2 Replies Latest reply on Jun 17, 2016 6:16 AM by j.s51476751
    Activation and running the application
    Julian1987
      Hi, i installed ADE 4.5.1 but the application doesn´t run, as solution i deleted and installed version 3.0 and this one runs but once i try to open my book there is an error message "error:check activation" so i don´t know what to do. what do you suggest?
        • 1. Re: Activation and running the application
          j.s51476751
          i have the same problem. in the 4.5 version i get the error message trying to open a new book. opening a new book I get the message:
          i can't deactivate my autorisation either
          • 2. Re: Activation and running the application
            j.s51476751 Level 1
            I find this solution via another forum member. for me it worked.
            succes
            For this problem, you need to deauthorize and authorize ADE again.
            Mac:
            1. 1. Go-> Go to folder.
            Go to folder dialog will appear.
            1. 2. Type   ~/Library/Application Support/Adobe/Digital Editions
            drag the activation.dat file to the trash.
            ADE will be deauthorized now.
            Now Authorize ADE again [Help -> Authorize Computer].
            Windows:
            Choose Start > Run.
            In the Open text box, type regedit and then press Enter. The Registry Editor opens.
            In the left pane of the Registry Editor, locate the following registry key:
            HKEY_CURRENT_USER\Software\Adobe\Adept
            Right-click the Adept key and choose Delete.
            In the Confirm Key Delete dialog, click OK.
            Your authorization will be deleted.
            Now Authorize ADE again.
