4 Replies Latest reply on Jun 23, 2016 12:38 PM by kglad
    How can I remove angled sections of an element?
    Netirrigate_Hauke
      I have an element from which I would like to remove sections at an angle. However, when I try to either use the eraser tool or the Polygon Selection Tool to remove the desired section, it defaults to removing a rectangular section. That's as good as I can explain it with words so please see the images below to see what I mean.
      Original graphic.
      Area I want to cut out selected with polygon tool while polygon tool is still active (aka mouse button still pressed).
      Area selected after polygon tool is applied (aka mouse button released).
      Area that is cut out using polygon tool.
      Area removed by eraser while eraser is still active (aka mouse button still pressed).
      Area that is removed after eraser tool is applied (aka mouse button released).
