4 Replies Latest reply on Jun 16, 2016 12:06 PM by steven85265304
    If Then Statement
    steven85265304
      Hello,
      I am using Adobe Acrobat XI Pro.  I have created a text field (textfield1) where the value equals textfield 2 + textfield 3).  I would like users to be able to add their own data if the values of text field 2 & 3 do not apply.
      Example:
      // Get the field values, as strings
      var s1 = getField("ReceiptLine1").valueAsString;
      var s2 = getField("Name").valueAsString;
      // Combine values, separated by a space
      event.value = s1 + " " + s2;
      else
      Value = User can add their own data
      ______________
      I hope this makes sense.  Any help would be appreciated.
      Thank you.
        • 1. Re: If Then Statement
          George_Johnson MVP & Adobe Community Professional
          What do you mean by "if the values of text field 2 and 3 do not apply", exactly? Do you mean if either or both are blank, or something else?
          • 2. Re: If Then Statement
            steven85265304 Level 1
            Sorry, I meant that it could be something else if needed.
            • 3. Re: If Then Statement
              One thing you can do is revise the script to the following:
              // Custom calculation script
              (function () {
                  // Get references to the input fields
                  var f1 = getField("ReceiptLine1");
                  var f2 = getField("Name");
                  // Set this field value if either input field changes
                  if (event.source === f1 || event.source === f2) {
                      event.value = f1.valueAsString + " " + f2.valueAsString;
              The user will then be able to enter a custom entry, but it will get overwritten if either of the input field values are changed. The other way to do this is with scripts in the validate events of the input fields. They would get the value of the other input field, create the string, and set the value of the third field to the string. Somehting like:
              // Custom Validate script for ReceiptLine1 field
              (function () {
                  // Get the other field value
                  var s1 = getField("Name").valueAsString;
                  // Set the other field value
                  getField("textfield1").value = event.value + " " + s1;
              The validate script for the Name field would be similar.
              • 4. Re: If Then Statement
                Awesome!! It worked perfectly.  Thank you very much
                Steve
