5 Replies Latest reply on Apr 24, 2006 9:33 AM by Newsgroup_User
    change a negative number to a postive
    Level 7
      Hi all,
      Is there an easy way to change a negative number into a positive? (i.e.
      "-4" becomes just plain old "4")? I've been using a complicated system of
      multiplying the number by itself and then finding the square root, but Flash
      has to have something easier. Any ideas?
      Thanks.
        • 1. Re: change a negative number to a postive
          Level 7
          Brock,
          > a positive? (i.e. "-4" becomes just plain old "4")?
          var n:Number = -4;
          trace(n); // output: -4
          n *= -1;
          trace(n) // output: 4
          > I've been using a complicated system of multiplying the
          > Flash has to have something easier.
          Just multiply by -1, and you're in.
          David
          stiller (at) quip (dot) net
          Dev essays: http://www.quip.net/blog/
          "Luck is the residue of good design."
          • 2. Re: change a negative number to a postive
            Level 7
            >> but Flash has to have something easier.
            P.S.
            Of course, Math.abs() will do the same (absolute value), but the -1
            approach means you can convert back to a negative number again.
            David
            • 3. Re: change a negative number to a postive
              Level 7
              y=(-4)
              x = (-y)
              trace(x)
              //outputs 4
              Dan Mode
              *Must Read* http://www.smithmediafusion.com/blog
              *Flash Helps* http://www.smithmediafusion.com/blog/?cat=11
              "Brock" <bramsay@inlets.net> wrote in message
              news:e2it0h$off$1@forums.macromedia.com...
              > Hi all,
              > Flash has to have something easier. Any ideas?
              > Thanks.
              • 4. Re: change a negative number to a postive
                Magic_Maker
                Havn't seen one.. but I ave needed to use one before and did it this way:
                lets suppose a = -4
                make a new var 'b'
                make b = bX2 (in this case it would = -8 )
                make a = a-b (a now = 4)
                but for my purpose, I also had to wrap it in an if/else statement (eg, if a <0) cos I allways needed it to be a positive number or else it would turn a positive into a negitive...
                Hope you find an easier way tho.... good luck.....
                • 5. Re: change a negative number to a postive
                  Level 7
                  Wow - thanks everyone!
                  I'm going to use David's Math.abs() solution because I don't want it to ever
                  show up as a negative again (And I'm starting with a list of both positive
                  and negative numbers that all need to be turned to positive).
                  Again, though, thanks to everyone for the suggestions!
                  Cheers.
                  > Hi all,
                  > Thanks.
