5 Replies Latest reply on Apr 25, 2006 11:37 AM by dempster
    adding multiple row and column data with a form
    muellertj
      I need to add multiple row and column data to a database using an online form and am not sure what the best method of data entry and inserting would be.
      The data should look like this:
      COLUMN1 COLUMN2
      var1 var1
      var2 var2
      var3 var3
      etc.......
      When creating the form should I have individual text fields for every var or would it be better to have a text field where they list the data. I'm just not sure where to start.
      Any advice would be great.
        • 1. Re: adding multiple row and column data with a form
          Dan Bracuk Level 5
          Individual text fields for every var is the way I would do it.
          • 2. Re: adding multiple row and column data with a form
            muellertj Level 1
            I don't think I was clear in my original explanation. I need all the variables in Column 1 to go into the same column in the database and of the variables in Column 2 to go into another column in the database. If I create a unique text field for each variable won't they each need their own column in the database? I need them to be inserted into one column, and the variables in Column 1 correspond to the variables in Column 2. I know I need to do a cfloop statement, but I need a little more guideance on how to set up the form.
            • 3. Re: adding multiple row and column data with a form
              Dan Bracuk Level 5
              Regarding:
              No.
              As long as you know the name of the form field and what you are supposed to do with it, write your code accordingly.
              • 4. adding multiple row and column data with a form
                dempster Level 1
                So the different columns are grouped with rows?
                • 5. Re: adding multiple row and column data with a form
                  dempster Level 1
                  You can use row numbers in your field names to associate the columns with a particular record. For example, let's say you want 5 rows to enter last names and first names:
                  <CFSET maxrow = 5>
                  <CFLOOP INDEX="rownum" FROM="1" TO="#maxrow#"><CFOUTPUT>
                  Last name: <INPUT TYPE="text" NAME="lname#rownum#" SIZE="25">
                  First name: <INPUT TYPE="text" NAME="fname#rownum#" SIZE="15"><BR>
                  </CFOUTPUT></CFLOOP>
                  This will give you a series of fields such as lname1, fname1, lname2, fname2, etc.
                  In your form, you can also include a hidden field to indicate the number of rows.
                  When you process the form, you loop again to insert each row:
                  <CFLOOP INDEX="onerow" FROM="1" TO="#Form.numrows#">
                  <CFQUERY NAME="addRec" DATASOURCE="mydsn">
                  INSERT INTO mytable (lastname, firstname)
                  VALUES ('#Form["lname" & onerow]#)', '#Form["fname" & onerow]#')
                  </CFQUERY>
                  </CFLOOP>
