2 Replies Latest reply on Apr 24, 2006 9:48 PM by The_350Z
    array structure
    The_350Z Level 1
      I'm stillnew to array.
      So i'm trying to create a dynamic structure like this:
      this_array = new Array();
      some_values = new Array();
      some_values = param.split ( " , " )
      for ( i = 0 ; i < param.length ; i ++ ){
      this[ "values_" + i ] = param[ i ] ;
      return_values = this[ "values_" + i ]
      this_array_structure = [ some_object , return_values ]
      this_array.push( this_array_structure )
      trace ( this_array ) // returns: computer_A , usb
      the problem is that the "return_values" consists more than one variable, in this case it has 5 : " dvi , firewire , audio , video , usb "
      Somehow it only returns the last variable which is usb.
      I'm trying to make it so that it would return something like this:
      [ computer_A , dvi , firewire , audio , video , usb ]
      The reason why I want to make it dynamic because each item has a different number of properties. In this case computer_A has 5, computer_B may only have 4 and so forth.
      Any help would be greatly appreciated.
        • 1. Re: dynamic array structure
          Level 7
          > this = param ;
          Sorry but your code doesn't make any sense: you are overwritting the this
          reference in a for loop and I think you may be confusing the length
          property of strings and the length property of arrays, this just cannot
          work. Was that a copy paste of the code you are actually using?
          Anyway, since you have a string, you don't need a for loop at all, the
          method split will return an array directly. So as an example:
          var param = "dvi , firewire , audio , video , usb"
          var the_array = param.split(" , ");
          trace(the_array); // done!
          And if you need to add the content of this array to another, check out the
          method "concat".
          Best luck,
          Tim.
          • 2. array structure
            The_350Z Level 1
            Oh the real code.. is hmm maybe too confusing.. but I'll attach it anyway.
            -------I also need a suggestions here------------------------------------------------------
            So, the whole point is that I'm trying to add some properties to an object.
            For example: computer_A would have 5 properties (connectors) which is: usb, dvi, firewire, audio out and video out.
            Later I will assign a boolean value to each of these properties.. let's say:
            firewire = false;
            which mean a firewire connector is closed and not available... or
            dvi = true;
            which means the dvi connector is still available(open).
            I'm open to any suggestions even if I have to start over and leave the array method behind.
            Thank you very much
