0 Replies Latest reply on Mar 18, 2009 10:25 PM by lurker28
    Memory Leak in .swf
    lurker28
      Memory Leak issue with CS4
      Using CS4, we have a memory leak and I can not find the source of the problem.
      http://tiny.cc/O7D3e here is the link to the testing site. If you take a look at your task manager you will see it your RAM will continue to increase even after two or three cycles. It does not stabilize.
      We are using FlashEff | Flash Effects Component in order to generate the smooth transitions. However, I have done some debugging and even completely deleted the plug n from the file and it still continually leaks memory. Does anyone have any possible solutions or causes for this.
