4 Replies Latest reply on Jun 17, 2016 9:20 AM by Karl Heinz Kremer
    Pdf to Text
    thais781
      Hi all,
      I am using the X version of Acrobat with pleasure.
      When I open a pdf document , I can save it as txt format in using "File / save as / other options / Text" and it is ok.
      Is there a way to do the same thing without openning the document (script shell, applescript, javascript ......) ?
      I tried the script "pdftotxt", but it do not respect the column selection in the page ....
      Thanks by advance
      Thais
        • 1. Re: Pdf to Text
          There are various ways of doing it, but since none of them involve Acrobat this is not really the place to discuss them.
          • 2. Re: Pdf to Text
            Karl Heinz Kremer Adobe Community Professional
            You don't say what environment you are using, but you are mentioning AppleScript, so I assume you are on a Mac and we can forget about VB on a Windows machine.
            Adobe Acrobat allows you to remote control it via the IAC (Interapplication Communication) API. This allows you to run certain functions from outside of the application. Take a look at the "save" method here:
            Acrobat DC SDK Documentation - save
            You can then write an AppleScript to save the currently open document to a filename as text using this script:
            tell application "Adobe Acrobat"
              activate
              save document 1 to file "Macintosh HD:Users:username:directory:conversion.txt" using conversion "com.adobe.acrobat.plain-text"
            eend tell
            You can also run any JavaScript using AppleScript via the "do script" event: Acrobat DC SDK Documentation - do script
            • 3. Re: Pdf to Text
              thais781 Level 1
              Hi all,
              Thanks for your help.
              I am effectively using Mac Os environment
              I already use the save command of Applescript but for it, we need to open the document with Acrobat
              For this operation, I do not need (and I don't want) to open it.
              I am just trying to know if Adobe allow this operation without opening the document ... perhaps I have to take a look to the Acrobat SDK ....
              Thais
              • 4. Re: Pdf to Text
                You cannot develop for or with Adobe Acrobat without using the SDK.
                The Acrobat SDK is not a tool to create a solution without running Acrobat. Anything you do with the SDK relies on Adobe Acrobat and therefore a document will be opened in Acrobat. At least on the Windows side, there are ways to open a document in the background so that it does not get displayed in Acrobat, but you cannot use the SDK without actually having Acrobat open.
                If you are thinking of creating a server or server-like solution (without anybody sitting in front of the computer), then you are not using the right tool: Acrobat is not licensed, nor technically feasible for such a solution.
