7 Replies Latest reply on Jun 24, 2016 9:34 AM by JJMack
    Script Photoshop HDR
    stevens29187206
      Hi, I would need your help. I want to personalize this code that it run automatically when i launch it without waiting for click OK anymore. Thank you very much.
      #target photoshop
       Batch HDR Script by David Milligan
      This program is free software: you can redistribute it and/or modify
      it under the terms of the GNU General Public License as published by
      the Free Software Foundation, either version 3 of the License, or
      (at your option) any later version.
      This program is distributed in the hope that it will be useful,
      but WITHOUT ANY WARRANTY; without even the implied warranty of
      MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.  See the
      GNU General Public License for more details.
      You should have received a copy of the GNU General Public License
      along with this program.  If not, see <http://www.gnu.org/licenses/>.
      // BEGIN__HARVEST_EXCEPTION_ZSTRING
      <javascriptresource>
      <name>Batch HDR...</name>
      <menu>automate</menu>
      </javascriptresource>
      // END__HARVEST_EXCEPTION_ZSTRING
      //these lines import the 'Merge To HDR.jsx' script that is built in to photoshop, we will make calls to that script and some of the scripts that it includes
      var runMergeToHDRFromScript = true;
      var g_ScriptFolderPath = app.path + "/"+ localize("$$$/ScriptingSupport/InstalledScripts=Presets/Scripts");
      var g_ScriptPath = File( g_ScriptFolderPath+'/Merge To HDR.jsx' );
      $.evalFile( g_ScriptPath );
      //$.level = 2;
      //default settings:
      mergeToHDR.useAlignment = true;
      mergeToHDR.useACRToning = false;
      var numberOfBrackets = 3;
      var userCanceled = false;
      var sourceFolder = new Folder('/d/Automata/LOADING');;
      var outputFolder = new Folder('/d/Automata/LOADING');;
      var saveType = "JPEG";
      var jpegQuality = 80;
      var progress;
      var statusText;
      var progressWindow;
      var fileMask = "*";
      var outputFilename = "hdr_output_";
      var zeroPadding = 2;
      var hdrRadius = 100;
      var hdrStrength = 0.5;
      var hdrGamma = 1.0;
      var hdrExposure = 0.0;
      var hdrDetail = 100;
      var hdrShadow = 0;
      var hdrHighlights = 0;
      var hdrVibrance = 20;
      var hdrSaturation = 30;
      var hdrSmooth = false;
      var hdrDeghosting = kMergeToHDRDeghostBest;//kMergeToHDRDeghostOff
      var hdrCurve = "0,0,255,255";
      var estTimeRemaining = "";
      var previewDoc;
      var originalDoc;
      function main()
          promptUser();
          //make sure user didn't cancel
          if(sourceFolder != null && outputFolder != null && sourceFolder.exists && outputFolder.exists && numberOfBrackets > 0)
              initializeProgress();
              var files =  sourceFolder.getFiles(fileMask);
              files.sort();
              var currentFileList = new Array();
              var numberOfFiles = files.length;
              if (numberOfFiles % 3 == 0)
              else
                  numberOfBrackets = 2;
              /* convert numberOfFiles to a string to make sure zeropaddingis high enough to cover all files */
              var numberOfFilesStr = "" + (numberOfFiles / numberOfBrackets);
              if (zeroPadding > 0 && zeroPadding < numberOfFilesStr.length)
                  zeroPadding = numberOfFilesStr.length;
              for(var index = 0;  index < numberOfFiles; index++)
                  if((index % numberOfBrackets) == numberOfBrackets - 1)
                      var start = new Date();
                      progress.value = 100 * index / numberOfFiles;
                      currentFileList.push(files[index]);
                      if(userCanceled) break;
                      if(numberOfBrackets > 1)
                          statusText.text = "Merging files "+(index-numberOfBrackets+2)+" - "+(index+1)+" of "+numberOfFiles + estTimeRemaining;
                          //for braketed exposures use the mergeToHDR script to merge the files into a single 32 bit image
                          mergeToHDR.outputBitDepth= 32;
                          mergeToHDR.mergeFilesToHDR( currentFileList, mergeToHDR.useAlignment, hdrDeghosting );
                          statusText.text = "Toning files "+(index-numberOfBrackets+2)+" - "+(index+1)+" of "+numberOfFiles+ estTimeRemaining;
                      else
                          statusText.text = "Loading file "+(index+1)+" of "+numberOfFiles+ estTimeRemaining;
                          //otherwise just open the file
                          doOpenFile(files[index]);
                          statusText.text = "Toning file "+(index+1)+" of "+numberOfFiles+ estTimeRemaining;
                      progress.value = 100 * (index + numberOfBrackets / 2 ) / numberOfFiles;
                      try
                          if(app.activeDocument != null && outputBitDepth < 32)
                              //apply the actual tone mapping to the HDR image to get it back down to 8 bits
                              doHDRToning();
                      catch(error)
                          alert(error + "\nCheck number of files in source folder");
                          break;
                      //save the result and close
                      //TODO: add leading zeros to index in filename
                          statusText.text = "Saving result "+(index-numberOfBrackets+2)+" - "+(index+1)+" of "+numberOfFiles+ estTimeRemaining;
                      else
                          statusText.text = "Saving result "+(index+1)+" of "+numberOfFiles+ estTimeRemaining;
                      doSaveFile(outputFolder.absoluteURI + "/" + outputFilename + ZeroPad(Math.round((index + 1)/numberOfBrackets), zeroPadding) );
                      activeDocument.close(SaveOptions.DONOTSAVECHANGES);
                      //reset our file list
                      //calculate time remaining
                      var end = new Date();
                      var timeElapsed = end.getTime() - start.getTime();
                      var mins = timeElapsed / 60000 * ((numberOfFiles - index - 1) / numberOfBrackets);
                      estTimeRemaining = " | Remaining: " + ZeroPad((mins / 60).toFixed(0),2) + ":" + ZeroPad((mins % 60).toFixed(0),2);
                  else
              progressWindow.hide();
      function doOpenFile(filename)
          const eventOpen = app.charIDToTypeID('Opn ');
          var desc = new ActionDescriptor();
          desc.putPath( typeNULL, new File( filename ) );
          desc.putBoolean( kpreferXMPFromACRStr, true ); //not sure what this does or if it is needed
          executeAction( eventOpen, desc, DialogModes.NO );
          //if we don't convert the image to 32bit the mergeToHDR script will not tone our image when we call it, it will simply downconvert it to 8 bit
          convertTo32Bit ();
      function convertTo32Bit()
          var idCnvM = charIDToTypeID( "CnvM" );
          var desc6 = new ActionDescriptor();
          var idDpth = charIDToTypeID( "Dpth" );
          desc6.putInteger( idDpth, 32 );
          var idMrge = charIDToTypeID( "Mrge" );
          desc6.putBoolean( idMrge, false );
          var idRstr = charIDToTypeID( "Rstr" );
          desc6.putBoolean( idRstr, false );
          executeAction( idCnvM, desc6, DialogModes.NO );
      function doSaveFile(filename)
          if(saveType == "JPEG")
              var jpgSaveOptions = new JPEGSaveOptions();
              jpgSaveOptions.embedColorProfile = true;
              jpgSaveOptions.formatOptions = FormatOptions.STANDARDBASELINE;
              jpgSaveOptions.matte = MatteType.NONE;
              jpgSaveOptions.quality = jpegQuality;
              activeDocument.saveAs(new File(filename), jpgSaveOptions, true /*Save As Copy*/, Extension.LOWERCASE /*Append Extention*/);
          else if(saveType == "TIFF")
              var tifSaveOptions = new TiffSaveOptions();
              tifSaveOptions.embedColorProfile = true;
              activeDocument.saveAs(new File(filename), tifSaveOptions, true /*Save As Copy*/, Extension.LOWERCASE /*Append Extention*/);
          else if(saveType == "TIFF LZW")
              tifSaveOptions.imageCompression = TIFFEncoding.TIFFLZW;
          else if(saveType == "TIFF ZIP")
              tifSaveOptions.imageCompression = TIFFEncoding.TIFFZIP;
          else
              activeDocument.saveAs(new File(filename), undefined, true /*Save As Copy*/, Extension.LOWERCASE /*Append Extention*/);
      function doHDRToning()
          //create the ActionDescriptor that describes the HDR toning settings to use
          var hdDesc = new ActionDescriptor;
          hdDesc.putInteger( stringIDToTypeID( 'version' ), 6 );//I'm not sure what this does
          hdDesc.putInteger(  kmethodStr, 3 );// the toning method to use, 3 = local adaptation
          hdDesc.putDouble( stringIDToTypeID( 'radius' ), hdrRadius );
          hdDesc.putDouble( stringIDToTypeID( 'threshold' ), hdrStrength );// strength
          hdDesc.putDouble( stringIDToTypeID( 'center' ), hdrGamma );// gamma
          hdDesc.putDouble( stringIDToTypeID( 'brightness' ), hdrExposure );// exposure
          hdDesc.putDouble( stringIDToTypeID( 'detail' ), hdrDetail );
          hdDesc.putDouble( stringIDToTypeID( 'shallow' ), hdrShadow );
          hdDesc.putDouble( stringIDToTypeID( 'highlights' ), hdrHighlights );
          hdDesc.putDouble( stringIDToTypeID( 'vibrance' ), hdrVibrance );
          hdDesc.putDouble( stringIDToTypeID( 'saturation' ), hdrSaturation);
          hdDesc.putBoolean( stringIDToTypeID( 'smooth' ), hdrSmooth );
          hdDesc.putBoolean( stringIDToTypeID( 'deghosting' ), hdrDeghosting );
          //create the tone curve
          var cDesc = new ActionDescriptor;
          cDesc.putString( stringIDToTypeID( 'name' ), 'Default');
          var cList = new ActionList;
          var points = hdrCurve.split(',');
          for(var i = 0; i < points.length; i++)
              if(i % 2 == 1)
                  var pDesc = new ActionDescriptor;
                  pDesc.putDouble( stringIDToTypeID( 'horizontal' ), points[i-1] );
                  pDesc.putDouble( stringIDToTypeID( 'vertical' ), points[i] );
                  pDesc.putBoolean( keyContinuity , false );// ?????
                  cList.putObject( charIDToTypeID( 'Pnt ' ), pDesc );
          cDesc.putList( stringIDToTypeID( 'curve' ), cList );
          hdDesc.putObject( kclassContour, classShapingCurve, cDesc );
          //call the script that actually invokes the toning plugin
          convertFromHDRNoDialog( outputBitDepth, hdDesc );
      function initializeProgress()
          progressWindow = new Window("palette { text:'Meilleure Visite Chargement', \
              statusText: StaticText { text: 'Processing Images...', preferredSize: [350,20] }, \
              progressGroup: Group { \
                  progress: Progressbar { minvalue: 0, maxvalue: 100, value: 0, preferredSize: [300,20] }, \
                  cancelButton: Button { text: 'Cancel' } \
          statusText = progressWindow.statusText;
          progress = progressWindow.progressGroup.progress;
          progressWindow.progressGroup.cancelButton.onClick = function() { userCanceled = true; }
          progressWindow.show();
      function promptUser()
          var setupWindow = new Window("dialog { orientation: 'row', text: 'Meilleure Visite', alignChildren:'top', \
              leftGroup: Group { orientation: 'column', alignChildren:'fill', \
                  inputPanel: Panel { text: 'Input', \
                      sourceGroup: Group { \
                      bracketGroup: Group{ \
                          bracketLabel: StaticText { text: 'Number of Brackets: ' }, \
                          bracketBox: EditText { characters: 2 }, \
                          filterLabel: StaticText { text: 'File Filter: ' }, \
                          filterText: EditText { characters: 5 }, \
                          alignCheckBox: Checkbox { text: 'Align' }\
                          deghostLabel: StaticText { text: 'Deghost: ' }\
                          deghostDropDown: DropDownList { }, \
                  toningPanel: Panel { text: 'Toning', orientation:'row', alignChildren:'top' } ,\
                  outputPanel: Panel { text: 'Output', \
                      outputGroup: Group { \
                          outputBox: EditText { characters: 10, text: '', enabled:false }, \
                      outputOptionsGroup: Group { \
                          outputFilenameLabel: StaticText { text: 'Filename Format: ' }, \
                          outputFilenameText: EditText { characters: 10 }, \
                      saveSettingsGroup: Group { \
                          saveTypeLabel: StaticText { text: 'Save As: ' }, \
                          saveDropDown: DropDownList { }, \
                          jpegQualityLabel: StaticText { text: 'JPEG Quality (1-10): ' }, \
                          jpegQualityText: EditText { characters: 2}, \
                          outputBitDepthLabel: StaticText { text: 'Bit Depth', enabled:false }, \
                          outputBitDepthDropDown: DropDownList { enabled:false }, \
              rightGroup: Group { orientation: 'column', alignChildren:'fill', \
                  okButton: Button { text: 'OK', enabled: true } \
          generateToningPanel(setupWindow.leftGroup.toningPanel);
          //shortcut variables
          var sourceBox = setupWindow.leftGroup.inputPanel.sourceGroup.sourceBox;
          var sourceBrowse = setupWindow.leftGroup.inputPanel.sourceGroup.sourceBrowse;
          var bracketBox = setupWindow.leftGroup.inputPanel.bracketGroup.bracketBox;
          var filterText = setupWindow.leftGroup.inputPanel.bracketGroup.filterText;
          var alignCheckBox = setupWindow.leftGroup.inputPanel.bracketGroup.alignCheckBox;
          var outputBox = setupWindow.leftGroup.outputPanel.outputGroup.outputBox;
          var outputFilenameText = setupWindow.leftGroup.outputPanel.outputOptionsGroup.outputFilenameText;
          var outputFilenamePost = setupWindow.leftGroup.outputPanel.outputOptionsGroup.outputFilenamePost;
          var saveDropDown = setupWindow.leftGroup.outputPanel.saveSettingsGroup.saveDropDown;
          var jpegQualityText = setupWindow.leftGroup.outputPanel.saveSettingsGroup.jpegQualityText;
          var jpegQualityLabel = setupWindow.leftGroup.outputPanel.saveSettingsGroup.jpegQualityLabel;
          var outputBitDepthDropDown = setupWindow.leftGroup.outputPanel.saveSettingsGroup.outputBitDepthDropDown;
          var outputBitDepthLabel = setupWindow.leftGroup.outputPanel.saveSettingsGroup.outputBitDepthLabel;
          var okButton = setupWindow.rightGroup.okButton;
          var cancelButton = setupWindow.rightGroup.cancelButton;
          var toningPanel = setupWindow.leftGroup.toningPanel;
          var deghostDropDown = setupWindow.leftGroup.inputPanel.bracketGroup.deghostDropDown;
          //set default values
          bracketBox.text = numberOfBrackets;
          filterText.text = fileMask;
          //mergeToHDR.useAlignment = true;
          alignCheckBox.value = mergeToHDR.useAlignment;
          outputFilenameText.text = outputFilename;
          jpegQualityText.text = jpegQuality;
          saveDropDown.add("item", "TIFF");
          saveDropDown.add("item", "JPEG");
          saveDropDown.add("item", "TIFF LZW");
          saveDropDown.add("item", "TIFF ZIP");
          saveDropDown.selection = 0;
          outputBitDepthDropDown.add("item", "8");
          outputBitDepthDropDown.add("item", "16");
          outputBitDepthDropDown.add("item", "32");
          outputBitDepthDropDown.selection = 0;
          var generateDeghostDropDownList = function(count)
              deghostDropDown.removeAll()
              deghostDropDown.add("item", "Best");
              deghostDropDown.add("item", "Off");
              for(var i = 0; i < count; i++)
                  deghostDropDown.add("item", i);
              deghostDropDown.selection = 0;
          generateDeghostDropDownList(numberOfBrackets);
          //event handlers
          bracketBox.onChange = function()
              numberOfBrackets = bracketBox.text;
          filterText.onChange = function() { fileMask = filterText.text; };
          alignCheckBox.onClick = function() { mergeToHDR.useAlignment = alignCheckBox.value; };
          deghostDropDown.onChange = function()
              if(this.selection.text == "Best")
              else if(this.selection.text == "Off")
                  hdrDeghosting = kMergeToHDRDeghostOff;
              else
                  hdrDeghosting = Number(this.selection.text);
          outputBox.onChange = function()
              outputFolder = new Folder(outputBox.text);
              okButton.enabled = sourceFolder != null && outputFolder != null && sourceFolder.exists && outputFolder.exists;
          outputFilenameText.onChange = function() { outputFilename = outputFilenameText.text; };
          saveDropDown.onChange = function()
              saveType = saveDropDown.selection.text;
              jpegQualityText.enabled = saveDropDown.selection.text == "JPEG";
              jpegQualityLabel.enabled = saveDropDown.selection.text == "JPEG";
              if(saveDropDown.selection.text == "JPEG")
              outputBitDepthDropDown.enabled = saveDropDown.selection.text != "JPEG" && saveDropDown.selection.text != "Radiance" && saveDropDown.selection.text != "OpenEXR";
              outputBitDepthLabel.enabled = outputBitDepthDropDown.enabled;
          jpegQualityText.onChange = function() { jpegQuality = jpegQualityText.text; };
          outputBitDepthDropDown.onChange = function()
              outputBitDepth = outputBitDepthDropDown.selection.text;
              toningPanel.enabled = outputBitDepth != 32;
          okButton.onClick = function() { setupWindow.hide(); cleanUpPreviews(); };
          cancelButton.onClick = function() { sourceFolder = null, setupWindow.hide(); cleanUpPreviews(); };
          saveDropDown.onChange();
          outputBitDepthDropDown.onChange();
          setupWindow.show();
      function cleanUpPreviews()
          if(originalDoc != null)
              originalDoc.close(SaveOptions.DONOTSAVECHANGES);
              originalDoc = null;
          if(previewDoc != null)
              previewDoc.close(SaveOptions.DONOTSAVECHANGES);
              previewDoc = null;
      function generateToningPanel(toningPanel)
          var leftToningGroup = toningPanel.add("group{orientation:'column',alignChildren:'fill'}");
          var rightToningGroup = toningPanel.add("group{orientation:'column',alignChildren:'fill'}");
          var presetGroup = leftToningGroup.add("group{orientation:'row'}");
          var presetDropDown = presetGroup.add("dropdownlist");
          var loadPresetButton = presetGroup.add("button", undefined, "Load Preset");
          var edgePanel = leftToningGroup.add("panel",undefined,"Edge Glow");
          var radiusSlider = createSliderControl(edgePanel.add("group"), "  Radius: ", "px", 0, 500, 0, hdrRadius, function(newValue){ hdrRadius = newValue; });
          var strengthSlider = createSliderControl(edgePanel.add("group"), "Strength: ", "", 0, 4.0, 2, hdrStrength, function(newValue){ hdrStrength = newValue; });
          var edgeGroup = edgePanel.add("group");
          var smoothEdgesBox = edgeGroup.add("checkbox",undefined, "Smooth Edges");
          var detailPanel = leftToningGroup.add("panel",undefined,"Tone and Detail");
          var gammaSlider = createSliderControl(detailPanel.add("group"), "  Gamma: ", "", 0.1, 2.0, 2, hdrGamma, function(newValue){ hdrGamma = newValue; });
          var exposureSlider = createSliderControl(detailPanel.add("group"), "Exposure: ", "", -5.0, 5.0, 2, hdrExposure, function(newValue){ hdrExposure = newValue; });
          var detailSlider = createSliderControl(detailPanel.add("group"), "     Detail: ", "%", -300, 300, 0, hdrDetail, function(newValue){ hdrDetail = newValue; });
          var advancedPanel = leftToningGroup.add("panel",undefined,"Advanced");
          var shadowSlider = createSliderControl(advancedPanel.add("group"), "  Shadow: ", "%", -100, 100, 0, hdrShadow, function(newValue){ hdrShadow = newValue; });
          var highlightSlider = createSliderControl(advancedPanel.add("group"), " Highlight: ", "%",  -100, 100, 0, hdrHighlights, function(newValue){ hdrHighlights = newValue; });
          var vibranceSlider = createSliderControl(advancedPanel.add("group"), "  Vibrance: ", "%",  -100, 100, 0, hdrVibrance, function(newValue){ hdrVibrance = newValue; });
          var saturationSlider = createSliderControl(advancedPanel.add("group"), "Saturation: ", "%",  -100, 100, 0, hdrSaturation, function(newValue){ hdrSaturation = newValue; });
          var toningCurvePanel = leftToningGroup.add("panel{text:'Toning Curve',alignChildren:'fill'}");
          var curveBox = toningCurvePanel.add("edittext", undefined, hdrCurve);
          //default values
          smoothEdgesBox.value = hdrSmooth;
          var presetFiles = getPresetFiles();
          var updateSliders = function()
              radiusSlider(hdrRadius);
              strengthSlider(hdrStrength);
              exposureSlider(hdrExposure);
              gammaSlider(hdrGamma);
              detailSlider(hdrDetail);
              shadowSlider(hdrShadow);
              highlightSlider(hdrHighlights);
              vibranceSlider(hdrVibrance);
              saturationSlider(hdrSaturation);
              curveBox.text = hdrCurve;
          if(presetFiles.length > 0)
              for(var f in presetFiles)
                  presetDropDown.add("item", presetFiles[f].displayName.replace(".hdt",""));
              presetDropDown.selection = 0;
              loadPreset(presetFiles[0]);
              presetDropDown.onChange = function()
                  loadPreset(presetFiles[presetDropDown.selection.index]);
                  updateSliders();
          //event handlers
          loadPresetButton.onClick = function()
              loadPreset(null);
              updateSliders();
          smoothEdgesBox.onClick = function () { hdrSmooth = smoothEdgesBox.value; };
          curveBox.onChange = function () { hdrCurve = curveBox.text; };
          updateSliders();
      function createSliderControl(group,label,postLabel,min,max,round,value,onValueChanged)
          var ignoreChange = false;
          group.add("statictext", undefined, label);
          var slider = group.add("slider",undefined,value,min,max);
          slider.alignment = "fill";
          var box = group.add("edittext",undefined,value);
          box.characters = 6;
          group.add("statictext", undefined, postLabel);
          slider.onChange = function()
              if(!ignoreChange)
                  ignoreChange = true;
                  box.text = slider.value.toFixed(round);
                  onValueChanged(slider.value);
          box.onChange = function()
              if(!ignoreChange)
                  slider.value = box.text;
                  onValueChanged(box.text);
          return function(newValue)
              slider.value = newValue;
              box.text = newValue.toFixed(round);
      //forces a redraw while a script dialog is active (for preview)
      var waitForRedraw = function()
          desc.putEnumerated(charIDToTypeID("Stte"), charIDToTypeID("Stte"), charIDToTypeID("RdCm"));
          executeAction(charIDToTypeID("Wait"), desc, DialogModes.NO);
      function getZoomLevel()
          var ref = new ActionReference();
          ref.putEnumerated( charIDToTypeID("Dcmn"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
          var desc = executeActionGet(ref);
          return Number(desc.getDouble(stringIDToTypeID('zoom'))*100).toFixed(1);
      function setZoomLevel( zoom )
          if(zoom < 1 ) zoom =1;
          ref.putEnumerated( charIDToTypeID("capp"), charIDToTypeID("Ordn"), charIDToTypeID("Trgt") );
          var getScrRes = executeActionGet(ref).getObjectValue(stringIDToTypeID('unitsPrefs')).getUnitDoubleValue(stringIDToTypeID('newDocPresetScreenResolution'))/72;
          var docRes = activeDocument.resolution;
          activeDocument.resizeImage( undefined, undefined, getScrRes/(zoom/100), ResampleMethod.NONE );
          ref = null;
          ref.putEnumerated( charIDToTypeID( "Mn  " ), charIDToTypeID( "MnIt" ), charIDToTypeID( 'PrnS' ) );
          desc.putReference( charIDToTypeID( "null" ), ref );
          executeAction( charIDToTypeID( "slct" ), desc, DialogModes.NO );
          activeDocument.resizeImage( undefined, undefined, docRes, ResampleMethod.NONE );
      function ZeroPad(number,numZeros)
          var result = number.toString();
          while(result.length < numZeros)
              result = "0" + result;
          return result;
      var getPresetFiles = function()
          var presetFolder = new Folder(app.path + "/Presets/HDR Toning");
          return presetFolder.getFiles("*.hdt");
      var loadPreset = function(presetFile)
          if(presetFile == null)
              presetFile = File.openDialog("Select Preset","*.hdt");
          if(presetFile != null)
              var tmpStr = new String();
              var binaryData = new Array();
              presetFile.encoding = "BINARY";
              presetFile.open('r');
              while(!presetFile.eof)
                  var ch = presetFile.readch();
                  if ( ch.charCodeAt(0) == 0 ){
                      tmpStr += ' ';
                  else {
                      tmpStr += ch;
                  binaryData.push(ch.charCodeAt(0));
              presetFile.close();
              if(binaryData.length >= 40)
                  // init start position for reading datas
                  // start position for english version ( string "D e f a u l t" is in the preset file )
                  var startPos = 38;
                  if ( tmpStr.search ("P a r   d é f a u t") > -1 ){
                      // start position for french preset file version ( string "P a r   d é f a u t" is in the preset file ) (==> + 6 bytes)
                      startPos = 44;
                  // if your preset file can't be read, try this : open it in notepad to see the string "D e f a u l t" in your language and add the code here to set startPos to 38 + diff between the length of ("D e f a u l t") and length of ("D e f a u l t" in your language)
                  var curvePointCount = getUInt16(binaryData, startPos);
                  if(binaryData.length >= 104 + curvePointCount * 4)
                      var curvePointStr = "";
                      for(var i = 0; i < curvePointCount; i++)
                          curvePointStr += getUInt16(binaryData, startPos + 4 + i * 4) + "," + getUInt16(binaryData, startPos + 2 + i * 4) + ((i < curvePointCount - 1) ? "," : "");
                      hdrCurve = curvePointStr;
                      hdrStrength =  getFloat32(binaryData,8);
                      hdrRadius = getFloat32(binaryData, startPos + 10 + 5 * curvePointCount);
                      hdrExposure = getFloat32(binaryData, startPos + 34 + 5 * curvePointCount);
                      hdrSaturation = getFloat32(binaryData, startPos + 38 + 5 * curvePointCount);
                      hdrDetail = getFloat32(binaryData, startPos + 42 + 5 * curvePointCount);
                      hdrShadow = getFloat32(binaryData, startPos + 46 + 5 * curvePointCount);
                      hdrHighlights = getFloat32(binaryData, startPos + 50 + 5 * curvePointCount);
                      hdrGamma = getFloat32(binaryData, startPos + 54 + 5 * curvePointCount);
                      hdrVibrance = getFloat32(binaryData, startPos + 58 + 5 * curvePointCount);
                      hdrSmooth = getUInt16(binaryData, startPos + 62 + 5 * curvePointCount) != 0;
                  else
                      alert("Error Loading File", "Error", true);
              else
      function getUInt16(byteArray,offset)
          return byteArray[offset] * 0x100 + byteArray[offset + 1];
      function getUInt32(byteArray,offset)
          return byteArray[offset] * 0x1000000 + byteArray[offset + 1] * 0x10000 + byteArray[offset + 2] * 0x100 + byteArray[offset + 3];
      function getFloat32(byteArray,offset)
          var bytes = getUInt32(byteArray,offset);
          var sign = (bytes & 0x80000000) ? -1 : 1;
          var exponent = ((bytes >> 23) & 0xFF) - 127;
          var significand = (bytes & ~(-1 << 23));
          if (exponent == 128)
              return sign * ((significand) ? Number.NaN : Number.POSITIVE_INFINITY);
          if (exponent == -127) {
              if (significand == 0) return sign * 0.0;
              exponent = -126;
              significand /= (1 << 22);
          } else significand = (significand | (1 << 23)) / (1 << 23);
          return sign * significand * Math.pow(2, exponent);
      main();
        • 1. Re: Script Photoshop HDR
          Without showing its dialog to get input and output and settings what would the script do? The Script is using Adobe's Merge to HDR Pro  script "Merge To HDR.jsx".  Why not wriite you own front end script to  Merge to HDR Pro and not use this one? One that does not have a dialog one the just pass a list of files from a fixed input folder and the setting you want to use to Merge to HDR Pro
          His Batch scripts uses Merge to HDR Pro two ways.
          mergeToHDR.mergeFilesToHDR( selectedFiles, false, -2 );
          Basicly what you need is:
          //@includepath "/Applications/Adobe Photoshop CC 2015/Presets/Scripts/"
          //@include "Merge To HDR.jsx"
          //@show include
          Then you pass a filelist and two flags to Merge to HDR Pro
          mergeToHDR.mergeFilesToHDR = function(filelist, alignFlag, deghostFlag)
          • 2. Re: Script Photoshop HDR
            stevens29187206 Level 1
            Well!!! Thank you for your help!
            I used the same script and just adjust it to my needs.
            But I have a problem, there is file which needs to be manually set of EV (lack of EXIF information). And it blocks the process.
            It says, script error: Check number of files in source folder. Firstly, I thought it was the filter format, that there is a kind of hidden file but it wasn't. I tried it in Photoshop with Merge HDR Pro and it opens a box dialog written Set EV, so I think the problem is there. But I don't know how to override or fit it to the script. Help please! thank you very much.
            • 3. Re: Script Photoshop HDR
              I do not bracket exposures to do HDR processing.   I have no desire to create HDR images. EXIF Data does not have an EV setting. You can calculate EV from information EXIF information.  If the HDR Process needs EXIF data to calculate EV your image file need to have  metadata then.  Your script may be able to pass something to the HDR script I have no idea what the deghostFlag is about. Perhaps if you look at the code in David Milligan script you can fine out how to use the HDR script from an other script.
              • 4. Re: Script Photoshop HDR
                Ok, thanks.
                I would also know what's the code to keep the file's name without changing it.
                Like I'm bracketing it, I would like to keep the name of the first file to be merged.
                Please, help.
                • 5. Re: Script Photoshop HDR
                  As Far as I can tell from its Dialog the Merge to HDR Pro script does not save any file.  To me it look like it create a Image document with some name it generates.  I would think that name may contain name information as to what image files and open document name it processed creating the HDR image document.  Your Script passes the HDR Pro script a file list you have created the I would think that the HDR Pro script would process those images and return to your script an document which is and HDR Image.  You can save that document with any name you want. In HDR Pro dialog I see no save options.
                  In David Milligan batch script dialog I see output naming options. Your script like his script would be the script  that create the output file name.  Your script create the file list.  The script knows the name of the first file in that list. It could use that name add a suffix like_HDR for the ouput file name it will save. Danid Dialog
                  • 6. Re: Script Photoshop HDR
                    Yes, in this script we can put the output name. You said, the script knows the first name of that list, where is it please? it's what I'm looking for. And how to change the script, the variable outputFilename to get it everytime I save the brackets of 3.
                    • 7. Re: Script Photoshop HDR
                      To use HDR Pro script your script need to create a file list.  You stated you want to used the first file name. I have no idea how you created the list or what VARs you have in you script.  It is your script how should I know.  If you modified David script you need to change the save logic.  His script was a Batch script with a dialog.  You wanted no dialog.  So I assume if you modified his script your modification would not display a dialog.  His script used the dialog for output options. You would need to modify the script output logic. to do the save you want.
