1 Reply Latest reply on Mar 15, 2009 8:21 AM by robdillon
    Dynamic Text issues
    beko75
      Hi Guys,
      I am loading a text dynamically from flash which pulls the text up from either HTML or txt file and is lacking showing some special characters, more specifically it doesn't show the apostrophe ( ' ) what I am in need for now.
      Does anyone have any solution how to fix this issue? I would appreciate it in endlessness if someone comes up with a solution.
      Thanks a lot for any efforts.
      Respectfully yours,
      Beko
        • 1. Re: Dynamic Text issues
          robdillon Most Valuable Participant
          Try changing the apostophe to the straight version. Flash doesn't read curly quotes. Most text editors will let you convert from one to the other. If that doesn't fix it or you want to keep the curly version, try using a text entity instead. You could substitute ‘ for the apostrophe and see if that works.
