3 Replies Latest reply on Jun 18, 2016 11:33 AM by e-Cottage
    Using Write on with a moving background
    e-Cottage
      Is it possible to tie the start and finish of a write on stroke to positions on vector background that is being moved and rescaled at various keyframes.  For example, if you draw a line between two points on a map where the map position and scale is different at the two keyframes the write on tool does not anchor the start position to the original position on the map.  Is there a way to tie the coordinates of the start position to the coordinates of the underlie map rather than the screen position at timeline position that you keyframe the start of the write on.  thanks.
