6 Replies Latest reply on Jun 22, 2016 12:24 AM by jabroy
    LR CC and GPS
    jabroy
      Hi
      Why does not LRCC pick the GPS coordinates of my pictures? I tried: LR5 makes it!
        • 1. Re: LR CC and GPS
          Mohit Goyal Adobe Employee (Admin)
          Hi jabroy,
          Is this started happening after the Lightroom CC 2015.6 update..?
          Regards,
          Mohit
          • 2. Re: LR CC and GPS
            jabroy Level 1
            Thanks, Mohit Goyal
            I noticed this bad situation, when I had uppdated LR6 -> LRCC. About a month ago.
            Jari
            • 3. Re: LR CC and GPS
              dj_paige Level 9
              jabroy wrote:
              Hi
              Exactly what does this mean? Describe the problem in detail. Describe the exact steps you are following. Describe what happens in detail. Show us screen captures.
              • 4. Re: LR CC and GPS
                jabroy Level 1
                Hi, dj-paige
                I have pictures with GPS coordinates (Nikon 810 and Nikon GP-1) in their metadata. But after importing them with LRCC, the GPS field of every pictures metadata is empty. This does not happen using LR5.
                Jari
                • 5. Re: LR CC and GPS
                  johnrellis Most Valuable Participant
                  [View this post in a Web browser to see its images]
                  Make sure you don't have an import metadata preset that's clearing the GPS fields.  In the right column of the Import window, make sure Apply During Import > Metadata is set to None and try doing a test import.  If that fixes the problem, then you've been using a metadata import preset that clears the GPS data -- edit the preset and uncheck the corresponding boxes.
                  • 6. Re: LR CC and GPS
                    jabroy Level 1
                    Thanks johnrellis!
                    I made test - and it´s true: big solutions are simple. I have not noticed that little thing.
                    Jari Pyy
