11 Replies Latest reply on Oct 20, 2016 11:27 AM by geordiem74078114
    Does a PP Project have XMP data?
    geordiem74078114 Level 1
      Hi all, can a Premiere Pro Project have XMP data?  I know clips can have data, but I want to store data globally for the project, not tied to a specific clip or bin.  I need to be able to blast all clips/bins from a project but still retain XMP data.
      I found this thread but it wasn't much help:
      Re: Storing data in Premiere Project
      I saw in the DOM there's a "app.project.rootItem" which is of type ProjectItem.
      I also saw the code in Premiere.jsx that reads/writes XMP data to ProjectItems and tried this on the root item, but with no luck.
      Any help would be greatly appreciated.
      TNKS!
      G
        • 1. Re: Does a PP Project have XMP data?
          Bruce Bullis Adobe Employee
          XMP is associated with project items, not with the project itself.
          What sort of XMP metadata would make sense, without being attached to actual data?
          • 2. Re: Does a PP Project have XMP data?
            Thanks for clarifying Bruce!
            I'm writing a Panel extension that can sync an OS folder structure to bins and clips and visa versa.  I need a place to globally store a user selectable base folder path (might even have multiple base paths).  I think I'll just auto generate a sequence to store global values on.
            • 3. Re: Does a PP Project have XMP data?
              1. That might work,
              2. That's some scary user experience.
              Why not store those as data, private to your panel, associated with that project?
              Save a list of correspondences in a .txt file somewhere (the PPro prefs dir is available via API; seems like a likely location); something like:
              OSFolder /Users/username/work_projects/ProjectXYZ_ingest  = /Users/username/Documents/Adobe/projectname.prproj:ProjectXYZ_ingest
              Your panel could sniff the current project path, check that .txt file for correspondences, then sync. Get the bin's 'context in project', from projectItem.treePath, to avoid dupe bin name problems.
              Potentially of interest: There's a 'hidden' pref tucked away in the Media Browser's 'hamburger menu' (three horizontal bars next to the name 'Media Browser'): 'Allow Duplicate Media During Project Import'. Turn this OFF, to ensure that users only ever get one copy of referenced footage.
              In a forthcoming release you should be able to add a property (with value) to the project metadata schema, but I'd start with the proposal above.
              • 4. Re: Does a PP Project have XMP data?
                Haha yes it could be scary   But we're planning on adding lots of smarts to address to problems of duplicate clips etc.  I'll look into the txt file solution as well.
                Thanks again!
                Geordie
                • 5. Re: Does a PP Project have XMP data?
                  OK more investigations, is it possible to set/get XMP data on a Bin?
                  I've noticed the only metadata fields that are editable for bins are "Comment" and "Client" in the Clip section.
                  Which XML schema do I use to access the clip data?
                  I'm using the mungeXMP function as inspiration to write this:
                   getProjectData: function()
                          if (ExternalObject.AdobeXMPScript == undefined)
                               ExternalObject.AdobeXMPScript = new ExternalObject('lib:AdobeXMPScript');
                          var numItems = app.project.rootItem.children.numItems;
                          var currentItem;
                          var dataItem;
                          for (var i = 0; i < numItems; i++)
                              currentItem = app.project.rootItem.children[i];
                              alert(currentItem.name);
                              if(currentItem.name == "__DATA_DO_NOT_DELETE__")
                                   alert("found");
                                  dataItem = currentItem;
                                  break;
                          if(dataItem === undefined)
                              //dataItem = app.project.createNewSequence( "__DATA_DO_NOT_DELETE__", $._ext.generateUUID());
                              dataItem = app.project.rootItem.createBin("__DATA_DO_NOT_DELETE__");
                          var xmp_blob = dataItem.getXMPMetadata();
                          var xmp = new XMPMeta(xmp_blob);
                          xmp.setProperty(XMPConst.NS_DM, "Comment", "{'test':'testVal'}");
                          var xmpAsString = xmp.serialize(); // either way, serialize and write XMP.
                          dataItem.setXMPMetadata(xmpAsString);
                          return(dataItem);
                          // var xmp_blob = dataItem.getXMPMetadata();
                  It runs but doesn't do anything.  I'm assuming XMPConst.NS_DM is the wrong schema.
                  Also, running this from the Extendscript Toolkit:
                  var xmpData = app.project.rootItem.children[0].getXMPMetadata();
                  $.writeln(xmpData);
                  Doesn't return any XMP data. (I confirmed my bin was child 0)
                  • 6. Re: Does a PP Project have XMP data?
                    As your testing showed, no. This makes sense, in PPro's model; XMP lives with the asset, and there is no asset 'behind' that bin.
                    • 7. Re: Does a PP Project have XMP data?
                      Thanks again, I'll begrudgingly store my project data in a sidecar file
                      For clarity:
                      Is Clip metadata not accessible at all though code (on any kind of asset) or is this more to do with assets that don't have a referenced file?
                      Clip metadata is not XMP data?
                      • 8. Re: Does a PP Project have XMP data?
                        When you say 'clip', my internal PPro translator substitutes 'clip within a timeline'. I think you mean media, a.k.a. projectItems, right?
                        In PPro, metadata travels with the media with which it's associated; in the API, that means projectItems, including media and sequences. As you've found, for bins, there's no "there" there; there's nowhere outside the .prproj for PPro to store asset-associated metadata (I'm 70% sure you'll find the same is true for Bars&Tone, Universal Counting Leader, and other synthetic importers).
                        For projectItems associated with actual media, panels can TOTALLY get and set both the XMP metadata, and PPro's private project metadata; see example in PProPanel.
                        Oh yeah, updated PProPanel sample forthcoming, including the capability to get the projectItem associated with a clip in a timeline.
                        • 9. Re: Does a PP Project have XMP data?
                          So in the metadata panel there's "Clip" and "File" sections.  I was referring to the "Clip" section above which would be linked to a Project Item.
                          Is the "Clip" section PPro's internal metadata and the "File" section the XMP data?
                          I can set the Clip -> Comment and Clip -> Client sections for Bins, and just did a test and can set the other text properties for a "Black Video" project item.  I've also saved the project and restarted PPro and the "Clip" metadata is still present for a Bin.
                          Is there an example of setting Clip -> Comment or Clip -> Client for a Bin or something similar with extendscript?
                          Thanks again Bruce for your Help
                          • 10. Re: Does a PP Project have XMP data?
                            Exactly!
                            Yes. From PProPanel:
                            modifyProjectMetadata : function () {
                            var kPProPrivateProjectMetadataURI = "http://ns.adobe.com/premierePrivateProjectMetaData/1.0/";
                            var namefield = "Column.Intrinsic.Name";
                            var tapename  = "Column.Intrinsic.TapeName";
                            var desc      = "Column.PropertyText.Description";
                            var newField  = "ExampleFieldName";
                            if (app.isDocumentOpen()) {
                            var projectItem = app.project.rootItem.children[0]; // just grabs first projectItem.
                            if (projectItem) {
                            if (ExternalObject.AdobeXMPScript === undefined) {
                            if (ExternalObject.AdobeXMPScript !== undefined) {// safety-conscious!
                            var projectMetadata = projectItem.getProjectMetadata();
                            var successfullyAdded = app.project.addPropertyToProjectMetadataSchema(newField, "ExampleFieldLabel",  2);
                            var xmp = new XMPMeta(projectMetadata);
                            var obj = xmp.dumpObject();
                            // var aliases = xmp.dumpAliases();
                            var namespaces = XMPMeta.dumpNamespaces();
                            var found_name      = xmp.doesPropertyExist(kPProPrivateProjectMetadataURI, namefield);
                            var found_tapename  = xmp.doesPropertyExist(kPProPrivateProjectMetadataURI, tapename);
                            var found_desc      = xmp.doesPropertyExist(kPProPrivateProjectMetadataURI, desc);
                            var found_custom = xmp.doesPropertyExist(kPProPrivateProjectMetadataURI, newField);
                            xmp.setProperty(kPProPrivateProjectMetadataURI, tapename,"***TAPENAME***");
                            xmp.setProperty(kPProPrivateProjectMetadataURI, desc,"***DESCRIPTION***");
                            xmp.setProperty(kPProPrivateProjectMetadataURI, namefield,"***NEWNAME***");
                            xmp.setProperty(kPProPrivateProjectMetadataURI, newField, "PProPanel set this, using addPropertyToProjectMetadataSchema().");
                            var str = xmp.serialize();
                            var array = new Array();
                            array[0] = tapename;
                            array[1] = desc;
                            array[2] = namefield;
                            array[3] = newField;
                            projectItem.setProjectMetadata(str, array);
                            // test: is it in there?
                            var newblob= projectItem.getProjectMetadata();
                            var newXMP= new XMPMeta(newblob);
                            var foundYet= newXMP.doesPropertyExist(kPProPrivateProjectMetadataURI, newField);
                            if (foundYet){
                            alert("PProPanel successfully added a field to the project metadata schema, and set a value for it.");
                            • 11. Re: Does a PP Project have XMP data?
                              Resurrecting this thread for future travelers.  Got a set and get metadata function working.  Thanks again for the help Bruce
                              // metadata format: [["fieldName", "fieldLabel", "PropValue"]]
                              // This is to get around eronious property names added at object level.
                              function setMetadata(projectItem, metadata)
                                          //var projectItem =  app.project.activeSequence.projectItem;
                                          if (projectItem)
                                                   // Adding new properties to schema
                                                   for(var pc =0; pc < metadata.length; pc++)
                                                       var successfullyAdded = app.project.addPropertyToProjectMetadataSchema(metadata[pc][0], metadata[pc][1],  2);
                                                    var array = [];
                                                        xmp.setProperty(kPProPrivateProjectMetadataURI, metadata[pc][0], metadata[pc][2]);
                                                        array.push(metadata[pc][0]);
                              // fieldNames = array of fieldnames
                              function getMetadata(projectItem, fieldNames)
                                       if (projectItem)
                                                   var retArray = []
                                                    for(var pc =0; pc < fieldNames.length; pc++)
                                                        if(xmp.doesPropertyExist(kPProPrivateProjectMetadataURI, fieldNames[pc]))
                                                              retArray.push([fieldNames[pc], xmp.getProperty(kPProPrivateProjectMetadataURI, fieldNames[pc])])
                                                     return(retArray);
                                  return(false);
                              // Test Code
                              var testObj = {};
                              testObj.propA = "test2";
                              testObj.propB = [4,2,3,2000];
                              setMetadata(projectItem, [["myCustomPropName", "myCustomPropLabel", JSON.stringify(testObj)]]); // value doesnt need to be JSON, just using as example
                              getMetadata(projectItem, ["myCustomPropName"]);
