4 Replies Latest reply on Jun 21, 2016 9:59 AM by mikeCoder
    Running ExtendScript Toolkit in command line - Trusted location message
    mikeCoder
      I am running the following in a Windows 7 command line:
      "C:\Program Files (x86)\Adobe\Adobe ExtendScript Toolkit CC\ExtendScript Toolkit.exe" -run "C:\Users\john\AppData\Roaming\Adobe\InDesign\Version 11.0\en_US\Scripts\Scripts Panel\example.jsx"
      However, I get the message "You are about to run a script in Adobe InDesign CC 2015. You should only run scripts from a trusted source. Do you want to run the script", with yes/no options.
      I was wondering if there is a way to supress this message from showing up. According to Indesign Java Script running error, this message is suppressed if the jsx script is located in a trusted location. I thought that C:\Users\john\AppData\Roaming\Adobe\InDesign\Version 11.0\en_US\Scripts\Scripts Panel is a trusted location.
