2 Replies Latest reply on Jun 18, 2016 5:26 AM by K.Daube
    How to update an array of objects ?
    K.Daube Level 2
      Dear friends,
      I have a number of objects stored in an array.
      It seems that the array does not point to the objects, but has copies of them.
      The item in the array is only updated with array[index].prop notation, not with the object.prop notation.
      It would be possible to always use the array[index].prop notation for an update of items, but I want to understand, why the other method does not work. And of course there should be no copies...
      var objArray = [oObject0, oObject1, oObject2];
      function oObjTpl (name, scheme, start, incr, current, decimals, items) { // 'prototype' definition
        this.Name =       name;
        this.Scheme =     scheme;                       // numermic | roman | ROMAN | text
        this.Start =      start;                        // start value
        this.Incr =       incr;                         // increment, may be a formula string
        this.Current =    current;                      // Last inserted value or item
        this.Decimals =   decimals;                     // relevant only for numeric scheme
        this.Items =      items;                        // array of list items, relevant only for text scheme
      var items0 = ["one","two", "three", "four", "five", "six", "zz", "seven", "eight", "nine", "ten"];
      var oObject0 = new oObjTpl ('CountingEN', 'text',     1,  1, undefined, undefined, items0);
      var oObject1 = new oObjTpl ('oObject1',  'numeric', 17, -1, undefined,         0, undefined);
      var oObject2 = new oObjTpl ('oObject2',  'roman',    1,  1, undefined,         0, undefined);
      // replace the zz by soemething else
      oObject0.Items[6] = "AAAA";       // this does not update objArray
      $.writeln (objArray[0].Items);
      objArray[0].Items[6] = "BBBB";    // this updates objArray
      oObject0.Items[6] = "CCCC";       // update of objArray effective in next run
      When running the script 3 times I get this console output:
      one,two,three,four,five,six,zz,seven,eight,nine,ten
      one,two,three,four,five,six,BBBB,seven,eight,nine,ten
      Result: undefined
      one,two,three,four,five,six,CCCC,seven,eight,nine,ten
      Result: undefined
      Result: undefined
        • 1. Re: How to update an array of objects ?
          Apollo102
          try in function oObjTpl "return this" in the end.
          Regards
          Apollo
          • 2. Re: How to update an array of objects ?
            K.Daube Level 2
            Thanks Apollo, but this did not do the trick.
            But I have found that the order of definitions is crucial here. The following works as intended:
            function oSeries (name, scheme, start, incr, current, decimals, items) { // 'prototype' definition
              this.Name =       name;
            //return this;      // ahs no effect
            var oSeries_0 = new oSeries ('CountingEN', 'text',     1,  1, undefined, undefined, items0);
            var oSeries_1 = new oSeries ('oSeries_1',  'numeric', 17, -1, undefined,         0, undefined);
            var oSeries_2 = new oSeries ('oSeries_2',  'roman',    1,  1, undefined,         0, undefined);
            var aSeries = [oSeries_0, oSeries_1, oSeries_2];
            var a1 = aSeries[2].Scheme;      // roman
            $.writeln (a1);
            // replace the zz by octogon
            oSeries_0.Items[6] = "AAAA";   // this does not update aSeries
            $.writeln (aSeries[0].Items);
            aSeries[0].Items[6] = "BBBB";  // this updates aSeries
            oSeries_0.Items[6] = "CCCC";   // update of aSeries effective in next run
            one,two,three,four,five,six,AAAA,seven,eight,nine,ten
            The order now is: set up the objects and then set up the array of objects.
