2 Replies Latest reply on Jun 25, 2016 12:05 PM by 1193581561
    I can't build a PhoneGap app.
    1193581561 Level 1
      I just created a new PhoneGap application, tried to build it with PhoneGap cli and the following error occured. But it builds without errors if I use build.phonegap.com. How to build it by PhoneGap cli?
      PS P:\Applications\Android\MyPhoneGapFirstApp> phonegap build android
      (node:3984) fs: re-evaluating native module sources is not supported. If you are using the graceful-fs module, please update it to a more recent version.
      [phonegap] executing 'cordova build android ' ...
      ANDROID_HOME=C:\Users\Хакер\AppData\Local\Android\sdk
      JAVA_HOME=C:\Program Files\java\jdk1.7.0_25
      :preBuild
      UP-TO-DATE
      :preDebugBuild
      UP-TO-DATE
      :checkDebugManifest
      :CordovaLib:preBuild
      UP-TO-DATE
      :CordovaLib:preDebugBuild
      UP-TO-DATE
      :CordovaLib:compileDebugNdk
      UP-TO-DATE
      :CordovaLib:compileLint
      :CordovaLib:copyDebugLint
      UP-TO-DATE
      :CordovaLib:mergeDebugProguardFiles
      :CordovaLib:packageDebugRenderscript
      UP-TO-DATE
      :CordovaLib:checkDebugManifest
      :CordovaLib:prepareDebugDependencies
      :CordovaLib:compileDebugRenderscript
      :CordovaLib:generateDebugResValues
      :CordovaLib:generateDebugResources
      :CordovaLib:packageDebugResources
      :CordovaLib:compileDebugAidl
      :CordovaLib:generateDebugBuildConfig
      :CordovaLib:generateDebugAssets
      UP-TO-DATE
      :CordovaLib:mergeDebugAssets
      :CordovaLib:processDebugManifest
      :CordovaLib:processDebugResources
      :CordovaLib:generateDebugSources
      :CordovaLib:compileDebugJavaWithJavac
      Note: Some input files use or override a deprecated API.
      Note: Recompile with -Xlint:deprecation for details.
      :CordovaLib:processDebugJavaRes
      UP-TO-DATE
      :CordovaLib:transformResourcesWithMergeJavaResForDebug
      :CordovaLib:transformClassesAndResourcesWithSyncLibJarsForDebug
      :CordovaLib:mergeDebugJniLibFolders
      :CordovaLib:transformNative_libsWithMergeJniLibsForDebug
      :CordovaLib:transformNative_libsWithSyncJniLibsForDebug
      :CordovaLib:bundleDebug
      :prepareAndroidCordovaLibUnspecifiedDebugLibrary
      :compileDebugAidl
      UP-TO-DATE
      :mergeDebugAssets
      :mergeDebugResources
      Note: Some input files use unchecked or unsafe operations.
      Note: Recompile with -Xlint:unchecked for details.
      :compileDebugNdk
      UP-TO-DATE
      :compileDebugSources
      :transformClassesWithDexForDebug
      java.lang.UnsupportedClassVersionError: com/android/dx/command/Main : Unsupported major.minor version 52.0
              at java.lang.ClassLoader.defineClass1(Native Method)
              at java.lang.ClassLoader.defineClass(ClassLoader.java:792)
              at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
              at java.net.URLClassLoader.defineClass(URLClassLoader.java:449)
              at java.net.URLClassLoader.access$100(URLClassLoader.java:71)
              at java.net.URLClassLoader$1.run(URLClassLoader.java:361)
              at java.net.URLClassLoader$1.run(URLClassLoader.java:355)
              at java.security.AccessController.doPrivileged(Native Method)
              at java.net.URLClassLoader.findClass(URLClassLoader.java:354)
              at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
              at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:308)
              at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
              at sun.launcher.LauncherHelper.checkAndLoadMain(LauncherHelper.java:482)
      Exception in thread "main"
      FAILED
      FAILURE:
      Build failed with an exception.
      * What went wrong:
      Execution failed for task ':transformClassesWithDexForDebug'.
      com.android.ide.common.process.ProcessException: org.gradle.process.internal.ExecException: Process 'command 'C:\Program Files\Java\jdk1.7.0_25\bin\java.exe'' finished with non-zero exit value 1
      * Try:
      Run with
      --stacktrace option to get the stack trace. Run with --info or --debug option to get more log output.
      BUILD FAILED
      Total time: 9.468 secs
      Error: Error code 1 for command: cmd with args: /s,/c,"P:\Applications\Android\MyPhoneGapFirstApp\platforms\android\gradlew cdvBuildDebug -b P:\Applications\Android\MyPhoneGapFirstApp\platforms\android\build.gradle -Dorg.gradle.daemon=true -Pandroid.useDeprecatedNdk=true"
      Adding the following code to gradle.build doesn't work:
      dexOptions {
              javaMaxHeapSize "4g"
      This also doesn't work:
      android {
          compileSdkVersion 21
          buildToolsVersion "21.1.0"
          defaultConfig {
              minSdkVersion 14
              targetSdkVersion 21
              // Enabling multidex support.
              multiDexEnabled true
      dependencies {
        compile 'com.android.support:multidex:1.0.0'
