2 Replies Latest reply on Jun 20, 2016 2:47 AM by mechaichezilla
    TextFrame text mixed up on overflow
    mechaichezilla
      I'm filling some lines of text into a textframe, this works fine as long as it fits inside the frame, but as soon as the text overflows, all new lines are inserted in their reverse order.
      for( iLine = 0; iLine < myLines.length; iLine ++) {
           myTextFrame.insertionPoints.lastItem().contents = '\n\n' + myLines[iLine];
      As an example, if the first two lines fit and the other two overflow, the result looks like:
      Line one
      Line two
      Line four
      Line three
      I already tried this solution:
      https://forums.adobe.com/message/2536811
      This works as long as I only add single lines, but as soon as I add longer text, it falls back to the original problem.
      The other solution I tried was:
      myTextFrame.fit(FitOptions.FRAME_TO_CONTENT);
      That shrinked the textFrame to the size of the first line though and only grew vertically from now on. So I added this:
      if( myTextFrame.overflows) {
      This helped a little so the horizontal size only shrinks to the largest line that's been added so far. I am currently considering just using a table instead of a textFrame and add new lines as new rows. Any better ideas?
      Thanks a lot!
        • 1. Re: TextFrame text mixed up on overflow
          Jump_Over Level 5
          mechaichezilla napisał(-a):
          1. for(iLine=0;iLine<myLines.length;iLine++){
          2. myTextFrame.insertionPoints.lastItem().contents='\n\n'+myLines[iLine];
          3. }
          myTextFrame.insertionPoints.lastItem() --> exactly means the last insertionPoint is shown (can be reached by user) in this textFrame.
          If your goal is to add some text to the end of story (regardles is shown or hidden) use textFrame.parentStory as a target
          Like:
          myTextFrame.parentStory.insertionPoints.lastItem().contents='\n\n'+myLines[iLine];
          Jarek
          • 2. Re: TextFrame text mixed up on overflow
            mechaichezilla Level 1
            Ah, that explains it. And using parentStroy worked as I intended it to, thanks!
