• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Command line installation of ColdFusion 11 hotfix 9 fails
Explorer ,
Jun 20, 2016 Jun 20, 2016
When I run the hotfix from the command line using this statement:
D:\ColdFusion11\jre\bin\java.exe -jar D:\ColdFusion11\cfusion\hf-updates\hotfix_009.jar -i silent -f D:\ColdFusion11\cfusion\hf-updates\my-server-name.profile
I get the following error:
Error: Could not find or load main class D:\ColdFusion11\cfusion\hf-updates\hotfix_009.jar
I also seems to be ignoring the profiles option, because I see the following new folders in the C:\ drive.
C:\ColdFusion11
C:\hf-updates
C:\hf-11-00009
Is the hotfix 9 broken, or is it just me?
[This messages was edited, I removed the extraneous information.]
Views
758
Translate
Translate
Report
Report
Community guidelines
community guidelines
Explorer , Jun 24, 2016 Jun 24, 2016
My my-server-name.profile document was corrupted causing a problem during installation.  Using a corrected .profile resolved the issue.
INSTALLER_UI=SILENT
USER_INSTALL_DIR=D:/ColdFusion11
DOC_ROOT=D:/ColdFusion11/cfusion/wwwroot
#The following applies only to multi server scenarios.
INSTANCE_LIST=cfusion
Votes
Translate
Translate
LEGEND ,
There are some users who maintain that running hotfixes from an elevated command prompt is the best way to do it.  (Which makes me ask - did you run from an ELEVATED prompt?  You can't do it from a standard user account, unless that account is in the Administrator group.)
I will always run the hotfixes from within CFAdmin, unless my CFAdmin is hosed.  This is especially important if you have moved your CFIDE to another location, outside of the webserver root.  When the hotfixes are run from within CFAdmin, it is the CF instance that is performing the update, and it knows where all the files are located.  When you execute a .jar from from a command prompt, unless you keep the default configuration, the .jar files assume the default locations and place the updated files, there.
If you have any way of rolling back what you did, and if you moved your CFIDE location to outside the webserver root, roll it back and perform the hotfix from within CFAdmin.
HTH,
^_^
Votes
Translate
Translate
Report
Report
Explorer ,
LATEST
INSTALLER_UI=SILENT
Votes
Translate
Translate
Report
Report
Resources
Documentation
