12 Replies Latest reply on Jul 1, 2016 12:09 PM by JimMcAndrew
    Latest Indesign crashing on startup
    JimMcAndrew
      I just updated to the latest indesign and now it crashes on startup. Any ideas on how to fix this?
      Here is the error report I'm getting:
      Process:               Adobe InDesign CC 2015 [979]
      Path:                  /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
      Identifier:            com.adobe.InDesign
      Version:               11.4.0.90 (11400)
      Code Type:             X86-64 (Native)
      Parent Process:        ??? [1]
      Responsible:           Adobe InDesign CC 2015 [979]
      User ID:               501
      Date/Time:             2016-06-23 15:19:27.294 -0400
      OS Version:            Mac OS X 10.11.5 (15F34)
      Report Version:        11
      Anonymous UUID:        0A680455-6E5D-F6C7-B4F5-E8D5F3AFA1D3
      Time Awake Since Boot: 770 seconds
      System Integrity Protection: enabled
      Crashed Thread:        0  Main Thread  Dispatch queue: com.apple.main-thread
      Exception Type:        EXC_BAD_ACCESS (SIGSEGV)
      Exception Codes:       KERN_INVALID_ADDRESS at 0x0000000000000000
      Exception Note:        EXC_CORPSE_NOTIFY
      VM Regions Near 0:
          __TEXT                 0000000109f58000-0000000109f5d000 [   20K] r-x/rwx SM=COW  /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
        • 1. Re: Latest Indesign crashing on startup
          ohmnath Adobe Employee
          Hi JimMcAndrew,
          Can you please share the complete crash log?
          Regards,
          Om
          • 2. Re: Latest Indesign crashing on startup
            JimMcAndrew Level 1
            I figured this out. I went into the Adobe Indesign Cache folder in Library and deleted the saved data, find change data, and all the temp files.
            • 3. Re: Latest Indesign crashing on startup
              Hi Jim,
              Thanks for sharing the same, it will certainly help many users !
              Regards,
              Om
              • 4. Re: Latest Indesign crashing on startup
                donnyskelton
                dumb question but im using windows 10 where is the cache folder?
                • 5. Re: Latest Indesign crashing on startup
                  C:\Documents and Settings\<USER>\Local Settings\Application Data\Adobe\InDesign\<Version #>\<Language>\Caches\
                  • 6. Re: Latest Indesign crashing on startup
                    I believe you mean the "Temp" folder where your system caches are stored. You can navigate to : C:\Windows\Temp
                    You can also take a look at : http://www.howto-connect.com/clear-all-type-of-cache-on-windows-10/
                    Regards,
                    Om
                    • 7. Re: Latest Indesign crashing on startup
                      JimMcAndrew Level 1
                      So Indesign continues to crash on startup. I delete the cache folder, it works for a while, and then crashes. Here is the  error report.
                      Anyone have any ideas?
                      Process:               Adobe InDesign CC 2015 [928]
                      Responsible:           Adobe InDesign CC 2015 [928]
                      User ID:               501
                      Date/Time:             2016-07-01 12:28:56.905 -0400
                      Report Version:        11
                      Sleep/Wake UUID:       4039DF58-8B74-48B7-A7A7-43BC2B0526E3
                      Time Awake Since Boot: 2200 seconds
                      Time Since Wake:       33 seconds
                      VM Regions Near 0:
                          __TEXT                 000000010454c000-0000000104551000 [   20K] r-x/rwx SM=COW  /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
                      Global Trace Buffer (reverse chronological seconds):
                      1.482596     CFNetwork                 0x00007fff96b133cb TCP Conn 0x7fc8feb7a680 SSL Handshake DONE
                      1.680055     CFNetwork                 0x00007fff96b132a7 TCP Conn 0x7fc8feb7a680 starting SSL negotiation
                      1.680371     CFNetwork                 0x00007fff96b11c71 TCP Conn 0x7fc8feb7a680 complete. fd: 47, err: 0
                      1.680420     CFNetwork                 0x00007fff96ba054b TCP Conn 0x7fc8feb7a680 event 1. err: 0
                      1.770063     CFNetwork                 0x00007fff96b10f43 TCP Conn 0x7fc8feb7a680 started
                      1.919809     CFNetwork                 0x00007fff96b133cb TCP Conn 0x7fc8ff0c3f80 SSL Handshake DONE
                      2.269475     CFNetwork                 0x00007fff96b132a7 TCP Conn 0x7fc8ff0c3f80 starting SSL negotiation
                      2.269662     CFNetwork                 0x00007fff96b11c71 TCP Conn 0x7fc8ff0c3f80 complete. fd: 47, err: 0
                      2.269863     CFNetwork                 0x00007fff96ba054b TCP Conn 0x7fc8ff0c3f80 event 1. err: 0
                      2.392465     CFNetwork                 0x00007fff96b10f43 TCP Conn 0x7fc8ff0c3f80 started
                      2.982486     CFNetwork                 0x00007fff96b133cb TCP Conn 0x7fc8fea954d0 SSL Handshake DONE
                      3.006949     CFNetwork                 0x00007fff96b132a7 TCP Conn 0x7fc8fea954d0 starting SSL negotiation
                      3.007114     CFNetwork                 0x00007fff96b11c71 TCP Conn 0x7fc8fea954d0 complete. fd: 44, err: 0
                      3.007340     CFNetwork                 0x00007fff96ba054b TCP Conn 0x7fc8fea954d0 event 1. err: 0
                      3.008065     CFNetwork                 0x00007fff96b133cb TCP Conn 0x7fc8fee8b9d0 SSL Handshake DONE
                      3.008404     CFNetwork                 0x00007fff96b133cb TCP Conn 0x7fc8feb2b020 SSL Handshake DONE
                      3.008485     CFNetwork                 0x00007fff96b133cb TCP Conn 0x7fc8fed9cea0 SSL Handshake DONE
                      3.033050     CFNetwork                 0x00007fff96b10f43 TCP Conn 0x7fc8fea954d0 started
                      3.116822     CFNetwork                 0x00007fff96b132a7 TCP Conn 0x7fc8fed9cea0 starting SSL negotiation
                      3.116967     CFNetwork                 0x00007fff96b11c71 TCP Conn 0x7fc8fed9cea0 complete. fd: 42, err: 0
                      3.117206     CFNetwork                 0x00007fff96ba054b TCP Conn 0x7fc8fed9cea0 event 1. err: 0
                      3.131134     CFNetwork                 0x00007fff96b132a7 TCP Conn 0x7fc8fee8b9d0 starting SSL negotiation
                      3.131341     CFNetwork                 0x00007fff96b11c71 TCP Conn 0x7fc8fee8b9d0 complete. fd: 36, err: 0
                      3.131341     CFNetwork                 0x00007fff96ba054b TCP Conn 0x7fc8fee8b9d0 event 1. err: 0
                      3.138004     CFNetwork                 0x00007fff96b132a7 TCP Conn 0x7fc8feb2b020 starting SSL negotiation
                      3.138328     CFNetwork                 0x00007fff96b11c71 TCP Conn 0x7fc8feb2b020 complete. fd: 38, err: 0
                      3.138336     CFNetwork                 0x00007fff96ba054b TCP Conn 0x7fc8feb2b020 event 1. err: 0
                      3.145047     CFNetwork                 0x00007fff96b10f43 TCP Conn 0x7fc8fed9cea0 started
                      3.179459     CFNetwork                 0x00007fff96b10f43 TCP Conn 0x7fc8feb2b020 started
                      3.210076     CFNetwork                 0x00007fff96b10f43 TCP Conn 0x7fc8fee8b9d0 started
                      Thread 0 Crashed:: Main Thread  Dispatch queue: com.apple.main-thread
                      0   com.adobe.InDesign.Font Manager 0x000000011bdeac18 0x11bd8f000 + 375832
                      1   DataBaseLib.dylib             0x000000010956de79 0x109537000 + 224889
                      2   DataBaseLib.dylib             0x000000010955cccd 0x109537000 + 154829
                      3   DataBaseLib.dylib             0x00000001095689fa 0x109537000 + 203258
                      4   DataBaseLib.dylib             0x00000001095529b6 0x109537000 + 113078
                      5   DataBaseLib.dylib             0x000000010954f024 0x109537000 + 98340
                      6   DataBaseLib.dylib             0x000000010954f403 0x109537000 + 99331
                      7   com.adobe.InDesign.Asset PubLibrary 0x0000000114369b68 0x114341000 + 166760
                      8   com.adobe.InDesign.Asset PubLibrary 0x000000011436b69a 0x114341000 + 173722
                      9   com.adobe.InDesign.Asset PubLibrary 0x000000011437c9ca 0x114341000 + 244170
                      10  com.adobe.InDesign.Asset PubLibrary 0x0000000114362474 0x114341000 + 136308
                      11  com.adobe.InDesign.Asset Library Panel 0x00000001143c592f 0x1143c0000 + 22831
                      12  ObjectModelLib.dylib           0x00000001095bfa18 0x1095b7000 + 35352
                      13  ObjectModelLib.dylib           0x00000001095b984a 0x1095b7000 + 10314
                      14  PublicLib.dylib               0x0000000105a3e74f MultiControllingUnknown::~MultiControllingUnknown() + 79
                      15  ObjectModelLib.dylib           0x00000001095fe8e3 0x1095b7000 + 293091
                      16  ObjectModelLib.dylib           0x00000001095feaea 0x1095b7000 + 293610
                      17  DataBaseLib.dylib             0x000000010954389d 0x109537000 + 51357
                      18  DataBaseLib.dylib             0x000000010953c999 0x109537000 + 22937
                      19  ObjectModelLib.dylib           0x00000001095feacb 0x1095b7000 + 293579
                      20  com.adobe.InDesign.Asset Library Panel 0x00000001143d9d88 0x1143c0000 + 105864
                      21  com.adobe.InDesign.Asset Library Panel 0x00000001143d9a0a 0x1143c0000 + 104970
                      22  ObjectModelLib.dylib           0x00000001095f2324 0x1095b7000 + 242468
                      23  ObjectModelLib.dylib           0x00000001095febc1 0x1095b7000 + 293825
                      24  DataBaseLib.dylib             0x000000010953c5c3 0x109537000 + 21955
                      25  com.adobe.InDesign.Asset Library Panel 0x00000001143d9950 0x1143c0000 + 104784
                      26  com.adobe.InDesign.Asset Library Panel 0x00000001143de9cf 0x1143c0000 + 125391
                      27  com.adobe.InDesign.AppFramework 0x000000010f8df8cd 0x10f881000 + 387277
                      28  ObjectModelLib.dylib           0x00000001095eb48e 0x1095b7000 + 214158
                      29  ObjectModelLib.dylib           0x00000001095fe65b 0x1095b7000 + 292443
                      30  ObjectModelLib.dylib           0x00000001095f9a9f ShuksanInit(IStartupScreen* (*)(), IPlugIn*) + 6703
                      31  com.adobe.InDesign             0x000000010454d5ce main + 94
                      32  libdyld.dylib                 0x00007fff865d25ad start + 1
                      Thread 1:
                      0   libsystem_kernel.dylib         0x00007fff8a0625e2 __workq_kernreturn + 10
                      1   libsystem_pthread.dylib       0x00007fff91dbc578 _pthread_wqthread + 1283
                      2   libsystem_pthread.dylib       0x00007fff91dba341 start_wqthread + 13
                      Thread 2:: Dispatch queue: com.apple.libdispatch-manager
                      0   libsystem_kernel.dylib         0x00007fff8a062efa kevent_qos + 10
                      1   libdispatch.dylib             0x00007fff97243165 _dispatch_mgr_invoke + 216
                      2   libdispatch.dylib             0x00007fff97242dcd _dispatch_mgr_thread + 52
                      Thread 3:
                      Thread 4:: com.apple.CFSocket.private
                      0   libsystem_kernel.dylib         0x00007fff8a06207a __select + 10
                      1   com.apple.CoreFoundation       0x00007fff906fd4fa __CFSocketManager + 762
                      2   libsystem_pthread.dylib       0x00007fff91dbc99d _pthread_body + 131
                      3   libsystem_pthread.dylib       0x00007fff91dbc91a _pthread_start + 168
                      4   libsystem_pthread.dylib       0x00007fff91dba351 thread_start + 13
                      Thread 5:: IPCClient rcvr: FMClient.501.928.140735162785792.1
                      1   com.extensis.FontManagement.plugin-interface 0x000000011495db16 GIPCReceiver::OSWaitForData() + 2846
                      2   com.extensis.FontManagement.plugin-interface 0x000000011495260a GIPCClient::ReceiverThreadProc(GThread*) + 798
                      3   com.extensis.FontManagement.plugin-interface 0x0000000114972e1b GThread::PthreadInternal(void*) + 223
                      4   libsystem_pthread.dylib       0x00007fff91dbc99d _pthread_body + 131
                      5   libsystem_pthread.dylib       0x00007fff91dbc91a _pthread_start + 168
                      6   libsystem_pthread.dylib       0x00007fff91dba351 thread_start + 13
                      Thread 6:: Agent IF Message Handler
                      0   libsystem_kernel.dylib         0x00007fff8a061db6 __psynch_cvwait + 10
                      1   libsystem_pthread.dylib       0x00007fff91dbd728 _pthread_cond_wait + 767
                      2   com.extensis.FontManagement.plugin-interface 0x000000011496cacc GSemaphore::TimedWait(unsigned int) + 76
                      3   com.extensis.FontManagement.plugin-interface 0x0000000114956dd3 GIPCClient::GIPCMTDataAccumulator::WaitForData(unsigned int, std::vector<char, std::allocator<char> >&, bool) + 37
                      4   com.extensis.FontManagement.plugin-interface 0x0000000114e5b079 GAgentIFMessageHandlerThread::RunMessageHandlerThread() + 445
                      5   com.extensis.FontManagement.plugin-interface 0x0000000114e5b796 GAgentIFMessageHandlerThread::AgentIFMessageHandlerThreadFunc(GThread*) + 42
                      6   com.extensis.FontManagement.plugin-interface 0x0000000114972e1b GThread::PthreadInternal(void*) + 223
                      7   libsystem_pthread.dylib       0x00007fff91dbc99d _pthread_body + 131
                      8   libsystem_pthread.dylib       0x00007fff91dbc91a _pthread_start + 168
                      9   libsystem_pthread.dylib       0x00007fff91dba351 thread_start + 13
                      Thread 7:: IPCDataHandler for rcvr: FMClient.501.928.140735162785792.1
                      1   com.extensis.FontManagement.plugin-interface 0x0000000114959e6e -[IPCDataHandler handleDataFromSocket:] + 2086
                      2   com.apple.Foundation           0x00007fff9536ae64 __NSThread__start__ + 1351
                      3   libsystem_pthread.dylib       0x00007fff91dbc99d _pthread_body + 131
                      4   libsystem_pthread.dylib       0x00007fff91dbc91a _pthread_start + 168
                      5   libsystem_pthread.dylib       0x00007fff91dba351 thread_start + 13
                      Thread 8:: com.apple.NSURLConnectionLoader
                      0   libsystem_kernel.dylib         0x00007fff8a05bf72 mach_msg_trap + 10
                      1   libsystem_kernel.dylib         0x00007fff8a05b3b3 mach_msg + 55
                      2   com.apple.CoreFoundation       0x00007fff906c01c4 __CFRunLoopServiceMachPort + 212
                      3   com.apple.CoreFoundation       0x00007fff906bf68c __CFRunLoopRun + 1356
                      4   com.apple.CoreFoundation       0x00007fff906beed8 CFRunLoopRunSpecific + 296
                      5   com.apple.CFNetwork           0x00007fff96ad8095 +[NSURLConnection(Loader) _resourceLoadLoop:] + 412
                      6   com.apple.Foundation           0x00007fff9536ae64 __NSThread__start__ + 1351
                      Thread 9:
                      Thread 10:
                      Thread 11:
                      Thread 12:
                      Thread 13:
                      Thread 14:
                      Thread 15:
                      0   libsystem_kernel.dylib         0x00007fff8a061fba __recvfrom + 10
                      1   VulcanMessage5.dylib           0x00000001095091d6 0x1094eb000 + 123350
                      2   VulcanMessage5.dylib           0x000000010950844d 0x1094eb000 + 119885
                      3   VulcanMessage5.dylib           0x0000000109507808 0x1094eb000 + 116744
                      4   VulcanMessage5.dylib           0x000000010950773e 0x1094eb000 + 116542
                      5   VulcanMessage5.dylib           0x00000001095022e8 0x1094eb000 + 94952
                      6   VulcanMessage5.dylib           0x0000000109502786 0x1094eb000 + 96134
                      7   VulcanMessage5.dylib           0x000000010950272d 0x1094eb000 + 96045
                      8   VulcanMessage5.dylib           0x00000001095065b2 0x1094eb000 + 112050
                      9   VulcanMessage5.dylib           0x00000001095062d9 0x1094eb000 + 111321
                      10  VulcanMessage5.dylib           0x0000000109505f5a 0x1094eb000 + 110426
                      11  VulcanMessage5.dylib           0x0000000109505ead 0x1094eb000 + 110253
                      12  VulcanMessage5.dylib           0x00000001094f8cb6 0x1094eb000 + 56502
                      13  VulcanMessage5.dylib           0x00000001094f976f 0x1094eb000 + 59247
                      14  VulcanMessage5.dylib           0x00000001095070d8 0x1094eb000 + 114904
                      15  VulcanMessage5.dylib           0x0000000109508bf9 0x1094eb000 + 121849
                      16  libsystem_pthread.dylib       0x00007fff91dbc99d _pthread_body + 131
                      17  libsystem_pthread.dylib       0x00007fff91dbc91a _pthread_start + 168
                      18  libsystem_pthread.dylib       0x00007fff91dba351 thread_start + 13
                      Thread 16:
                      2   com.adobe.headlights.LogSessionFramework 0x000000011227207c boost::condition_variable::do_wait_until(boost::unique_lock<boost::mutex>&, timespec const&) + 76
                      3   com.adobe.headlights.LogSessionFramework 0x000000011227093e boost::this_thread::hiden::sleep_until(timespec const&) + 78
                      4   com.adobe.headlights.LogSessionFramework 0x00000001122192d3 RealTimeProcessor::Sleep(int) + 243
                      5   com.adobe.headlights.LogSessionFramework 0x00000001122179b7 RealTimeProcessor::WorkerThread() + 2873
                      6   com.adobe.headlights.LogSessionFramework 0x000000011226f99a 0x11218b000 + 936346
                      Thread 17:
                      0   libsystem_kernel.dylib         0x00007fff8a06210a __semwait_signal + 10
                      1   libsystem_c.dylib             0x00007fff8653ad17 nanosleep + 199
                      2   PMRuntime.dylib               0x0000000105f722f6 IDThreading::Sleep(unsigned int) + 54
                      3   DataBaseLib.dylib             0x000000010957595c 0x109537000 + 256348
                      4   DataBaseLib.dylib             0x000000010956e787 0x109537000 + 227207
                      5   com.adobe.boost_threads.framework 0x000000010599894a boost::thread::start_thread_noexcept() + 426
                      Thread 0 crashed with X86 Thread State (64-bit):
                        rax: 0x000000011bdeac10  rbx: 0x00007fc8ff0f0760  rcx: 0x0000000000000000  rdx: 0x00000000000023fb
                        rdi: 0x0000000000000000  rsi: 0x0000000109634d98  rbp: 0x00007fff5b6b27e0  rsp: 0x00007fff5b6b27e0
                         r8: 0x0000000000008000   r9: 0x000000010f641000  r10: 0x0000000000007fff  r11: 0x0000000000003eed
                        r12: 0xffffffffffffffff  r13: 0x00007fc8fede3100  r14: 0x00007fc8feef0100  r15: 0x00007fc8fec90cc0
                        rip: 0x000000011bdeac18  rfl: 0x0000000000010206  cr2: 0x0000000000000000
                      Logical CPU:     4
                      Error Code:      0x00000004
                      Trap Number:     14
                      Binary Images:
                             0x10454c000 -        0x104550ffe +com.adobe.InDesign (11.4.0.90 - 11400) <2CE33748-941B-31B3-A425-F64CA01B9F35> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Adobe InDesign CC 2015
                             0x10455b000 -        0x10455bff7 +com.adobe.InDesign.InDesignModelAndUI (9.0 - 0) <FB61F9A6-DE48-3A5E-A074-B023C1686C20> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/InDesignModelAndUI.framework/Versions/A/InDesignModelAndUI
                             0x104560000 -        0x104567fff +com.adobe.coretech.adobesplashkit (AdobeSplashKit Version 1.0 - 1.0) <707D43E9-76C9-3CD0-8A2E-BAFFFC27E0CA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSplashKit.framework/Versions/A/AdobeSplashKit
                             0x104572000 -        0x10457cffd +ASLSupportLib.dylib (0) <E212D47A-07C8-31E6-A790-413B0646F302> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/ASLSupportLib.dylib
                             0x104587000 -        0x104684ff9 +DV_WidgetBinLib.dylib (0) <AB257A63-5512-36E5-8D21-63293078C75F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/DV_WidgetBinLib.dylib
                             0x1047b9000 -        0x1047f9ff3 +TextPanelLib.dylib (0) <3132D35D-6E53-3C3D-BE64-5783047E86EE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/TextPanelLib.dylib
                             0x104815000 -        0x104962ff5 +WidgetBinLib.dylib (0) <45FB390F-31A5-3FEE-92D8-FA98AA23F3F3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/WidgetBinLib.dylib
                             0x104a21000 -        0x104babff7 +com.adobe.owl (AdobeOwl version 5.2.9 - 5.2.9) <6E62006B-A021-3C39-9A8A-B8072804229F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                             0x104bf8000 -        0x104ed0ff7 +com.adobe.dvacore.framework (10.0.0 - 10.0.0.0) <ACB56524-07BD-3D35-B2AC-833B6EAE860E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                             0x104fb1000 -        0x105570ff7 +com.adobe.dvaui.framework (10.0.0 - 10.0.0.0) <FB405F75-478D-39DC-99E3-086C918BE66E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
                             0x10598d000 -        0x10598dff7 +com.adobe.InDesign.InDesignModel (9.0 - 0) <A9C36234-F5A9-30E4-8C8F-6FAD52ED3FA3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/InDesignModel.framework/Versions/A/InDesignModel
                             0x105997000 -        0x1059a6ff7 +com.adobe.boost_threads.framework (10.0.0 - 10.0.0.0) <A3D5B28D-3241-3BCF-AEF0-D0A3BE73F4F1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                             0x1059bf000 -        0x1059c0ff7 +com.adobe.boost_system.framework (10.0.0 - 10.0.0.0) <F9F8FF2C-62DF-3B25-A407-633C6E8033E9> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                             0x1059c8000 -        0x1059cdfff +com.adobe.boost_date_time.framework (10.0.0 - 10.0.0.0) <238E8E5E-DC9F-3CA4-8ED0-62E179B66B7C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                             0x1059db000 -        0x105e1aff5 +PublicLib.dylib (0) <35795B23-EB75-3880-A58D-1DEF6B78CB76> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/PublicLib.dylib
                             0x105f6b000 -        0x105f74ff7 +PMRuntime.dylib (0) <B473E542-1734-38D7-9ADA-EB0866E96E4B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/PMRuntime.dylib
                             0x105f81000 -        0x105f92fff +com.adobe.AFL (AdobeAFL 2.0.0 - 2.0) <BF9D724B-D40A-3250-8A0F-6F978D3904AA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAFL.framework/Versions/A/AdobeAFL
                             0x105fa6000 -        0x106294ffb +com.adobe.CoolType (AdobeCoolType 5.15.00.36125 - 5.15.00.36125) <C7B78AC8-5659-3CD0-9483-29F9628C0C61> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                             0x1062e4000 -        0x106300ffb +com.adobe.BIB (AdobeBIB 1.2.03.36125 - 1.2.03.36125) <28247879-8E7A-3B40-9012-FF1E849D7236> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                             0x10630a000 -        0x10630bffe +com.adobe.InDesign.Metadata Database Filter (11.4.0.90 - 0) <E4128E3B-04B9-3A72-970B-ECEC5E678197> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Metadata Database Filter.InDesignPlugin/Metadata Database Filter
                             0x106310000 -        0x106455ff3 +com.adobe.ACE (AdobeACE 2.20.02.36125 - 2.20.02.36125) <833F0706-F228-39B7-BCAF-9989A47E4D55> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                             0x106471000 -        0x106cecff7 +com.adobe.AGM (AdobeAGM 4.30.60.1 - 4.30.60.1) <97FE95F6-4572-38E0-965A-CDF2F7968413> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                             0x106dad000 -        0x106ddeffb +com.adobe.ARE (AdobeARE 1.5.02.36125 - 1.5.02.36125) <23632FFE-0B66-3458-AB4F-3E0CAAF27625> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeARE.framework/Versions/A/AdobeARE
                             0x106de9000 -        0x106e0cff3 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <B71D4C22-E568-3088-AED2-7D14B810D74A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                             0x106e15000 -        0x106e16ff6 +com.adobe.InDesign.Global Preferences Panel (11.4.0.90 - 0) <9F993B33-64F2-311A-A489-02183FB5C38F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Global Preferences Panel.InDesignPlugin/Global Preferences Panel
                             0x106e1c000 -        0x107182ffb +com.adobe.MPS (AdobeMPS 5.8.1.36043 - 5.8.1.36043) <16E2510F-2C06-3BDB-9302-8DE6D31F8D90> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                             0x1071f6000 -        0x107219fff +com.adobe.dvaflashview.framework (10.0.0 - 10.0.0.0) <76C552D5-2A29-3B70-AE0F-B6FC25F1AACB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaflashview.framework/Versions/A/dvaflashview
                             0x107237000 -        0x10723bff7 +com.adobe.ape.shim (3.4.0.29366 - 3.4.0.29366) <B9447EE8-6F91-9E85-C163-96600BF70764> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                             0x107247000 -        0x107322ff7 +com.adobe.exo.framework (10.0.0 - 10.0.0.0) <5841EF9E-0875-38AF-BDE0-573654209D61> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/exo.framework/Versions/A/exo
                             0x1073e9000 -        0x107524ff7 +com.adobe.dvaworkspace.framework (10.0.0 - 10.0.0.0) <C8C1C417-2232-3366-9EB0-2E83C6CEC3BD> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
                             0x107617000 -        0x107935fcf +com.adobe.PlugPlugOwl (6.1.0.176 - 6.1.0.176) <0DE87856-3AC9-3A51-A4C4-DC2F3D2750C8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/PlugPlugOwl.framework/Versions/A/PlugPlugOwl
                             0x10799b000 -        0x107ae9ff3 +libtypekitC4Release.dylib (0) <9F44287D-0E7F-300C-9388-098FF7355BC0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/libtypekitC4Release.dylib
                             0x107b0c000 -        0x107b3cfef +libtbb.dylib (0) <D41FA1F0-4921-308A-93DF-4D16F8913472> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/libtbb.dylib
                             0x107b5b000 -        0x107b80fff +libtbbmalloc.dylib (0) <60EF4F46-298B-38B6-A6CD-9B168072EAB7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/libtbbmalloc.dylib
                             0x107bac000 -        0x1088f1fff +com.adobe.ICUData (4.0 - 3.61) <B9864D01-126E-3C56-B04C-993F9890F6AD> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUData.framework/Versions/4.0/ICUData
                             0x108908000 -        0x108a43fff +com.adobe.ICUInternationalization (4.0 - 3.61) <CEAE369B-B601-30D5-9563-6C2AB781AF27> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUInternationalization.framework/Versions/4.0/ICUInternatio nalization
                             0x108a9b000 -        0x108b9eff7 +com.adobe.ICUUnicode (4.0 - 3.61) <CE487901-E84A-3E54-95AB-91F2EAF57F6A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUUnicode.framework/Versions/4.0/ICUUnicode
                             0x108bdb000 -        0x108d12ff7 +com.winsoft.wrservices (WRServices 11.0.0 - 11.0.0) <A1AF94EB-8B13-305C-8B8C-8E420BA0DD0A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                             0x108d76000 -        0x108e77fff +com.adobe.amtlib (9.0.0.21 - 9.0.0.21) <BAE71CEB-B622-38DB-A0A2-796C0BEB4E03> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                             0x108e90000 -        0x108e93fff +com.adobe.AdobeCrashReporter (7.3 - 7.3.2) <F09CBDBF-D0F2-3E8B-A039-EC311CD1CCA1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                             0x108ea0000 -        0x108f6cfff +com.adobe.boost_regex.framework (10.0.0 - 10.0.0.0) <4669C11B-8D91-384F-8732-A606C6B1E33E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_regex.framework/Versions/A/boost_regex
                             0x108fe9000 -        0x1090e3fff +com.adobe.adobe_caps (adobe_caps 10.0.0.5 - 10.0.0.5) <E029224F-4AD9-3054-87A7-AB5FAAD7CD1F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
                             0x1090f6000 -        0x109104fff +com.adobe.boost_filesystem.framework (10.0.0 - 10.0.0.0) <CB4D5B6B-4168-3770-BB10-51165E1BA76E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_filesystem.framework/Versions/A/boost_filesystem
                             0x109115000 -        0x109121ff7 +com.adobe.boost_signals.framework (10.0.0 - 10.0.0.0) <9954BF85-9C28-303D-A819-7A881E2C16EF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                             0x109134000 -        0x109138fff  com.apple.agl (3.3.1 - AGL-3.3.1) <4E401980-0F4F-33E2-A0CF-8C7CCF375F24> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                             0x109141000 -        0x109289ff7 +com.adobe.AIDE (1.5.0 - 1.5.0.35921) <452817DA-9C9F-3579-A2D2-F1166387B510> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AIDE.framework/Versions/A/AIDE
                             0x1092ad000 -        0x109356ff7 +com.adobe.ICUConverter (4.0 - 3.61) <E20E390A-9BAF-3454-BA16-7B9CCD4CA8F0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/ICUConverter
                             0x10937a000 -        0x109457ff7 +com.adobe.dvanet.framework (10.0.0 - 10.0.0.0) <0ED5C705-35D8-30B7-AC1D-49AC13C03597> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvanet.framework/Versions/A/dvanet
                             0x1094ba000 -        0x1094dbff7 +VulcanControl.dylib (5.2.0.50 - 5.2.0.50 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <00913D4C-517C-33E8-895A-6F6509111B19> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/VulcanControl.dylib
                             0x1094eb000 -        0x109523fff +VulcanMessage5.dylib (5.2.0.49 - 5.2.0.49 Copyright 2015, Adobe Systems Incorporated. All rights reserved.) <1D3CED35-E99B-3AAB-9C60-C6F853ED3BFB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/VulcanMessage5.dylib
                             0x109537000 -        0x10959affc +DataBaseLib.dylib (0) <FF4E20F1-11C7-33A6-849F-09FF71474601> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/DataBaseLib.dylib
                             0x1095b7000 -        0x10962dfff +ObjectModelLib.dylib (0) <1BEC7239-4AF1-31BB-AB11-83CD64425B4E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/ObjectModelLib.dylib
                             0x10964e000 -        0x10966efff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.8.0.36035 - 3.8.0.36035) <812A75FD-E9B1-3F2B-A06F-04F504220CBE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExp at
                             0x10ef2a000 -        0x10ef6aff7 +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 9.0.0.3 - 9.0.0.3) <2F5B40E6-812C-34E0-A8AC-02F55D770D49> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotificatio ns
                             0x10f881000 -        0x10fa53ff1 +com.adobe.InDesign.AppFramework (11.4.0.90 - 0) <43D53B09-D827-3AC7-B7C8-F5FB328FC85B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/AppFramework.InDesignPlugin/AppFramework
                             0x1102b3000 -        0x1102c8ff2 +com.adobe.InDesign.IME (11.4.0.90 - 0) <8D0A4901-70BA-39F3-BBE8-757BEE561A09> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/IME.InDesignPlugin/IME
                             0x1102d8000 -        0x11046bff0 +com.adobe.InDesign.Text Walker (11.4.0.90 - 0) <8E4D7CF0-5075-329D-95AE-CA16601EA48D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Walker.InDesignPlugin/Text Walker
                             0x1104bf000 -        0x110505ffc +com.adobe.InDesign.Linguistics (11.4.0.90 - 0) <484FB4C5-E090-37C4-B5C5-4BCFE04746C5> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Linguistics.InDesignPlugin/Linguistics
                             0x11051e000 -        0x110573ffc +com.adobe.InDesign.Text Panel (11.4.0.90 - 0) <0DE9B14E-643E-3785-A25B-852C74B0F6E3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Text/Text Panel.InDesignPlugin/Text Panel
                             0x110599000 -        0x1105e0ff8 +com.adobe.InDesign.Spelling Panel (11.4.0.90 - 0) <67DC1C7E-E2B3-3914-B60A-CC3851B1E824> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Text/Spelling Panel.InDesignPlugin/Spelling Panel
                             0x1105f9000 -        0x110838ff7 +com.adobe.InDesign.Package and Preflight (11.4.0.90 - 0) <58C26D79-0007-33BE-B2A7-325252937503> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Prepress/Package and Preflight.InDesignPlugin/Package and Preflight
                             0x11087c000 -        0x110a1afff +com.adobe.AdobeXMPCore (Adobe XMP Core 5.6 -c 123 - 79.158978) <809207CB-7887-390D-95EF-3002CBFA575B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                             0x110a81000 -        0x110ce3ff7 +com.adobe.InDesign.Layout UI (11.4.0.90 - 0) <217C5685-DF40-3DFA-933D-E931C2D65A1A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Layout UI.InDesignPlugin/Layout UI
                             0x110d63000 -        0x110e1fff8 +com.adobe.InDesign.Import Export UI (11.4.0.90 - 0) <451B59A6-2C8A-375A-B4D8-D960DF07DD7F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Import Export UI.InDesignPlugin/Import Export UI
                             0x110e51000 -        0x110f44ff8 +com.adobe.InDesign.Hyperlinks (11.4.0.90 - 0) <D0E5316A-3787-3FE8-9DAA-31F79851024F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Hyperlinks.InDesignPlugin/Hyperlinks
                             0x110f6e000 -        0x111007ff0 +com.adobe.InDesign.Master Page (11.4.0.90 - 0) <5A84F927-519B-3CF3-AB29-4F093E1E8AA8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Master Page.InDesignPlugin/Master Page
                             0x111021000 -        0x111105ff7 +com.adobe.InDesign.Text Editor (11.4.0.90 - 0) <AB18DD9F-95E2-3A5E-A585-0CB7EDAE8137> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Editor.InDesignPlugin/Text Editor
                             0x11113a000 -        0x11115bff4 +com.adobe.InDesign.Utilities (11.4.0.90 - 0) <F6D752E9-256C-38A0-901C-7A18910FB4D3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Utilities.InDesignPlugin/Utilities
                             0x111175000 -        0x111255fff +com.adobe.InDesign.Color Management (11.4.0.90 - 0) <5197D16E-A550-3251-B717-DC8C57AF378A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Color Management.InDesignPlugin/Color Management
                             0x1115de000 -        0x111836fef +com.adobe.InDesign.Application UI (11.4.0.90 - 0) <A6736970-5811-3F19-AE19-150BE664ADBA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Application UI.InDesignPlugin/Application UI
                             0x1118fd000 -        0x111c4ffff +com.adobe.dvaadameve.framework (10.0.0 - 10.0.0.0) <6F2651E8-88C6-3D12-8228-0CACF4606C0E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaadameve.framework/Versions/A/dvaadameve
                             0x11218b000 -        0x1122cbfff +com.adobe.headlights.LogSessionFramework (7.3.1.72) <EE72ED3F-9A64-372D-A709-67F79995E15D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                             0x11233d000 -        0x112452ff7 +com.adobe.dvametadataUI.framework (10.0.0 - 10.0.0.0) <20F4B9BF-F9C2-392A-9C20-3BE375D84E4C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
                             0x1124e2000 -        0x11258dff7 +com.adobe.AdobeExtendScript (ExtendScript 4.5.6 - 4.5.6.1) <79B05FB3-724B-3679-A9B7-E96511405E4F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                             0x1125b4000 -        0x11264ffff +com.adobe.AdobeScCore (ScCore 4.5.6 - 4.5.6.1) <B8F6ECB6-E6F8-3117-8CEF-BC00B5C924FE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                             0x112678000 -        0x1126adfff +AgoraLib.dylib (1.0.0.0) <73697218-E690-371D-9728-7883DA2051A7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AgoraLib.dylib
                             0x1126e0000 -        0x11284aff7 +com.adobe.dvascriptui.framework (7.0.6 - 7.0.6.0) <D0089811-F821-3BDC-BB1C-CCABEED7F0FE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvascriptui.framework/Versions/A/dvascriptui
                             0x112971000 -        0x112af0fff +com.adobe.AdobeXMPFiles (Adobe XMP Files 5.6 -f 180 - 79.158978) <2314BD50-A00B-395A-A5C0-B68BC46BD627> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
                             0x112b42000 -        0x112c15ff7 +com.adobe.dvametadata.framework (10.0.0 - 10.0.0.0) <89BFC84F-75E0-3B5D-BC63-2D5DEEB4553E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
                             0x112c6d000 -        0x112d2ffff +com.adobe.dvaeve.framework (10.0.0 - 10.0.0.0) <F41A9BDC-17A2-373E-A25A-F376C1861883> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
                             0x112ddd000 -        0x112e43ff7 +com.adobe.dvatemporalxmp.framework (10.0.0 - 10.0.0.0) <BBE84DF9-1102-3E14-BC7D-592D8CDAD0E3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
                             0x112e63000 -        0x112ea1fff +com.adobe.dvamediatypes.framework (10.0.0 - 10.0.0.0) <B69D3450-9AD3-3422-8799-25823EB5C08E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                             0x112ebc000 -        0x113093ff1 +com.adobe.InDesign.Document Framework (11.4.0.90 - 0) <2A83D00E-D2BF-399A-836C-C27C2009ADFE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Document Framework.InDesignPlugin/Document Framework
                             0x1133c4000 -        0x1135a5ff7 +WoodWing (v11.0.0 build 2 - v11.0.0 build 2) <91A9EFB7-8D4A-3754-9C4D-E823105C5698> /Applications/Adobe InDesign CC 2015/*/WoodWing
                             0x113816000 -        0x113864fff +libcurl.4.dylib (0) <FC1BC8D4-776E-39EE-A620-A66D36FE3C43> /Applications/Adobe InDesign CC 2015/*/libcurl.4.dylib
                             0x113873000 -        0x113c87fef +libxerces-c-3.1.dylib (0) <35A5AF83-1D7A-3F9C-8506-E522C9CDE19C> /Applications/Adobe InDesign CC 2015/*/libxerces-c-3.1.dylib
                             0x11402d000 -        0x11425fff5 +com.adobe.InDesign.Table Model (11.4.0.90 - 0) <437BA929-0795-3D6B-A7EC-C9060C8D43B0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Table Model.InDesignPlugin/Table Model
                             0x1142a2000 -        0x1142fcff7 +SmartTables (v11.0.0 build 10 - v11.0.0 build 10) <C7BE3C28-FBA4-3453-9424-3CEE9A378812> /Applications/Adobe InDesign CC 2015/*/SmartTables
                             0x114341000 -        0x1143a2ff4 +com.adobe.InDesign.Asset PubLibrary (11.4.0.90 - 0) <9D27D731-65CE-39E4-A60F-A7B3A3045EED> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Asset PubLibrary.InDesignPlugin/Asset PubLibrary
                             0x1143c0000 -        0x114407ff8 +com.adobe.InDesign.Asset Library Panel (11.4.0.90 - 0) <E3041B19-73FC-3E1F-B15B-59DB6EF96EE7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Asset Library Panel.InDesignPlugin/Asset Library Panel
                             0x11442c000 -        0x11447bff7 +WWStyling (v11.0.0 build 10 - v11.0.0 build 10) <975DE96F-6F94-3B10-96EE-B5907B6F7AD1> /Applications/Adobe InDesign CC 2015/*/WWStyling
                             0x1144bb000 -        0x1144dafff +SmartStyles (v11.0.0 build 10 - v11.0.0 build 10) <CCE4EFAD-4F08-3D1E-AE89-8E9168A5BD3F> /Applications/Adobe InDesign CC 2015/*/SmartStyles
                             0x1144f4000 -        0x114727fff +com.extensis.AutoActivationPlugin.ID10 (17.3.0.636751 - 17.3.0.636751) <038E9F78-863C-3A79-9421-3C5AFC11D219> /Applications/Adobe InDesign CC 2015/*/ExtensisFontManagementIDCC2015
                             0x1148d2000 -        0x115175fff +com.extensis.FontManagement.plugin-interface (17.3.0.636887 - 636887) <10705EF8-332E-3FC6-A9D5-CE736B1C3C11> /Applications/Suitcase Fusion 6.app/Contents/Resources/ExtensisPluginInterface.framework/ExtensisPluginInterface
                             0x115368000 -        0x1153c1ffa +com.adobe.InDesign.XMLParser (11.4.0.90 - 0) <91168CC3-32EA-3DC7-82BE-FE624A198108> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/XMLParser.InDesignPlugin/XMLParser
                             0x1153d6000 -        0x1154a1ff7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.8.0.36035 - 3.8.0.36035) <2BA7754B-B1E0-3413-A7D1-21773A59BFFD> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                             0x1154b5000 -        0x115564fff +com.adobe.AXEXSLT (AdobeAXSLE 3.8.0.36035 - 3.8.0.36035) <C4D2EBD3-F77E-3C73-B427-303BEE1ACA8B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeAXSLE.framework/Versions/A/AdobeAXSLE
                             0x115578000 -        0x11577fffd +com.adobe.InDesign.XML (11.4.0.90 - 0) <C9D1A147-1CAF-35CE-9D68-9840B32C455D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/XML.InDesignPlugin/XML
                             0x1157c8000 -        0x1157efffe +com.adobe.InDesign.WorldReady (11.4.0.90 - 0) <EEC95266-BE2B-3F83-8AB3-695206401979> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/WorldReady.InDesignPlugin/WorldReady
                             0x1157ff000 -        0x115835ff8 +com.adobe.InDesign.Workgroup (11.4.0.90 - 0) <76FB216F-F98A-3284-A5BB-FF8C74C08349> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Workgroup.InDesignPlugin/Workgroup
                             0x115844000 -        0x115862fff +com.adobe.InDesign.Workgroup Client (11.4.0.90 - 0) <353CD815-4ED8-3993-B24D-4B5621689739> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Workgroup Client.InDesignPlugin/Workgroup Client
                             0x115870000 -        0x11599eff2 +com.adobe.InDesign.Transparency (11.4.0.90 - 0) <5EF18585-71D5-3226-89F3-51F63EA82E5D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Transparency.InDesignPlugin/Transparency
                             0x1159c9000 -        0x118ff7fcf +com.adobe.psl (AdobePSL 15.1.0.36130 - 15.1.0.36130) <B609F7A3-CF08-3DB1-8F8D-526058913E60> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
                             0x1194f6000 -        0x1195b6ff7 +com.adobe.JP2K (1.2.2 - 1.2.2.36027) <92828386-6A5A-398C-B90D-989D2641F40F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                             0x1195da000 -        0x1195dcff7  com.apple.textencoding.unicode (3.0 - 3.0) <B8CEE380-5919-3519-8088-119C65562EE9> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                             0x1195e2000 -        0x11963fffa +com.adobe.InDesign.TOC (11.4.0.90 - 0) <8B7C1F79-ECD4-38F1-BCF3-B414693F0BC3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/TOC.InDesignPlugin/TOC
                             0x119653000 -        0x119c1affa +com.adobe.InDesign.Text (11.4.0.90 - 0) <D24611FF-62A1-3906-B2D5-244B228470C7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text.InDesignPlugin/Text
                             0x119cbd000 -        0x119d27ffa +com.adobe.InDesign.Text Wrap (11.4.0.90 - 0) <85FB106E-664F-388D-9A6C-7488BB268DBA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Wrap.InDesignPlugin/Text Wrap
                             0x119d40000 -        0x119d5fff3 +com.adobe.InDesign.Text Wrap Path (11.4.0.90 - 0) <540E72A2-63B4-30CE-9C31-2F70469A0E39> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Wrap Path.InDesignPlugin/Text Wrap Path
                             0x119d68000 -        0x119d7cff4 +com.adobe.InDesign.Text Editor Model (11.4.0.90 - 0) <AD4141DF-7569-30AF-A2B3-8F234242FDB3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Editor Model.InDesignPlugin/Text Editor Model
                             0x119d87000 -        0x119dcdff0 +com.adobe.InDesign.Text Attributes (11.4.0.90 - 0) <AFAAB8AA-3049-3605-B205-BAA9194DBA30> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Text Attributes.InDesignPlugin/Text Attributes
                             0x119de8000 -        0x119e40ff0 +com.adobe.InDesign.TableStyles (11.4.0.90 - 0) <E069F3BB-73BB-35E7-B598-D9EF1A0BAF11> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/TableStyles.InDesignPlugin/TableStyles
                             0x119e52000 -        0x119e9effd +com.adobe.InDesign.Image Filters (11.4.0.90 - 0) <4497F05F-8D4D-3B55-8274-B6F107928573> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Image Filters.InDesignPlugin/Image Filters
                             0x119eab000 -        0x119f29ff5 +com.adobe.InDesign.SVGExport (11.4.0.90 - 0) <660635D9-791C-3A05-9EE4-58B0ACE5ACEC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/SVGExport.InDesignPlugin/SVGExport
                             0x119f42000 -        0x11a000fff +com.adobe.SVGExport (AdobeSVGExport 6.0 - 6.0) <2FAB4B9A-EDB9-0FF9-55B2-52DEC380D2BF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSVGExport.framework/Versions/A/AdobeSVGExport
                             0x11a023000 -        0x11a0b8ffe +com.adobe.InDesign.Support for JavaScript (11.4.0.90 - 0) <99DE3F14-605D-3392-9C80-F7BBEBC20A65> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Support for JavaScript.InDesignPlugin/Support for JavaScript
                             0x11a0e1000 -        0x11a136ff0 +com.adobe.InDesign.Support for AppleScript (11.4.0.90 - 0) <C947E4E6-1E6C-3B9A-B00D-A92FECB571AF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Support for AppleScript.InDesignPlugin/Support for AppleScript
                             0x11a14c000 -        0x11a231ff8 +com.adobe.InDesign.Graphics (11.4.0.90 - 0) <C5E245A8-E728-33C0-8033-EC85E95C92D4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Graphics.InDesignPlugin/Graphics
                             0x11a254000 -        0x11a2a4ff2 +com.adobe.InDesign.Stroke and Fill (11.4.0.90 - 0) <2D4B51BF-9172-35F7-B69A-79CBF4F177E5> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Stroke and Fill.InDesignPlugin/Stroke and Fill
                             0x11a2bb000 -        0x11a3eaff6 +com.adobe.InDesign.Spread (11.4.0.90 - 0) <1762000D-B749-3B01-ACAE-028E1EBE375B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spread.InDesignPlugin/Spread
                             0x11a41b000 -        0x11a45fffe +com.adobe.InDesign.Spline (11.4.0.90 - 0) <A0A28403-3193-3F7F-ABCA-4DA457EA71FA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spline.InDesignPlugin/Spline
                             0x11a477000 -        0x11a487ff3 +com.adobe.InDesign.Spelling Service (11.4.0.90 - 0) <C1A7BBA0-F5A3-3878-A695-C6DDBC9D141F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spelling Service.InDesignPlugin/Spelling Service
                             0x11a495000 -        0x11a4a1ffc +com.adobe.InDesign.Sound (11.4.0.90 - 0) <13692150-15E0-3956-920C-67C03867A151> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Sound.InDesignPlugin/Sound
                             0x11a4ad000 -        0x11a528ff8 +com.adobe.InDesign.SharedContent (11.4.0.90 - 0) <C2C6CC5B-6DD2-3797-91AC-28B61A0BC17A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/SharedContent.InDesignPlugin/SharedContent
                             0x11a547000 -        0x11a569ff8 +com.adobe.InDesign.Sections (11.4.0.90 - 0) <FE882339-773C-37DB-926C-C56F795CE6F6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Sections.InDesignPlugin/Sections
                             0x11a57a000 -        0x11a60eff4 +com.adobe.InDesign.Scripting (11.4.0.90 - 0) <6EF8D2B1-7853-3197-A26C-D83349E722FA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Scripting.InDesignPlugin/Scripting
                             0x11a62f000 -        0x11a7a6ff0 +com.adobe.InDesign.Print (11.4.0.90 - 0) <644FC4CF-74B3-3D71-8A51-9833D7C8FBAC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Print.InDesignPlugin/Print
                             0x11a7d3000 -        0x11a80bffe +com.adobe.InDesign.PNG Import Filter (11.4.0.90 - 0) <AFFB3A8F-2C61-37D2-940E-DD2D64652A84> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/PNG Import Filter.InDesignPlugin/PNG Import Filter
                             0x11a81b000 -        0x11a858ff8 +com.adobe.InDesign.Photoshop Import Filter (11.4.0.90 - 0) <2C86E90C-14C4-30B6-B4AF-0C970EF16E60> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Photoshop Import Filter.InDesignPlugin/Photoshop Import Filter
                             0x11a869000 -        0x11a8c7ffc +com.adobe.InDesign.Book (11.4.0.90 - 0) <7189C8F9-B454-3CD2-BDFE-C43E2FC501F6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Book.InDesignPlugin/Book
                             0x11a8de000 -        0x11a9dbff4 +com.adobe.InDesign.Image (11.4.0.90 - 0) <F634D0AD-5946-3B8F-856D-DE8B565AD587> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Image.InDesignPlugin/Image
                             0x11aa08000 -        0x11aa13ffa +com.adobe.InDesign.Group (11.4.0.90 - 0) <5C5E6F92-3929-391A-BE7C-A074582A211D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Group.InDesignPlugin/Group
                             0x11aa1f000 -        0x11ab42ff1 +com.adobe.InDesign.EPS Page Item (11.4.0.90 - 0) <EF34D37B-F905-3F63-B2E6-655561AC6B69> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/EPS Page Item.InDesignPlugin/EPS Page Item
                             0x11ab83000 -        0x11add9ff5 +com.adobe.InDesign.PDF (11.4.0.90 - 0) <B0F81607-4181-389E-83AD-5BE457C8DC44> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/PDF.InDesignPlugin/PDF
                             0x11ae1f000 -        0x11af0cff3 +com.adobe.PDFPort (AdobePDFPort 2.1.0.36125 - 2.1.0.36125) <7908BFC3-7514-3832-B831-1F52193BF1BB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePDFPort.framework/Versions/A/AdobePDFPort
                             0x11af1f000 -        0x11af47fff +com.adobe.PDFSettings (AdobePDFSettings 1.07.0 - 1.7) <78CCA159-119A-3A97-8CA3-E024044C0AB6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobePDFSettings.framework/Versions/A/AdobePDFSettings
                             0x11af50000 -        0x11b19dff4 +com.adobe.InDesign.Generic Page Item (11.4.0.90 - 0) <F9379485-1896-3056-8C3C-0D2E75CB34BC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Generic Page Item.InDesignPlugin/Generic Page Item
                             0x11b1e9000 -        0x11b224ffc +com.adobe.InDesign.Path Type (11.4.0.90 - 0) <7B93E9B7-46B6-346A-AF64-25B21D7B1498> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Path Type.InDesignPlugin/Path Type
                             0x11b23d000 -        0x11b245ffb +PathTypeLib.dylib (0) <02ABE533-5966-3126-8F57-07C8D9A9BFE4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/PathTypeLib.dylib
                             0x11b24d000 -        0x11b2f2ffd +com.adobe.InDesign.Paragraph Composer (11.4.0.90 - 0) <236EB750-CEB2-3510-B716-CD2D844C8E34> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Paragraph Composer.InDesignPlugin/Paragraph Composer
                             0x11b302000 -        0x11b342ff9 +com.adobe.InDesign.Open Place (11.4.0.90 - 0) <10B74E1F-B94D-369D-AF29-E7248557089B> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Open Place.InDesignPlugin/Open Place
                             0x11b356000 -        0x11b36bff4 +com.adobe.InDesign.Movie (11.4.0.90 - 0) <E3213D0E-B598-3E3F-AC4B-96A894052A21> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Movie.InDesignPlugin/Movie
                             0x11b37a000 -        0x11b3f8ff8 +com.adobe.InDesign.Metadata (11.4.0.90 - 0) <75E2E3C0-7333-38F6-A6E0-3F8595BE7BC3> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Metadata.InDesignPlugin/Metadata
                             0x11b414000 -        0x11b464ff3 +com.adobe.InDesign.Media (11.4.0.90 - 0) <87915F97-68A5-31E1-B492-2B7E1888DA6A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Media.InDesignPlugin/Media
                             0x11b47a000 -        0x11b5ceff3 +com.adobe.InDesign.Links (11.4.0.90 - 0) <9808593A-B5D9-37C6-8AC4-91AF66D20101> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Links.InDesignPlugin/Links
                             0x11b60a000 -        0x11b62ffff +com.adobe.InDesign.Layout (11.4.0.90 - 0) <D24B9F6C-CC28-37D4-9EFC-6D5BD20908BE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Layout.InDesignPlugin/Layout
                             0x11b63d000 -        0x11b666ffc +com.adobe.InDesign.Layer (11.4.0.90 - 0) <70781FB3-F69D-3AB0-A4D1-03139AE8D955> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Layer.InDesignPlugin/Layer
                             0x11b679000 -        0x11b736ff4 +com.adobe.InDesign.INXCore (11.4.0.90 - 0) <AB12333D-9E19-3E7D-9825-419F83500D38> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/INXCore.InDesignPlugin/INXCore
                             0x11b75e000 -        0x11b852ff1 +com.adobe.InDesign.Indexing (11.4.0.90 - 0) <8246817E-F9D0-36E9-89E1-F25B60A97032> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Indexing.InDesignPlugin/Indexing
                             0x11b873000 -        0x11b90dff6 +com.adobe.InDesign.InCopyWorkflow (11.4.0.90 - 0) <4C672A76-4A63-35D7-B359-A6331624A3EF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/InCopyWorkflow.InDesignPlugin/InCopyWorkflow
                             0x11b932000 -        0x11ba24fff +com.adobe.InDesign.InCopyShared (11.4.0.90 - 0) <DE7E90E6-A335-3119-85CF-F97B0A42BFC1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/InCopyShared.InDesignPlugin/InCopyShared
                             0x11ba4f000 -        0x11bb1cffa +com.adobe.InDesign.HTMLPGT (11.4.0.90 - 0) <58E90D26-2A24-3DCF-9244-C8EB90B14DBC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/HTMLPGT.InDesignPlugin/HTMLPGT
                             0x11bb76000 -        0x11bb94ff6 +com.adobe.InDesign.Guides (11.4.0.90 - 0) <5E79084B-B18F-3FF5-9D91-ECA38F95A104> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Guides.InDesignPlugin/Guides
                             0x11bba5000 -        0x11bc08ff0 +com.adobe.InDesign.Gradient Fill (11.4.0.90 - 0) <25FB5EF1-F9AC-398F-A11F-B3C47B66B7D7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Gradient Fill.InDesignPlugin/Gradient Fill
                             0x11bc23000 -        0x11bc2eff5 +com.adobe.InDesign.GenericSettings (11.4.0.90 - 0) <E5C4D5B1-66EE-3DE1-A192-31F482F3ACC0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/GenericSettings.InDesignPlugin/GenericSettings
                             0x11bc37000 -        0x11bc8fff4 +com.adobe.InDesign.Galley (11.4.0.90 - 0) <1264814F-844D-3B0C-BBB9-08076C69A889> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Galley.InDesignPlugin/Galley
                             0x11bca3000 -        0x11bd6aff5 +com.adobe.InDesign.FormField (11.4.0.90 - 0) <7EB4ECEA-67BB-30A0-9834-68F5142CBB13> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/FormField.InDesignPlugin/FormField
                             0x11bd8f000 -        0x11be9afff +com.adobe.InDesign.Font Manager (11.4.0.90 - 0) <1217625E-B7FB-3BA1-838C-F083BA80E839> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Font Manager.InDesignPlugin/Font Manager
                             0x11bebd000 -        0x11c1d3fff +com.adobe.InDesign.Dynamic Documents (11.4.0.90 - 0) <7FFEA33D-FA1D-3396-957F-CC04327A6E42> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Dynamic Documents.InDesignPlugin/Dynamic Documents
                             0x11c21e000 -        0x11c315fff +com.adobe.AGMFL (AdobeAGMFL 2.1.0.32362 - 2.1.0.32362) <C93FF155-AA80-34F1-A785-42BC0D8D3909> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/ADBE_AGMFL.framework/Versions/A/ADBE_AGMFL
                             0x11c332000 -        0x11c50fff7 +com.adobe.AFlamingo (AFlamingo 2.4.402.31977 - 2.4.402.31977) <B90D5CA4-DA52-39A1-95DD-8011764655A1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/aflamingo.framework/Versions/A/aflamingo
                             0x11c533000 -        0x11c558ff0 +com.adobe.InDesign.Document Actions (11.4.0.90 - 0) <AD205C70-E02B-322C-9DB9-D6D1D1235021> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Document Actions.InDesignPlugin/Document Actions
                             0x11c565000 -        0x11c592ffe +com.adobe.InDesign.ContentDropper (11.4.0.90 - 0) <5668D541-50FC-3E88-8BFE-94C609ACE93A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/ContentDropper.InDesignPlugin/ContentDropper
                             0x11c5a5000 -        0x11c5f5ff0 +com.adobe.InDesign.Conditional Text (11.4.0.90 - 0) <92DD3B70-7348-3183-85AD-A795850AC942> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Conditional Text.InDesignPlugin/Conditional Text
                             0x11c60e000 -        0x11c670ffd +com.adobe.InDesign.CompFontMgr (11.4.0.90 - 0) <A2A51F49-9F10-3D26-A723-50C0C740E72E> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CompFontMgr.InDesignPlugin/CompFontMgr
                             0x11c68a000 -        0x11c708ff2 +com.adobe.InDesign.CJKGrid (11.4.0.90 - 0) <DDA29A41-53C8-3583-A248-F3BCE31BB63F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CJKGrid.InDesignPlugin/CJKGrid
                             0x11c724000 -        0x11c79aff5 +com.adobe.InDesign.CJK Text Attributes (11.4.0.90 - 0) <9C0B652D-526F-3E44-AC79-4A23FA0FEB64> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CJK Text Attributes.InDesignPlugin/CJK Text Attributes
                             0x11c7bd000 -        0x11c7f1ffa +com.adobe.InDesign.CellStyles (11.4.0.90 - 0) <67294C6C-E601-3381-969C-F6F1E238E77A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/CellStyles.InDesignPlugin/CellStyles
                             0x11c804000 -        0x11c896ff1 +com.adobe.InDesign.BNCore (11.4.0.90 - 0) <E4047150-CBEC-3D71-8E89-0A485D7C9746> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/BNCore.InDesignPlugin/BNCore
                             0x11c8b4000 -        0x11c906ff6 +com.adobe.InDesign.Behavior (11.4.0.90 - 0) <94E53F57-EBC6-326D-9DA2-9363E5F6C854> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Behavior.InDesignPlugin/Behavior
                             0x11c923000 -        0x11c95dfff +com.adobe.InDesign.AWS (11.4.0.90 - 0) <387C433A-7D5D-32D4-8654-B4BB7AB5333C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/AWS.InDesignPlugin/AWS
                             0x11c977000 -        0x11ca07ffc +com.adobe.InDesign.Assignments (11.4.0.90 - 0) <10AA3575-87E1-3DD8-A3F0-5D28D5DBE3A8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Assignments.InDesignPlugin/Assignments
                             0x11ca28000 -        0x11ca49ff9 +com.adobe.InDesign.Article (11.4.0.90 - 0) <BEB98508-F460-3FA1-8C6E-112A851826B2> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Article.InDesignPlugin/Article
                             0x11ca58000 -        0x11caa2ffd +com.adobe.InDesign.Snippet (11.4.0.90 - 0) <02D58BB3-5737-3AF0-B591-205D978A09C6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/XMedia/Snippet.InDesignPlugin/Snippet
                             0x11cabb000 -        0x11cac5ffe +com.adobe.InDesign.PerformanceMetrics (11.4.0.90 - 0) <7B9B8827-5189-32CB-9983-D2191C2DA47C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Utility/PerformanceMetrics.InDesignPlugin/PerformanceMet rics
                             0x11cacf000 -        0x11caddff1 +com.adobe.InDesign.SING (11.4.0.90 - 0) <A0C3CE98-9E43-3D6D-BF4D-9F3C1A10B3F7> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Text/SING.InDesignPlugin/SING
                             0x11cae6000 -        0x11cb04ff4 +com.adobe.InDesign.Optical Kerning (11.4.0.90 - 0) <E4BA50AF-DB3B-3728-AD1B-404063866DF6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Text/Optical Kerning.InDesignPlugin/Optical Kerning
                             0x11cb10000 -        0x11cb2aff8 +com.adobe.InDesign.Create Outlines (11.4.0.90 - 0) <E7A3C134-C01F-36C4-89FB-3CFB59EBF3BB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Text/Create Outlines.InDesignPlugin/Create Outlines
                             0x11cb37000 -        0x11cc07ffe +com.adobe.InDesign.JBX (11.4.0.90 - 0) <163FE37D-6EE3-3FDF-871C-63C08DE86AF0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Sandbox/JBX.InDesignPlugin/JBX
                             0x11cc31000 -        0x11ccd3ff0 +com.adobe.InDesign.DataMerge (11.4.0.90 - 0) <4328DAAE-4C1E-3968-9BB8-2BF4E99A5B57> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/PMPack/DataMerge.InDesignPlugin/DataMerge
                             0x11ccf3000 -        0x11cd05ffa +com.adobe.InDesign.Scotch Rules (11.4.0.90 - 0) <5955BAC7-39E3-31D7-9B03-051BB3316C73> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Page Item/Scotch Rules.InDesignPlugin/Scotch Rules
                             0x11cd10000 -        0x11cdbdffc +com.adobe.InDesign.Knowledge Base (11.4.0.90 - 0) <23D0A82F-3FFF-3414-9504-0F21E2510805> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Knowledge Base.InDesignPlugin/Knowledge Base
                             0x11cdc7000 -        0x11cde2ff0 +com.adobe.InDesign.Layout Adjustment (11.4.0.90 - 0) <C66606A7-19E6-364F-9A1A-5C27DD65C01D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Layout Adjustment.InDesignPlugin/Layout Adjustment
                             0x11cdf0000 -        0x11cdf6ff3 +com.adobe.InDesign.InCopyImport (11.4.0.90 - 0) <92AE81B7-8E01-360F-9926-40A4A6C8CBEB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyImport.InDesignPlugin/InCopyImport
                             0x11cdfd000 -        0x11ce04ff8 +com.adobe.InDesign.InCopyExport (11.4.0.90 - 0) <390FA732-55AD-3F1B-9E08-B610E43D9940> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopyExport.InDesignPlugin/InCopyExport
                             0x11ce0d000 -        0x11ce45ffa +com.adobe.InDesign.InCopy Bridge (11.4.0.90 - 0) <58B9EA11-15CE-3C34-BD84-A666218DC157> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/InCopy Bridge.InDesignPlugin/InCopy Bridge
                             0x11ce55000 -        0x11ce68ff8 +com.adobe.InDesign.Printer Styles (11.4.0.90 - 0) <076200FF-E63B-3DF9-BB6C-41059376A9C2> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/Printer Styles.InDesignPlugin/Printer Styles
                             0x11ce76000 -        0x11ce8dff7 +com.adobe.InDesign.JPEG Export (11.4.0.90 - 0) <1347F4DC-6DB4-3FE5-A1E0-1212CA6E3617> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/JPEG Export.InDesignPlugin/JPEG Export
                             0x11ce9e000 -        0x11cf29ff9 +com.adobe.InDesign.Tagged Text Attributes (11.4.0.90 - 0) <2CC31F7B-D3B1-3E2D-8A1F-46D12E3377D4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Attributes.InDesignPlugin/Tagged Text Attributes
                             0x11cf58000 -        0x11cff5ff2 +com.adobe.InDesign.Tagged Text Filters (11.4.0.90 - 0) <16EB9FF6-A83B-3CD1-9DDE-96B499FBEC19> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Filters/Tagged Text Filters.InDesignPlugin/Tagged Text Filters
                             0x11d009000 -        0x11d00bffe +com.adobe.InDesign.SimpleTextImportFilter (11.4.0.90 - 0) <1C3148A2-A873-3909-8B4E-26B9639078E1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Filters/SimpleTextImportFilter.InDesignPlugin/SimpleText ImportFilter
                             0x11d011000 -        0x11d026ff1 +com.adobe.InDesign.SaveBack (11.4.0.90 - 0) <F924B1C4-DA6A-317A-BC6E-37C6AE930633> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Filters/SaveBack.InDesignPlugin/SaveBack
                             0x11d034000 -        0x11d190ff9 +com.adobe.InDesign.SangamServicer-Mapper (11.4.0.90 - 0) <73E74175-0E53-3207-9EB8-C53CCFAA3F66> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Filters/SangamServicer-Mapper.InDesignPlugin/SangamServi cer-Mapper
                             0x11d1bf000 -        0x11d23eff7 +com.adobe.AdobeSangam (AdobeSangam 5.65.0.36007 - 5.65.0.36007) <EC7B69CF-2DA9-370F-9685-99509E63D642> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeSangam.framework/Versions/A/AdobeSangam
                             0x11d28f000 -        0x11d2d8ff2 +com.adobe.InDesign.Media Import Filter (11.4.0.90 - 0) <3A7F5E76-5946-3161-9B29-AC082D6B34A6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Filters/Media Import Filter.InDesignPlugin/Media Import Filter
                             0x11d2ea000 -        0x11d549ffd +com.adobe.InDesign.EBookExport (11.4.0.90 - 0) <676D45FF-8021-36AA-87F2-3C7947E1C7AF> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Filters/EBookExport.InDesignPlugin/EBookExport
                             0x11d580000 -        0x11d762ff3 +com.adobe.InDesign.Digital Publishing (11.4.0.90 - 0) <04B2FF24-8333-3BB9-84DD-C318C1CA3B5C> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Filters/Digital Publishing.InDesignPlugin/Digital Publishing
                             0x11d7a7000 -        0x11d7cbfff +com.adobe.InDesign.LILO (11.4.0.90 - 0) <9AC600D7-792C-387C-B665-310E31026CAA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Dictionaries/LILO/LILO.InDesignPlugin/LILO
                             0x11d7d9000 -        0x11d8c0fff +com.adobe.linguistic.LinguisticManager (9.0.0 - 21429) <7C403E13-460B-3576-B7BB-E2A88287B15D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                             0x11d8dd000 -        0x11d8e8ff0 +com.adobe.InDesign.DTTransform (11.4.0.90 - 0) <907FE07B-72F1-34C5-BE6C-98A40BE44B71> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Data Services/DTTransform.InDesignPlugin/DTTransform
                             0x11d8f1000 -        0x11d8f7ff4 +com.adobe.InDesign.Data Services (11.4.0.90 - 0) <B07286D0-7F16-36E1-B3EC-1C51597828D1> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Data Services/Data Services.InDesignPlugin/Data Services
                             0x11d8fd000 -        0x11d923ff7 +com.adobe.ape (3.4.0.29366 - 3.4.0.29366) <40A59819-7A57-0E9F-658D-1803B2A461AE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/adbeapecore.framework/adbeapecore
                             0x11d936000 -        0x11d942fff +com.extensis.fontplugins (17.3.0.636751 - 17.3.0.636751) <DAA42E85-FE97-3374-90F3-239F04CB9957> /Applications/Suitcase Fusion 6.app/Contents/Resources/PluginFiles/ExtensisPlugins.framework/ExtensisPlugins
                             0x11d98a000 -        0x11d9a4ff2 +com.adobe.InDesign.SavebackService (11.0.0 - 0) <4069FBE8-6DFA-318B-AA60-2354D3D539D8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/SavebackService/SavebackService.InDesignPlugin/SavebackS ervice
                             0x11d9b2000 -        0x11dafdfff +IMSLib.dylib (10.0.0.7 - 10.0.0.7) <1DD294BF-3FEB-3BBF-A27C-94D2445CB4B4> /Library/Application Support/Adobe/*/IMSLib.dylib
                             0x11db1e000 -        0x11db98ff7  com.apple.xquery (1.3.1 - 30) <C1020441-B131-3995-86D9-9D0B725D3FAD> /System/Library/PrivateFrameworks/XQuery.framework/XQuery
                             0x11dbdd000 -        0x11dc33ff9 +com.adobe.InDesign.Actions (11.4.0.90 - 0) <40719ABA-75D2-3542-A0FA-C2BA4FC09621> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Actions.InDesignPlugin/Actions
                             0x11dc4f000 -        0x11dc5aff0 +com.adobe.InDesign.Scripts Panel (11.4.0.90 - 0) <BEC9D3F4-3BFB-33B0-A002-B08C6E661998> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Script/Scripts Panel.InDesignPlugin/Scripts Panel
                             0x11dc68000 -        0x11dcecff8 +com.adobe.InDesign.Eyedropper Tool (11.4.0.90 - 0) <565C843A-7E7E-389A-91B6-65F351DF4731> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Eyedropper Tool.InDesignPlugin/Eyedropper Tool
                             0x11dd67000 -        0x11dd6affe +com.adobe.InDesign.Username UI (11.4.0.90 - 0) <D00DFC4A-B366-30BC-9811-A2189631BE8F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Username UI.InDesignPlugin/Username UI
                             0x11dd74000 -        0x11ddf1fff +com.adobe.InDesign.CSXS (11.4.0.90 - 0) <259819EA-B552-3EBB-975F-E27B36D58629> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/UI/CSXS.InDesignPlugin/CSXS
                             0x11de90000 -        0x11deb5ff7 +com.adobe.InDesign.AWSUI (11.4.0.90 - 0) <872FD8EB-2743-3F24-8ADE-75ED9680A376> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/AWSUI.InDesignPlugin/AWSUI
                             0x11dec9000 -        0x11df2bff4 +com.adobe.InDesign.Spread UI (11.4.0.90 - 0) <9C2FFB9C-1B38-3694-BBD8-092A62FC52C2> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Required/Spread UI.InDesignPlugin/Spread UI
                             0x11df4d000 -        0x11e046ff3 +com.adobe.InDesign.Package and Preflight UI (11.4.0.90 - 0) <83E280DA-ECBF-3E62-AA36-F71318E17FA6> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Prepress/Package and Preflight UI.InDesignPlugin/Package and Preflight UI
                             0x11e085000 -        0x11e1a0ff2 +com.adobe.InDesign.XMedia UI (11.4.0.90 - 0) <BC73F097-B5FD-3E75-9662-E74F64D243BC> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/XMedia/XMedia UI.InDesignPlugin/XMedia UI
                             0x11e1ea000 -        0x11e213fff +libSLCacheWrapper.dylib (1) <AB5FD9B1-D26B-3599-820A-6E1238597C86> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/LogSession.framework/Libraries/libSLCacheWrapper.dylib
                             0x11e5b0000 -        0x11e5d4ff5 +com.adobe.InDesign.Text Style Panel (11.4.0.90 - 0) <9A9DB83F-BD5E-3901-A198-E834A4E6D6A0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Text/Text Style Panel.InDesignPlugin/Text Style Panel
                             0x11e5e5000 -        0x11e656ff5 +com.adobe.InDesign.Style Panel (11.4.0.90 - 0) <4FB43614-35A0-30B9-88B3-26AF8AC883BE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Text/Style Panel.InDesignPlugin/Style Panel
                             0x11e67f000 -        0x11e68eff8 +com.adobe.InDesign.PS Import UI (11.4.0.90 - 0) <33F2213D-54FD-3A6D-85DE-50F4E6D91232> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/PS Import UI.InDesignPlugin/PS Import UI
                             0x11e69c000 -        0x11e6b3fff +com.adobe.InDesign.Bookmark Panel (11.4.0.90 - 0) <EA926117-06DE-3CFA-B5D1-664729716290> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Bookmark Panel.InDesignPlugin/Bookmark Panel
                             0x11f6d1000 -        0x11f72cff5 +com.adobe.InDesign.Assignment UI (11.4.0.90 - 0) <7CA97EDE-69BE-3A57-AB45-2BAA069711FA> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Assignment UI.InDesignPlugin/Assignment UI
                             0x11f74e000 -        0x11f776fff +com.adobe.InDesign.Article Panel (11.4.0.90 - 0) <99EFC99C-6581-3B7C-9E4B-E62A7E4EBA6D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/UI/Article Panel.InDesignPlugin/Article Panel
                             0x11f78e000 -        0x11f7c3ff2 +com.adobe.InDesign.Transform Panel (11.4.0.90 - 0) <9A281113-989B-30A3-B3C8-03447E521927> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Transform Panel.InDesignPlugin/Transform Panel
                             0x11f7d8000 -        0x11f84fff8 +com.adobe.InDesign.DynamicDocumentsUI (11.4.0.90 - 0) <5F1C45A4-A00B-3CCF-9F66-5CEB9630D6A5> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/DynamicDocumentsUI.InDesignPlugin/DynamicDocume ntsUI
                             0x11f875000 -        0x11f8a1ff4 +com.adobe.InDesign.Conditional Text UI (11.4.0.90 - 0) <2C7B88CE-F7D9-3E2E-A414-3125AEA8766D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Text/Conditional Text UI.InDesignPlugin/Conditional Text UI
                             0x11f8bb000 -        0x11f955ffc +com.adobe.InDesign.TableStylesUI (11.4.0.90 - 0) <1AC83940-41AC-334F-AF57-7A69F416A7DD> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Tables/TableStylesUI.InDesignPlugin/TableStylesUI
                             0x11f980000 -        0x11f988ff4 +com.adobe.InDesign.Generic Style Editor (11.4.0.90 - 0) <95698B55-A79E-3321-B50C-53DF9785C919> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/Generic Style Editor.InDesignPlugin/Generic Style Editor
                             0x11f995000 -        0x11fa66ff9 +com.adobe.InDesign.PrintUI (11.4.0.90 - 0) <CA40DE23-FB80-3640-BDF4-BCB2A93C53A5> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/PrintUI.InDesignPlugin/PrintUI
                             0x11fa90000 -        0x11fb13ff9 +com.adobe.InDesign.Color Picker Panel (11.4.0.90 - 0) <A291749D-2E33-3149-ACFA-E9A415E75DE0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/Color Picker Panel.InDesignPlugin/Color Picker Panel
                             0x11fb3e000 -        0x11fc22ff2 +com.adobe.InDesign.Swatches Panel (11.4.0.90 - 0) <202E7ADE-550E-36B5-868E-BF0AED36A1EE> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/Swatches Panel.InDesignPlugin/Swatches Panel
                             0x11fc5d000 -        0x11fcfaff7 +com.adobe.InDesign.Transparency UI (11.4.0.90 - 0) <F93AF504-D752-32FF-97B5-DF0A58C952E8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/Transparency UI.InDesignPlugin/Transparency UI
                             0x11fd2d000 -        0x11fdd4fff +com.adobe.InDesign.Graphic Panels (11.4.0.90 - 0) <5B6573E3-3155-3F7F-85BF-C2D203B0FBE5> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/Graphic Panels.InDesignPlugin/Graphic Panels
                             0x11fdfe000 -        0x11fe96ffe +com.adobe.InDesign.ObjectStylesUI (11.4.0.90 - 0) <C5D2D705-94D5-31B3-9B97-A97B0F8505D0> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/ObjectStylesUI.InDesignPlugin/ObjectStylesUI
                             0x11fec4000 -        0x11ff51ff5 +com.adobe.InDesign.ButtonUI (11.4.0.90 - 0) <95B3AD17-C517-3F2F-B1AA-A2552B2FEE02> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Interactive/ButtonUI.InDesignPlugin/ButtonUI
                             0x11ff7e000 -        0x12001cff0 +com.adobe.InDesign.Hyperlinks Panel (11.4.0.90 - 0) <E5C89F16-D20E-3372-AF4C-7A6B51981947> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Hyperlinks Panel.InDesignPlugin/Hyperlinks Panel
                             0x120045000 -        0x1200ccff4 +com.adobe.InDesign.Index Panel (11.4.0.90 - 0) <C8A98780-283E-38DB-9A1A-DD9088779B69> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Index Panel.InDesignPlugin/Index Panel
                             0x1200eb000 -        0x1200f7ff7  com.apple.carbonframeworktemplate (1.0 - 1.0) <6F5D8218-7BB8-378F-A9EA-EF46B665DC63> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/Frameworks/unihan.framework/Versions/A/unihan
                             0x120102000 -        0x12014dff7 +com.adobe.InDesign.Output Preview (11.4.0.90 - 0) <3E63A762-9336-3CBB-B0B4-883A91062E9D> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/Output Preview.InDesignPlugin/Output Preview
                             0x120168000 -        0x1201a4ffe +com.adobe.InDesign.TOC UI Dialog (11.4.0.90 - 0) <14E0F2CD-7D26-39C8-B512-EED3B4413974> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/TOC UI Dialog.InDesignPlugin/TOC UI Dialog
                             0x1201bc000 -        0x1201d0ff4 +com.adobe.InDesign.OutputMiscUI (11.4.0.90 - 0) <FB53277D-552D-34B4-BD6B-4958A0E9E5AB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Graphics/OutputMiscUI.InDesignPlugin/OutputMiscUI
                             0x1201e1000 -        0x1201ecff6 +com.adobe.InDesign.Sections UI (11.4.0.90 - 0) <18415F9C-26BB-30DF-B24C-33EB2857779A> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Sections UI.InDesignPlugin/Sections UI
                             0x1201f5000 -        0x12023cffc +com.adobe.InDesign.Book Panel (11.4.0.90 - 0) <2D5A0AC5-46D0-30D8-93C7-E5F2F65E9CCB> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Book Panel.InDesignPlugin/Book Panel
                             0x12025f000 -        0x1202b0ff6 +com.adobe.InDesign.Note (11.4.0.90 - 0) <23A5EE5F-F310-34E9-BB86-4FD697DCC3E8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/InCopyWorkflow/Note.InDesignPlugin/Note
                             0x1202cf000 -        0x120318ff0 +com.adobe.InDesign.Layers Panel (11.4.0.90 - 0) <FC62661B-416C-3741-96F5-0ED0825182A8> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Layers Panel.InDesignPlugin/Layers Panel
                             0x120338000 -        0x12036eff6 +com.adobe.InDesign.Dictionary Editor Dialog (11.4.0.90 - 0) <B1EE846E-E57B-3CD4-9163-E2AFCE26D8F4> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Dictionaries/Dictionary Editor Dialog.InDesignPlugin/Dictionary Editor Dialog
                             0x12038e000 -        0x12044affa +com.adobe.InDesign.Pages Panel (11.4.0.90 - 0) <02D8650F-015A-3BFA-88FF-9BFDC9C9660F> /Applications/Adobe InDesign CC 2015/Adobe InDesign CC 2015.app/Contents/MacOS/Plug-Ins/Layout/Pages Panel.InDesignPlugin/Pages Panel
                             0x120858000 -        0x12085ffff  com.apple.URLMount.AFPPlugin (6.0 - 6.0) <8CE70180-6B49-36F9-81B7-9C0922F606D5> /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
                             0x120867000 -        0x1208a7fff  com.apple.AppleShareClientCore (4.0 - 3.0) <AF0480F0-9E73-3BDB-AE92-34C1D5513729> /System/Library/PrivateFrameworks/AppleShareClientCore.framework/Versions/A/AppleShareCli entCore
                          0x7fff66da7000 -     0x7fff66dde25f  dyld (360.22) <A468D85E-D8D6-3461-8C99-49D3B9ACFC63> /usr/lib/dyld
                          0x7fff8266c000 -     0x7fff82671fff  com.apple.DiskArbitration (2.7 - 2.7) <F55902AA-5316-3255-A701-FDED5B553065> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                          0x7fff82688000 -     0x7fff82893fff  libFosl_dynamic.dylib (16.24) <5F9DB82D-FD4B-3952-8531-CE020F93ED49> /usr/lib/libFosl_dynamic.dylib
                          0x7fff82956000 -     0x7fff82957fff  libDiagnosticMessagesClient.dylib (100) <4243B6B4-21E9-355B-9C5A-95A216233B96> /usr/lib/libDiagnosticMessagesClient.dylib
                          0x7fff82a6c000 -     0x7fff82b7efef  libvDSP.dylib (563.5) <5702650E-DF08-3D58-B16F-9EF0A28702B3> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                          0x7fff82b80000 -     0x7fff82cfefff  com.apple.UIFoundation (1.0 - 436.1) <AABB5267-E7B7-3D75-B051-E665BDA8DEF4> /System/Library/PrivateFrameworks/UIFoundation.framework/Versions/A/UIFoundation
                          0x7fff82e2d000 -     0x7fff82e2eff3  com.apple.print.framework.Print (10.0 - 266) <3E85F70C-D7D4-34E1-B88A-C1F503F99CDA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                          0x7fff82e2f000 -     0x7fff82e40ff7  libz.1.dylib (61.20.1) <B3EBB42F-48E3-3287-9F0D-308E04D407AC> /usr/lib/libz.1.dylib
                          0x7fff83552000 -     0x7fff83641fff  libxml2.2.dylib (29.7) <32BBF51E-B084-3FC2-AE9C-C008BE84102B> /usr/lib/libxml2.2.dylib
                          0x7fff83642000 -     0x7fff83645ff7  com.apple.help (1.3.3 - 46) <35DA4D48-0BC2-35A1-8D7C-40905CDF4F64> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                          0x7fff8365d000 -     0x7fff836f3fff  com.apple.ColorSync (4.9.0 - 4.9.0) <8FC37E20-6579-3CB2-9D49-BC39FC38DF87> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                          0x7fff836f4000 -     0x7fff83716fff  com.apple.IconServices (68.1 - 68.1) <CDEEDBE6-F53B-3BA1-82D4-23BCA3DD8949> /System/Library/PrivateFrameworks/IconServices.framework/Versions/A/IconServices
                          0x7fff8371b000 -     0x7fff8371ffff  libcache.dylib (75) <9548AAE9-2AB7-3525-9ECE-A2A7C4688447> /usr/lib/system/libcache.dylib
                          0x7fff838fc000 -     0x7fff83927ffb  libarchive.2.dylib (33.20.2) <6C370A21-63FD-3A68-B4B3-5333F24B770B> /usr/lib/libarchive.2.dylib
                          0x7fff83928000 -     0x7fff83956ff7  com.apple.CoreServicesInternal (248.2 - 248.2) <6E111F0A-D7F1-3738-ADE7-CF983BD4EC8B> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                          0x7fff839bb000 -     0x7fff845e4ff7  com.apple.AppKit (6.9 - 1404.47) <F3411F6E-DD87-34D0-8C68-C69B2205E41D> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                          0x7fff845e5000 -     0x7fff84600ff7  libCRFSuite.dylib (34) <078B4CD8-6A8C-3067-B2BA-0C2A0BAB8AC3> /usr/lib/libCRFSuite.dylib
                          0x7fff84601000 -     0x7fff8462aff7  libxpc.dylib (765.50.8) <54D1328E-054E-3DAA-89E2-375722F9D18F> /usr/lib/system/libxpc.dylib
                          0x7fff84642000 -     0x7fff84647ff3  libunwind.dylib (35.3) <F6EB48E5-4D12-359A-AB54-C937FBBE9043> /usr/lib/system/libunwind.dylib
                          0x7fff84648000 -     0x7fff84701ff7  libvMisc.dylib (563.5) <BF612F7D-FA3B-3F9F-8BE7-8D1BCB21ECC5> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                          0x7fff84702000 -     0x7fff847bbff7  com.apple.cloudkit.CloudKit (482.29 - 482.29) <E235B37E-1491-3857-BDE8-38450D4FE8D0> /System/Library/Frameworks/CloudKit.framework/Versions/A/CloudKit
                          0x7fff847bc000 -     0x7fff847d3ff7  libsystem_asl.dylib (323.50.1) <41F8E11F-1BD0-3F1D-BA3A-AA1577ED98A9> /usr/lib/system/libsystem_asl.dylib
                          0x7fff847d4000 -     0x7fff847dcfff  com.apple.CoreServices.FSEvents (1223.10.1 - 1223.10.1) <7F5B7A23-BC1D-3FA9-A9B8-D534F1E1979A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/FSEvents.framewor k/Versions/A/FSEvents
                          0x7fff84c89000 -     0x7fff84cd8ff7  com.apple.opencl (2.7.0 - 2.7.0) <C3AFF6D2-90FE-3108-A2D5-A1EBCFC5D627> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                          0x7fff84cd9000 -     0x7fff84fbeffb  com.apple.CoreServices.CarbonCore (1136.2 - 1136.2) <2DBAFC9A-6CD6-351D-B1F4-87D81AA6D640> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                          0x7fff84fbf000 -     0x7fff852b4fff  com.apple.HIToolbox (2.1.1 - 807.2) <36413C45-36AF-34EF-9C0E-F18B31D1E565> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                          0x7fff85379000 -     0x7fff85398ff7  com.apple.framework.Apple80211 (11.0 - 1121.34.2) <90477FAE-B835-3931-80FB-FDFF02B21D9D> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                          0x7fff85454000 -     0x7fff85912fcf  com.apple.vImage (8.0 - 8.0) <85FB412E-EB30-3433-A79B-B3970FC83580> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                          0x7fff85913000 -     0x7fff85913fff  com.apple.Carbon (154 - 157) <8F6ED602-5943-3E29-A793-BC331E2C183D> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                          0x7fff85920000 -     0x7fff85928fff  libsystem_networkextension.dylib (385.40.36) <66095DC7-6539-38F2-95EE-458F15F6D014> /usr/lib/system/libsystem_networkextension.dylib
                          0x7fff85944000 -     0x7fff85946fff  libsystem_coreservices.dylib (19.2) <1B3F5AFC-FFCD-3ECB-8B9A-5538366FB20D> /usr/lib/system/libsystem_coreservices.dylib
                          0x7fff85ad0000 -     0x7fff85ad4fff  libGIF.dylib (1450) <49D45D41-11AD-38DC-BDC5-9EC57E3B8E30> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                          0x7fff85b73000 -     0x7fff85b75ff7  libsystem_configuration.dylib (802.40.13) <3DEB7DF9-6804-37E1-BC83-0166882FF0FF> /usr/lib/system/libsystem_configuration.dylib
                          0x7fff85b76000 -     0x7fff85bc8fff  com.apple.CloudDocs (1.0 - 383.13) <5FD9138D-09D9-3B97-BBAD-5692E1687F30> /System/Library/PrivateFrameworks/CloudDocs.framework/Versions/A/CloudDocs
                          0x7fff85c74000 -     0x7fff85c84fff  libbsm.0.dylib (34) <7E14504C-A8B0-3574-B6EB-5D5FABC72926> /usr/lib/libbsm.0.dylib
                          0x7fff85c85000 -     0x7fff85c89fff  libpam.2.dylib (20) <CFCD19BD-87BC-3F2B-BB1C-4C23E8E55F1A> /usr/lib/libpam.2.dylib
                          0x7fff85c8a000 -     0x7fff85cd6fff  com.apple.print.framework.PrintCore (11.2 - 472.2) <5AE8AA6B-CE09-397D-B0D4-0F9CCBF1F77D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                          0x7fff85ce6000 -     0x7fff85d55fff  com.apple.SearchKit (1.4.0 - 1.4.0) <F159A888-34CA-36F1-AC8E-EB1B38C9DFB3> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                          0x7fff85d56000 -     0x7fff85f77ff7  com.apple.CoreImage (11.4.0 - 366.4.19) <F5B7B115-E43A-3C61-A6AD-EFCDE7FC43A1> /System/Library/Frameworks/CoreImage.framework/Versions/A/CoreImage
                          0x7fff85f81000 -     0x7fff85fb7fff  libssl.0.9.8.dylib (59.40.2) <523FEBFA-4BF7-3A69-83B7-164265BE7F4D> /usr/lib/libssl.0.9.8.dylib
                          0x7fff85fb8000 -     0x7fff85fc6ff7  libbz2.1.0.dylib (38) <28E54258-C0FE-38D4-AB76-1734CACCB344> /usr/lib/libbz2.1.0.dylib
                          0x7fff861b3000 -     0x7fff8626bff7  com.apple.CoreDuet (1.0 - 1) <FC1EAEE1-73A4-3B13-A634-1D2A94D0C0B7> /System/Library/PrivateFrameworks/CoreDuet.framework/Versions/A/CoreDuet
                          0x7fff86291000 -     0x7fff862aafe7  libcompression.dylib (28) <F83F421D-115D-3457-A9AA-1BEB5070A30B> /usr/lib/libcompression.dylib
                          0x7fff862ff000 -     0x7fff86333ff7  com.apple.CoreVideo (1.8 - 191.3) <1AA24A1B-CB84-3F6B-B6DE-11494542649C> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                          0x7fff86365000 -     0x7fff863dcfeb  libcorecrypto.dylib (335.50.1) <B5C05FD7-A540-345A-87BF-8E41848A3C17> /usr/lib/system/libcorecrypto.dylib
                          0x7fff86441000 -     0x7fff86446ff7  libheimdal-asn1.dylib (453.40.10) <981DE40B-FA16-36F7-BE92-8C8A115D6CD9> /usr/lib/libheimdal-asn1.dylib
                          0x7fff86447000 -     0x7fff8648cff3  libFontRegistry.dylib (155.2) <A70DD497-35F3-34DA-9C19-F4B90080E961> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                          0x7fff864bb000 -     0x7fff86548fff  libsystem_c.dylib (1082.50.1) <B552D565-B798-3B9B-AE63-F623B42A5F01> /usr/lib/system/libsystem_c.dylib
                          0x7fff86549000 -     0x7fff8654afff  com.apple.TrustEvaluationAgent (2.0 - 25) <0239494E-FEFE-39BC-9FC7-E251BA5128F1> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                          0x7fff865a8000 -     0x7fff865b2fff  com.apple.KerberosHelper (4.0 - 1.0) <67D88B2C-A54B-34FF-ABF3-2D3736879730> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
                          0x7fff865cf000 -     0x7fff865d2ffb  libdyld.dylib (360.22) <CC088C2A-D407-33E7-A6B6-B06E0D4AD999> /usr/lib/system/libdyld.dylib
                          0x7fff865d3000 -     0x7fff865fcfff  libsystem_info.dylib (477.50.4) <FAA9226D-64DE-3769-A6D8-6CABA4B7FF4D> /usr/lib/system/libsystem_info.dylib
                          0x7fff866e9000 -     0x7fff8673afff  com.apple.audio.CoreAudio (4.3.0 - 4.3.0) <EA7D4F3B-062B-3C81-A98C-C89264D00D48> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                          0x7fff8673b000 -     0x7fff86bd6ffb  com.apple.GeoServices (1.0 - 1151.49.1) <2D887517-B73D-30FF-91DC-AF6AD91F96B9> /System/Library/PrivateFrameworks/GeoServices.framework/Versions/A/GeoServices
                          0x7fff87b26000 -     0x7fff87b31ff7  libcommonCrypto.dylib (60075.50.1) <93732261-34B4-3914-B7A2-90A81A182DBA> /usr/lib/system/libcommonCrypto.dylib
                          0x7fff87b32000 -     0x7fff87b33fff  liblangid.dylib (122) <9CC4F0D1-5C51-3B69-BC8F-EE3A51FD0822> /usr/lib/liblangid.dylib
                          0x7fff87b34000 -     0x7fff87b40fff  com.apple.SpeechRecognitionCore (2.2.7 - 2.2.7) <6BA06290-D4A3-351C-87F9-B61EF61FF055> /System/Library/PrivateFrameworks/SpeechRecognitionCore.framework/Versions/A/SpeechRecogn itionCore
                          0x7fff87b41000 -     0x7fff87bb5ff3  com.apple.securityfoundation (6.0 - 55126) <130656AE-2711-3914-8736-D8B021C93FE0> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                          0x7fff87ff7000 -     0x7fff881c5ff3  com.apple.QuartzCore (1.11 - 410.14) <076BDE58-8AED-3D47-84FD-548CF8E8EDB9> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                          0x7fff881c6000 -     0x7fff882b8ff7  libJP2.dylib (1450) <8337298A-7911-3B56-85C7-BBA2D8D844EE> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                          0x7fff88f79000 -     0x7fff89020fff  com.apple.LanguageModeling (1.0 - 1) <58C18A47-BDE7-3CBE-81C0-797029D170A1> /System/Library/PrivateFrameworks/LanguageModeling.framework/Versions/A/LanguageModeling
                          0x7fff89081000 -     0x7fff890dffff  com.apple.SystemConfiguration (1.14 - 1.14) <D801FAD7-5A2D-3E5E-9F44-B6C9B8BEA747> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                          0x7fff89603000 -     0x7fff89899fff  libmecabra.dylib (696.5) <EF6C0BD4-5FE8-34FB-8ADF-69A53CEC97A9> /usr/lib/libmecabra.dylib
                          0x7fff89b62000 -     0x7fff89b7cfff  com.apple.Kerberos (3.0 - 1) <1B4744BF-E5AE-38E2-AA56-E22D3270F2E8> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                          0x7fff89b9b000 -     0x7fff89bb4fff  com.apple.openscripting (1.7.1 - 169.1) <36EBF6A7-334A-3197-838F-E8C7B27FCDBB> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                          0x7fff89bb5000 -     0x7fff89bbafff  com.apple.ImageCapture (9.0 - 9.0) <ACECF0B7-7D92-3A22-BF47-E8FADF4C5378> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                          0x7fff89bf0000 -     0x7fff89bf0fff  com.apple.Accelerate (1.10 - Accelerate 1.10) <5831771A-C1C3-3625-9FE9-2CCB6B2E7EE1> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                          0x7fff89c0b000 -     0x7fff89c24fff  com.apple.CFOpenDirectory (10.11 - 194) <11F95672-55E0-3F9D-9171-5E8C56AEE948> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                          0x7fff89c25000 -     0x7fff89c25fff  com.apple.Accelerate.vecLib (3.10 - vecLib 3.10) <848125D3-AF14-3526-8745-FFCDB200CD76> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                          0x7fff89c26000 -     0x7fff89c26ff7  libkeymgr.dylib (28) <8371CE54-5FDD-3CE9-B3DF-E98C761B6FE0> /usr/lib/system/libkeymgr.dylib
                          0x7fff89c27000 -     0x7fff89c4efff  com.apple.ChunkingLibrary (167 - 167) <AD7F285C-005E-36BB-98A3-5826413533BE> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                          0x7fff89c4f000 -     0x7fff89d5dff3  com.apple.desktopservices (1.10.3 - 1.10.3) <3A6906D4-C0B8-30D1-B589-0466E5E42B69> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                          0x7fff89d5e000 -     0x7fff89d78ff3  liblzma.5.dylib (10) <CC03591B-FA57-3CA5-AC81-0D76033AC0CE> /usr/lib/liblzma.5.dylib
                          0x7fff89d79000 -     0x7fff89d96ff7  com.apple.AppleVPAFramework (2.1.2 - 2.1.2) <41378C0B-B56A-3A73-9BD0-E06FA1F87B8C> /System/Library/PrivateFrameworks/AppleVPA.framework/Versions/A/AppleVPA
                          0x7fff89e0c000 -     0x7fff89e0ffff  libsystem_sandbox.dylib (460.50.4) <150A9D3D-F69E-32F7-8C7B-8E72CAAFF7E4> /usr/lib/system/libsystem_sandbox.dylib
                          0x7fff89e10000 -     0x7fff89e1bfff  libkxld.dylib (3248.50.21) <99195052-038E-3490-ACF8-76F9AC43897E> /usr/lib/system/libkxld.dylib
                          0x7fff89fd9000 -     0x7fff89fdbfff  libCGXType.A.dylib (957) <B901C222-E779-32EB-96C2-5A707A09FC5B> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCGXType.A.dylib
                          0x7fff89fdc000 -     0x7fff8a04aff7  com.apple.ApplicationServices.ATS (377 - 394.4) <9779E916-0788-3CAC-B1EC-F68BCB12A2B6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                          0x7fff8a04b000 -     0x7fff8a069ff7  libsystem_kernel.dylib (3248.50.21) <78E54D59-D2B0-3F54-9A4A-0A68D671F253> /usr/lib/system/libsystem_kernel.dylib
                          0x7fff8a0d5000 -     0x7fff8a0d6ffb  libremovefile.dylib (41) <552EF39E-14D7-363E-9059-4565AC2F894E> /usr/lib/system/libremovefile.dylib
                          0x7fff8a0d7000 -     0x7fff8a106ffb  libsystem_m.dylib (3105) <08E1A4B2-6448-3DFE-A58C-ACC7335BE7E4> /usr/lib/system/libsystem_m.dylib
                          0x7fff8a191000 -     0x7fff8a219fff  com.apple.CoreSymbolication (3.1 - 58048.1) <4730422E-4178-34F9-8550-BB92F2A4F44B> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                          0x7fff8a21a000 -     0x7fff8a21afff  libOpenScriptingUtil.dylib (169.1) <AD0DAC8A-9849-3077-999F-9AEC6112BDAB> /usr/lib/libOpenScriptingUtil.dylib
                          0x7fff8a758000 -     0x7fff8a79eff7  libauto.dylib (186) <999E610F-41FC-32A3-ADCA-5EC049B65DFB> /usr/lib/libauto.dylib
                          0x7fff8a7bb000 -     0x7fff8a7c3fff  libGFXShared.dylib (12.1) <5A0C2493-200C-30BE-97D5-8E8C0B8E604D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                          0x7fff8a7c4000 -     0x7fff8a7c9ff7  com.apple.AssetCacheServices (14.1 - 14.1) <5F249F84-660A-3E94-B073-6729E7ED56D9> /System/Library/PrivateFrameworks/AssetCacheServices.framework/Versions/A/AssetCacheServi ces
                          0x7fff8a7ca000 -     0x7fff8a808ff7  libGLImage.dylib (12.1) <BB1F1A93-5101-3906-AB17-8D83FCB200F9> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                          0x7fff8a809000 -     0x7fff8a896dd7  com.apple.AppleJPEG (1.0 - 1) <558ACADA-C41F-3EEF-82A0-C2D7B13C5428> /System/Library/PrivateFrameworks/AppleJPEG.framework/Versions/A/AppleJPEG
                          0x7fff8a8fe000 -     0x7fff8a8fffff  libsystem_blocks.dylib (65) <1244D9D5-F6AA-35BB-B307-86851C24B8E5> /usr/lib/system/libsystem_blocks.dylib
                          0x7fff8a923000 -     0x7fff8a92bfff  com.apple.AppleSRP (5.0 - 1) <840A5C20-6452-36BB-ACF7-29BA6CBF7C48> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                          0x7fff8ac35000 -     0x7fff8ac35fff  libmetal_timestamp.dylib (600.0.44.1) <6576F284-BACA-332A-A6E7-FA1C347636E3> /System/Library/PrivateFrameworks/GPUCompiler.framework/libmetal_timestamp.dylib
                          0x7fff8ad93000 -     0x7fff8af5cff7  com.apple.ImageIO.framework (3.3.0 - 1450) <14333D7C-1DB1-3928-AF9C-9470235ED2CF> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                          0x7fff8af5d000 -     0x7fff8af68ff7  libChineseTokenizer.dylib (16) <79B8C67A-3061-3C78-92CD-4650719E68D4> /usr/lib/libChineseTokenizer.dylib
                          0x7fff8afc1000 -     0x7fff8b02cff7  com.apple.framework.CoreWLAN (11.0 - 1101.20) <3B35C543-7FCE-333F-80C1-432FA41DDCDE> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                          0x7fff8b2b2000 -     0x7fff8b2b7fff  com.apple.TCC (1.0 - 1) <F5EEB2D3-9517-3975-97BE-22CB8E11B8A3> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                          0x7fff8b3db000 -     0x7fff8b42cff7  libcups.2.dylib (435.2) <91584A40-214D-33E8-A613-CE22289037C8> /usr/lib/libcups.2.dylib
                          0x7fff8b434000 -     0x7fff8b448fff  com.apple.CoreDuetDaemonProtocol (1.0 - 1) <1D60D60C-914A-3BAB-8607-79F68F4C712E> /System/Library/PrivateFrameworks/CoreDuetDaemonProtocol.framework/Versions/A/CoreDuetDae monProtocol
                          0x7fff8b451000 -     0x7fff8b49dffb  com.apple.HIServices (1.22 - 550) <6B76B41C-CF5A-34C4-89F4-EFD7CA3D1C9D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                          0x7fff8b4c0000 -     0x7fff8b4d7fff  libmarisa.dylib (4) <E4919B03-D9BD-3AF8-B436-C415C98E3F0A> /usr/lib/libmarisa.dylib
                          0x7fff8b4d8000 -     0x7fff8b4f4ff7  libextension.dylib (78) <FD952DA6-BBEC-3CB6-98B3-E1D111C5C54E> /usr/lib/libextension.dylib
                          0x7fff8b4f5000 -     0x7fff8b4f8ff7  libCoreFSCache.dylib (119.5) <2389D7DA-B8EF-3EB4-AAAF-FBEDE01CDECA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                          0x7fff8b4f9000 -     0x7fff8b4fbfff  libCVMSPluginSupport.dylib (12.1) <D81B3D8D-B83F-3918-BD4B-6C794A30AF9F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                          0x7fff8b53a000 -     0x7fff8b588ff7  libstdc++.6.dylib (104.1) <76E2AFB1-07E5-3F19-B692-F6E21B7E470D> /usr/lib/libstdc++.6.dylib
                          0x7fff8b590000 -     0x7fff8b594fff  com.apple.CommonPanels (1.2.6 - 96) <4AE7E5AE-55B3-37FA-9BDE-B23147ADA2E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                          0x7fff8b595000 -     0x7fff8b5a4ffb  com.apple.LangAnalysis (1.7.0 - 1.7.0) <18D21123-A3E7-3851-974A-08E5D4540475> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                          0x7fff8bf0f000 -     0x7fff8bfa4fff  com.apple.ink.framework (10.9 - 214) <1F76CF36-3F79-36B8-BC37-C540AF34B338> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                          0x7fff8c050000 -     0x7fff8c16dfff  libsqlite3.dylib (216.4) <DC3D59E7-91A3-374F-957C-6699729CD82B> /usr/lib/libsqlite3.dylib
                          0x7fff8c3db000 -     0x7fff8c3ddfff  com.apple.loginsupport (1.0 - 1) <9B2F5F9B-ED38-313F-B798-D2B667BCD6B5> /System/Library/PrivateFrameworks/login.framework/Versions/A/Frameworks/loginsupport.fram ework/Versions/A/loginsupport
                          0x7fff8c3de000 -     0x7fff8c80cfff  com.apple.vision.FaceCore (3.3.1 - 3.3.1) <E54028EA-4217-3078-A2B1-C52E4214D59E> /System/Library/PrivateFrameworks/FaceCore.framework/Versions/A/FaceCore
                          0x7fff8cbd1000 -     0x7fff8cbedff3  libresolv.9.dylib (60) <A650B5C8-1950-36A0-86D1-0B2465318BFA> /usr/lib/libresolv.9.dylib
                          0x7fff8d556000 -     0x7fff8d558ff7  libquarantine.dylib (80) <0F4169F0-0C84-3A25-B3AE-E47B3586D908> /usr/lib/system/libquarantine.dylib
                          0x7fff8d5ec000 -     0x7fff8d62dff7  libGLU.dylib (12.1) <CD7A5916-3E3C-3EF3-A275-B281016B99CB> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                          0x7fff8d62e000 -     0x7fff8d62eff7  libunc.dylib (29) <DDB1E947-C775-33B8-B461-63E5EB698F0E> /usr/lib/system/libunc.dylib
                          0x7fff8d62f000 -     0x7fff8d67dfff  libcurl.4.dylib (90) <12E01E4B-24C9-394C-9D2C-85CF85D5F459> /usr/lib/libcurl.4.dylib
                          0x7fff8dd8c000 -     0x7fff8dd8ffff  libCoreVMClient.dylib (119.5) <560D70FB-709F-3030-96C9-F249FCB7DA6D> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                          0x7fff8dd90000 -     0x7fff8dd90fff  com.apple.Cocoa (6.11 - 22) <807787AB-D231-3F51-A99B-A9314623C571> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                          0x7fff8dd91000 -     0x7fff8dda6ff3  libCGInterfaces.dylib (317.9) <473434E1-5269-3077-A047-D05E024AE631> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/Libraries/libCGInterfaces.dylib
                          0x7fff8dda7000 -     0x7fff8de02ff7  libTIFF.dylib (1450) <5BB63D48-B807-31FB-B13F-05C60584707E> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                          0x7fff8e190000 -     0x7fff8e1a0ff3  com.apple.ProtocolBuffer (1 - 243) <BAE5E5C9-DD59-3BB8-9741-EEFC5E3046EE> /System/Library/PrivateFrameworks/ProtocolBuffer.framework/Versions/A/ProtocolBuffer
                          0x7fff8e1a1000 -     0x7fff8e1a4ffb  libScreenReader.dylib (426.42) <16FC79D1-4573-3E90-945F-CBA22D5185FD> /usr/lib/libScreenReader.dylib
                          0x7fff8e1c5000 -     0x7fff8e1cdfff  com.apple.NetFS (6.0 - 4.0) <842A5346-24C3-3F22-9ECF-E586A10EA1F2> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                          0x7fff8e1cf000 -     0x7fff8e243ff7  com.apple.Heimdal (4.0 - 2.0) <5D365381-8B5E-3259-8867-FC4A7D307BDE> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                          0x7fff8e259000 -     0x7fff8e275ff7  libsystem_malloc.dylib (67.40.1) <5748E8B2-F81C-34C6-8B13-456213127678> /usr/lib/system/libsystem_malloc.dylib
                          0x7fff8e276000 -     0x7fff8e41cff7  com.apple.audio.toolbox.AudioToolbox (1.13 - 1.13) <082319FC-59F2-3D36-AC9B-94759724E302> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                          0x7fff8e41d000 -     0x7fff8e42bfff  com.apple.opengl (12.1.0 - 12.1.0) <BBC4458E-12FC-3C9B-BF7E-6985D61C7A67> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                          0x7fff8e42c000 -     0x7fff8e46eff7  com.apple.Metal (56.6 - 56.6) <2B2C0F78-20B8-3878-B9B1-DE18BB92919D> /System/Library/Frameworks/Metal.framework/Versions/A/Metal
                          0x7fff8e46f000 -     0x7fff8e4d6fff  com.apple.framework.CoreWiFi (11.0 - 1101.20) <993592F1-B3F1-3FAD-87BD-EA83C361BCCF> /System/Library/PrivateFrameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                          0x7fff8f011000 -     0x7fff8f048ff7  com.apple.LDAPFramework (2.4.28 - 194.5) <9AE33BF2-FB17-342D-8F1E-5F83C6E6EB69> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                          0x7fff8f8bf000 -     0x7fff8f8c1ff7  com.apple.xpc.ServiceManagement (1.0 - 1) <D96D7A6D-EDEB-35EE-B5D9-E33A3BF011B5> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                          0x7fff8f8c2000 -     0x7fff8f8ebffb  libRIP.A.dylib (957) <5F18F20D-5921-3314-A9F8-F1B1CB62C83D> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/Resources/libRIP.A.dylib
                          0x7fff8fa36000 -     0x7fff8fa5afff  com.apple.MultitouchSupport.framework (304.12 - 304.12) <65CB7653-EACD-3ADB-ABB6-2E0671708301> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                          0x7fff8fa91000 -     0x7fff8faa2fff  libcmph.dylib (6) <BA4BF2C6-7F4E-33B8-9DD7-619C9EB83ECF> /usr/lib/libcmph.dylib
                          0x7fff8fb80000 -     0x7fff8fbf5fff  com.apple.framework.IOKit (2.0.2 - 1179.50.2) <A509D3AE-9D48-31B7-89C7-326A7A2007B2> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                          0x7fff900ac000 -     0x7fff900b5ff7  com.apple.CommonAuth (4.0 - 2.0) <4B8673E1-3697-3FE2-8D30-AC7AC5D4F8BF> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                          0x7fff900b6000 -     0x7fff900c2fff  com.apple.speech.synthesis.framework (5.4.12 - 5.4.12) <71DA00B8-5EA2-326B-8814-59DB25512F65> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                          0x7fff900de000 -     0x7fff90378ff3  com.apple.security (7.0 - 57337.50.23) <8B6CF71D-A63E-34C9-9227-0AACAB643584> /System/Library/Frameworks/Security.framework/Versions/A/Security
                          0x7fff903c0000 -     0x7fff903f8ff7  com.apple.RemoteViewServices (2.0 - 101) <B2881449-8CFE-3D1C-B4BF-155640392533> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                          0x7fff90470000 -     0x7fff9047bfff  com.apple.CrashReporterSupport (10.11 - 718) <05892B57-F2CD-3C84-B984-0417F6B361DB> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                          0x7fff9047c000 -     0x7fff9048cfff  libSparseBLAS.dylib (1162.2) <6F591A0F-80D0-384D-8304-B035C4ED1BBD> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libSparseBLAS.dylib
                          0x7fff90636000 -     0x7fff90aacfff  com.apple.CoreFoundation (6.9 - 1258.1) <943A1383-DA6A-3DC0-ABCD-D9AEB3D0D34D> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                          0x7fff90ab2000 -     0x7fff90abafef  libsystem_platform.dylib (74.40.2) <29A905EF-6777-3C33-82B0-6C3A88C4BA15> /usr/lib/system/libsystem_platform.dylib
                          0x7fff90b4e000 -     0x7fff91db6ff7  com.apple.CoreGraphics (1.600.0 - 957) <0AD5EC17-569E-3864-A637-AD720F5AE0BE> /System/Library/Frameworks/CoreGraphics.framework/Versions/A/CoreGraphics
                          0x7fff91db9000 -     0x7fff91dc2ff7  libsystem_pthread.dylib (138.10.4) <3DD1EF4C-1D1B-3ABF-8CC6-B3B1CEEE9559> /usr/lib/system/libsystem_pthread.dylib
                          0x7fff91dca000 -     0x7fff91e28fff  com.apple.CoreServices.OSServices (728.12 - 728.12) <776EBD4F-7052-377F-A70D-E2FDBD465A5E> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                          0x7fff91e29000 -     0x7fff91e3aff7  libsystem_trace.dylib (201.10.3) <F00E92E4-DBDA-3749-B5B3-0C3FBBABA1CB> /usr/lib/system/libsystem_trace.dylib
                          0x7fff91fd5000 -     0x7fff91fdbfff  com.apple.IOAccelerator (205.10 - 205.10) <E46ED853-C2CC-3F29-A7DD-5E9351A2E754> /System/Library/PrivateFrameworks/IOAccelerator.framework/Versions/A/IOAccelerator
                          0x7fff91fdc000 -     0x7fff91fdcfff  com.apple.ApplicationServices (48 - 48) <ADD57D3A-142F-3EF5-BFD8-EACD82164884> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                          0x7fff91fe7000 -     0x7fff921f4fff  libicucore.A.dylib (551.51.3) <5BC80F94-C90D-3175-BD96-FF1DC222EC9C> /usr/lib/libicucore.A.dylib
                          0x7fff921fd000 -     0x7fff92252fff  com.apple.AE (701 - 701) <AD492742-F884-386B-A450-FAC281B9FFA4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                          0x7fff92253000 -     0x7fff9227cfff  libc++abi.dylib (125) <DCCC8177-3D09-35BC-9784-2A04FEC4C71B> /usr/lib/libc++abi.dylib
                          0x7fff923fb000 -     0x7fff923fbfff  com.apple.CoreServices (728.12 - 728.12) <A4FFF004-53B0-3EAC-A13F-5416BFFD8886> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                          0x7fff92a2f000 -     0x7fff92a38ff3  libsystem_notify.dylib (150.40.1) <D48BDE34-0F7E-34CA-A0FF-C578E39987CC> /usr/lib/system/libsystem_notify.dylib
                          0x7fff92a39000 -     0x7fff92a73ff7  com.apple.DebugSymbols (132 - 132) <23A42C53-B941-3871-9EE2-4C87A46005B5> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                          0x7fff92a74000 -     0x7fff92afdff7  com.apple.PerformanceAnalysis (1.0 - 1) <2064F7E8-5C3D-3E18-8029-2D832D13E2A2> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                          0x7fff92afe000 -     0x7fff92b38fff  com.apple.QD (3.12 - 302) <0FE53180-2895-3D14-A1E7-F82DE1D106E1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                          0x7fff92b39000 -     0x7fff92f3bfff  libLAPACK.dylib (1162.2) <42238ED4-6B7A-39D0-BFF2-304A0C287213> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                          0x7fff92f70000 -     0x7fff92f78fff  libcopyfile.dylib (127) <A48637BC-F3F2-34F2-BB68-4C65FD012832> /usr/lib/system/libcopyfile.dylib
                          0x7fff92fa7000 -     0x7fff92fecff7  com.apple.coreservices.SharedFileList (24.4 - 24.5) <1D2AD77B-778F-3253-A295-3D0A32A8121C> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SharedFileList.fr amework/Versions/A/SharedFileList
                          0x7fff9300b000 -     0x7fff930affff  com.apple.Bluetooth (4.4.5 - 4.4.5f3) <141F2C36-70B6-32D3-A556-7A605832CDB3> /System/Library/Frameworks/IOBluetooth.framework/Versions/A/IOBluetooth
                          0x7fff930b0000 -     0x7fff930d5ff7  libPng.dylib (1450) <EB65B96A-B190-36A8-9F9D-F3A3020B267D> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                          0x7fff930d6000 -     0x7fff93220ff7  com.apple.coreui (2.1 - 366.1) <8138636F-A0A7-31C7-896C-5F5747FA1B2A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                          0x7fff933e1000 -     0x7fff933e1ff7  liblaunch.dylib (765.50.8) <834ED605-5114-3641-AA4D-ECF31B801C50> /usr/lib/system/liblaunch.dylib
                          0x7fff933eb000 -     0x7fff93414fff  com.apple.ProtectedCloudStorage (1.0 - 1) <7436B2B3-943A-3500-B099-80F133B3E002> /System/Library/PrivateFrameworks/ProtectedCloudStorage.framework/Versions/A/ProtectedClo udStorage
                          0x7fff935c4000 -     0x7fff936e9fff  com.apple.LaunchServices (728.12 - 728.12) <F5AB56CD-CF33-33F0-A48D-372551714E77> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                          0x7fff936ec000 -     0x7fff9378cfff  com.apple.Metadata (10.7.0 - 972.34) <A93B485D-094C-3024-8CBB-D9E035FB83C4> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                          0x7fff9379d000 -     0x7fff937bfff7  com.apple.Sharing (442.13.6 - 442.13.6) <DDD2811C-6ECB-32F2-8EE1-69BF9657B4A8> /System/Library/PrivateFrameworks/Sharing.framework/Versions/A/Sharing
                          0x7fff937c0000 -     0x7fff937d3fff  com.apple.CoreBluetooth (1.0 - 1) <E54CA9A2-A5C6-30C5-9D6E-8472DBA9371E> /System/Library/Frameworks/CoreBluetooth.framework/Versions/A/CoreBluetooth
                          0x7fff93818000 -     0x7fff9381fff7  libcompiler_rt.dylib (62) <A13ECF69-F59F-38AE-8609-7B731450FBCD> /usr/lib/system/libcompiler_rt.dylib
                          0x7fff93830000 -     0x7fff9392cff7  libFontParser.dylib (158.6) <267A9AE4-4138-3112-8D73-BDFDC96568FF> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                          0x7fff93d3a000 -     0x7fff93d3dfff  com.apple.IOSurface (108.2.1 - 108.2.1) <A0037B0A-277A-393E-9BF6-688595BD564D> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                          0x7fff93f08000 -     0x7fff93fb8fff  com.apple.backup.framework (1.7.4 - 1.7.4) <F304E9D1-991A-379E-9659-BF85C35B4808> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                          0x7fff9494f000 -     0x7fff94bf5ff7  com.apple.CoreData (120 - 641.3) <A29A5491-6169-372B-828F-84EE0CFD4BC4> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                          0x7fff94bf6000 -     0x7fff94bf6fff  libenergytrace.dylib (10.40.1) <0A491CA7-3451-3FD5-999A-58AB4362682B> /usr/lib/libenergytrace.dylib
                          0x7fff94c24000 -     0x7fff94c2aff7  com.apple.speech.recognition.framework (5.1.1 - 5.1.1) <9E5A980A-F455-32D5-BBEE-3BD6018CC45E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                          0x7fff94c2b000 -     0x7fff94c42ff7  libsystem_coretls.dylib (83.40.5) <C90DAE38-4082-381C-A185-2A6A8B677628> /usr/lib/system/libsystem_coretls.dylib
                          0x7fff95335000 -     0x7fff95689fff  com.apple.Foundation (6.9 - 1259) <71A9D3A0-0B1F-3E3A-86F3-1486365A6EF2> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                          0x7fff9568a000 -     0x7fff95694fff  com.apple.NetAuth (6.0 - 6.0) <D692B1EF-534F-3892-8E2F-2BBA7C8AFD74> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                          0x7fff95acf000 -     0x7fff95af3ff7  libJPEG.dylib (1450) <33C07EEE-95CB-33F7-87C1-09CE82F1E478> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                          0x7fff95af4000 -     0x7fff95b44ff7  com.apple.Symbolication (1.4 - 58044) <F70BF765-FBE9-3F1E-85CA-BB2F8E53E8C2> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                          0x7fff95b45000 -     0x7fff95c72ff3  com.apple.CoreText (352.0 - 494.11) <08E8640E-6602-3A00-BC28-94235FD311B4> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                          0x7fff95cac000 -     0x7fff95caeff7  libRadiance.dylib (1450) <0C0DACDA-2040-3D22-A8E7-7035AB624E4A> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                          0x7fff95ea7000 -     0x7fff95ea8ffb  libSystem.B.dylib (1226.10.1) <C5D09FE1-CC70-383E-AC27-18602F2EDEC4> /usr/lib/libSystem.B.dylib
                          0x7fff95eb8000 -     0x7fff96078ffb  libBLAS.dylib (1162.2) <B4C21826-5EB3-3C6D-B75D-CA4886E2B6A6> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                          0x7fff96319000 -     0x7fff96321ffb  libsystem_dnssd.dylib (625.50.5) <4D10E12B-59B5-386F-82DA-326F18028F0A> /usr/lib/system/libsystem_dnssd.dylib
                          0x7fff96335000 -     0x7fff96388ff7  libc++.1.dylib (120.1) <8FC3D139-8055-3498-9AC5-6467CB7F4D14> /usr/lib/libc++.1.dylib
                          0x7fff96389000 -     0x7fff963b2ff7  libxslt.1.dylib (14.2) <6E8D0F06-9086-32D3-9D87-3870A1CE9E99> /usr/lib/libxslt.1.dylib
                          0x7fff966b5000 -     0x7fff966b5fff  com.apple.audio.units.AudioUnit (1.13 - 1.13) <93C1D642-37D4-3692-AD35-DCAD04F9610B> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                          0x7fff966b6000 -     0x7fff966b8ff7  com.apple.securityhi (9.0 - 55006) <1E7BE52B-97EA-371A-AECA-1EE2AD246D8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                          0x7fff96715000 -     0x7fff96744ff7  com.apple.DictionaryServices (1.2 - 250.3) <30250542-CBAA-39C1-91AA-B57A5DE17594> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                          0x7fff96747000 -     0x7fff96763fff  com.apple.GenerationalStorage (2.0 - 239.1) <8C821448-4294-3736-9CEF-467C93785CB9> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                          0x7fff96764000 -     0x7fff96acf657  libobjc.A.dylib (680) <D55D5807-1FBE-32A5-9105-44D7AFE68C27> /usr/lib/libobjc.A.dylib
                          0x7fff96ad0000 -     0x7fff96d57ff3  com.apple.CFNetwork (760.5.1 - 760.5.1) <EE9426D1-F11C-3DD4-AE08-EA29AEB27177> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                          0x7fff96d58000 -     0x7fff96e3eff7  libcrypto.0.9.8.dylib (59.40.2) <2486D801-C756-3488-B519-1AA6807E8948> /usr/lib/libcrypto.0.9.8.dylib
                          0x7fff96e3f000 -     0x7fff96eb6ff7  com.apple.MMCS (1.3 - 357.1) <549FBEFC-55F7-3101-BF51-A0B1F7CF2B46> /System/Library/PrivateFrameworks/MMCS.framework/Versions/A/MMCS
                          0x7fff96eb7000 -     0x7fff96ebffff  com.apple.frameworks.CoreDaemon (1.3 - 1.3) <CC53DC12-9231-3C4F-921B-9A770D463323> /System/Library/PrivateFrameworks/CoreDaemon.framework/Versions/B/CoreDaemon
                          0x7fff96ec0000 -     0x7fff96f2ffff  com.apple.datadetectorscore (7.0 - 460) <FA46DEE8-B25B-3E84-B067-6A31193A0885> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                          0x7fff96fd9000 -     0x7fff96fe4fff  libGL.dylib (12.1) <70D51643-04AC-3400-8F11-A6FC25985289> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                          0x7fff97047000 -     0x7fff97078fff  com.apple.GSS (4.0 - 2.0) <B490333A-3B3E-397A-AD75-68846E9A9140> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                          0x7fff97086000 -     0x7fff970ecff7  libsystem_network.dylib (583.50.1) <B52DAB73-92DC-3DA7-B9F4-B899D66445C1> /usr/lib/system/libsystem_network.dylib
                          0x7fff970f0000 -     0x7fff971e2ff7  libiconv.2.dylib (44) <F05A0A5A-92A9-3668-8F20-F27CBDA26BE9> /usr/lib/libiconv.2.dylib
                          0x7fff971e3000 -     0x7fff971e8ff7  libmacho.dylib (875.1) <318264FA-58F1-39D8-8285-1F6254EE410E> /usr/lib/system/libmacho.dylib
                          0x7fff971e9000 -     0x7fff97235ff7  com.apple.corelocation (1486.17 - 1615.38) <6336CFC5-9D7D-3B76-B263-56DD6EBD0B8D> /System/Library/Frameworks/CoreLocation.framework/Versions/A/CoreLocation
                          0x7fff9723b000 -     0x7fff97268fff  libdispatch.dylib (501.40.12) <C7499857-61A5-3D7D-A5EA-65DCC8C3DF92> /usr/lib/system/libdispatch.dylib
                          0x7fff9747f000 -     0x7fff97481fff  com.apple.CoreDuetDebugLogging (1.0 - 1) <7C932160-AC9C-3173-900F-98138E829CB3> /System/Library/PrivateFrameworks/CoreDuetDebugLogging.framework/Versions/A/CoreDuetDebug Logging
                          0x7fff97494000 -     0x7fff974a6fff  libsasl2.2.dylib (209) <11C7D200-0CA5-30F4-A19A-178CA81D48FE> /usr/lib/libsasl2.2.dylib
                          0x7fff974a7000 -     0x7fff974b5fff  libxar.1.dylib (302) <03207F66-2C4A-3DBD-8D81-70F4C85903C4> /usr/lib/libxar.1.dylib
                          0x7fff974d9000 -     0x7fff974dafff  libsystem_secinit.dylib (20) <32B1A8C6-DC84-3F4F-B8CE-9A52B47C3E6B> /usr/lib/system/libsystem_secinit.dylib
                          0x7fff974db000 -     0x7fff974e7ff7  com.apple.OpenDirectory (10.11 - 194) <31A67AD5-5CC2-350A-96D7-821DF4BC4196> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                          0x7fff98ab3000 -     0x7fff98ac9ff7  libLinearAlgebra.dylib (1162.2) <FFE54EDF-F06F-3C0A-864A-4CA7BBFD4B2D> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLinearAlgebra.dylib
                      External Modification Summary:
                        Calls made by other processes targeting this process:
                          task_for_pid: 2
                          thread_create: 0
                          thread_set_state: 0
                        Calls made by this process:
                          task_for_pid: 0
                          thread_create: 0
                          thread_set_state: 0
                        Calls made by all processes on this machine:
                          task_for_pid: 1292
                          thread_create: 0
                          thread_set_state: 0
                      VM Region Summary:
                      ReadOnly portion of Libraries: Total=515.7M resident=0K(0%) swapped_out_or_unallocated=515.7M(100%)
                      Writable regions: Total=204.9M written=0K(0%) resident=0K(0%) swapped_out=0K(0%) unallocated=204.9M(100%)
                                                      VIRTUAL   REGION
                      REGION TYPE                        SIZE    COUNT (non-coalesced)
                      Accelerate.framework               128K        2
                      Activity Tracing                  2048K        2
                      CG backing stores                 1488K        2
                      CG shared images                   176K        6
                      CoreAnimation                       28K        4
                      CoreUI image file                  128K        2
                      Dispatch continuations            16.0M        2
                      Image IO                          1480K        2
                      Kernel Alloc Once                    8K        3
                      MALLOC                           132.5M       32
                      MALLOC guard page                   32K        7
                      MALLOC_LARGE (reserved)           7436K        3         reserved VM address space (unallocated)
                      Memory Tag 242                      12K        2
                      Process Corpse Info               2048K        2
                      STACK GUARD                       56.1M       19
                      Stack                             16.2M       23
                      VM_ALLOCATE                       3128K        8
                      __DATA                            38.9M      628
                      __IMAGE                            528K        2
                      __LINKEDIT                       133.5M      251
                      __TEXT                           382.2M      458
                      __UNICODE                          552K        2
                      mapped file                       46.1M       14
                      shared memory                     16.3M       11
                      TOTAL                            856.6M     1463
                      TOTAL, minus reserved VM space   849.3M     1463
                      Model: MacBookPro10,1, BootROM MBP101.00EE.B0A, 4 processors, Intel Core i7, 2.4 GHz, 8 GB, SMC 2.3f36
                      Graphics: Intel HD Graphics 4000, Intel HD Graphics 4000, Built-In
                      Graphics: NVIDIA GeForce GT 650M, NVIDIA GeForce GT 650M, PCIe, 1024 MB
                      Memory Module: BANK 0/DIMM0, 4 GB, DDR3, 1600 MHz, 0x802C, 0x384A54463235363634485A2D3147364D3120
                      Memory Module: BANK 1/DIMM0, 4 GB, DDR3, 1600 MHz, 0x802C, 0x384A54463235363634485A2D3147364D3120
                      AirPort: spairport_wireless_card_type_airport_extreme (0x14E4, 0xEF), Broadcom BCM43xx 1.0 (7.21.95.175.1a6)
                      Bluetooth: Version 4.4.5f3 17904, 3 services, 27 devices, 1 incoming serial ports
                      Network Service: USB Ethernet, Ethernet, en2
                      Network Service: Wi-Fi, AirPort, en0
                      PCI Card: pci1b21,612, AHCI Controller, Thunderbolt@195,0,0
                      Serial ATA Device: APPLE SSD SD256E, 251 GB
                      Serial ATA Device: WDC WD20NPVX-11EA4T0, 2 TB
                      USB Device: USB 2.0 Bus
                      USB Device: Hub
                      USB Device: USB2.0 Hub
                      USB Device: Datacolor Spyder4
                      USB Device: Apple USB Ethernet Adapter
                      USB Device: FaceTime HD Camera (Built-in)
                      USB Device: Hub
                      USB Device: Hub
                      USB Device: Apple Internal Keyboard / Trackpad
                      USB Device: BRCM20702 Hub
                      USB Device: Bluetooth USB Host Controller
                      USB Device: USB 3.0 Bus
                      USB Device: Hub in Apple Pro Keyboard
                      USB Device: ShuttlePRO v2
                      USB Device: USB Device
                      USB Device: Apple Pro Keyboard
                      Thunderbolt Bus: MacBook Pro, Apple Inc., 23.4
                      Thunderbolt Device: My Passport Pro, Western Digital, 3, 7.1
                      • 8. Re: Latest Indesign crashing on startup
                        JimMcAndrew Level 1
                        Hello ohmnath,
                        My issue is back. I posted complete crash log below. Any ideas?
                        • 9. Re: Latest Indesign crashing on startup
                          ohmnath Adobe Employee
                          Hi Jim,
                          Is the app crashing at launch or when you perform a certain workflow?
                          Regards,
                          Om
                          • 11. Re: Latest Indesign crashing on startup
                            Hi Jim,
                            Please follow the steps mentioned below and check (it is to manually reset the preferences :
                            1. Navigate to User Library ( Press and hold Option key to show the user library from the "Go" menu) > Caches > Adobe InDesign > Rename the Version 11.0 folder to "Old Version 11.0"
                            2. Navigate to User Library  > Preferences > Adobe InDesign > Rename the Version 11.0 folder to "Old Version 11.0"
                            3. Re launch ID and check.
                            Regards,
                            Om
                            • 12. Re: Latest Indesign crashing on startup
                              JimMcAndrew Level 1
                              thanks Om,
                              I've done this several times over the past week. It'll work for a day or so and then start crashing again.
                              Jim
