQL than making an app with Phonegap ... ;-)
            Can you give me a (short) explanation how to make a PHP webservice that return JSON objects so I do some searching in the app and add the search result into a mysql database?
            Kind regards,
            Arie
