2 Replies Latest reply on Jan 15, 2009 5:39 AM by Newsgroup_User
    Actionscript 2.0/Flash 8: Starting sounds issue.
    Level 7
      Greetings,
      I have a function that displays a explosion movie clip and plays a sound.
      The bigger the movie clip the more times the explosion function is called,
      this can result in the sound being played multiple
      times within a short space of time.
      The sound is attached and played as below
      var ExplosiveSound:Sound = new Sound();
      ExplosiveSound.attachSound("Explosivesound");
      _root.ExplosiveSound.start()
      I've discovered since if the sound is started again the previous sound is
      cut off for another to be started.
      I discovered the OnSoundComplete method but was unable to work out how I
      could use this to ensure that the sound is played in its entirety i.e. If a
      sound is currently being played do not start another one.
      How is it possible to ensure if a explosion sound is currently be played
      that another is not started?
      Rob
        • 1. Re: Actionscript 2.0/Flash 8: Starting sounds issue.
          Level 7
          I've done this as a workaround (see code below) are there any better
          recommendations/solutions?
          if (z == 0)
          z=1;
          _root.ExplosiveSound.start();
          _root.ExplosiveSound.onSoundComplete = function()
          z=0;
          "Rob W" <Whllrob@aol.com> wrote in message
          news:gkn14b$rc5$1@forums.macromedia.com...
          > Greetings,
          > a sound is currently being played do not start another one.
          > Thanks
          > Rob
          • 2. Re: Actionscript 2.0/Flash 8: Starting sounds issue.
            Level 7
            Quick note to say I'm now using a boolean as better suited (true/false).
            news:gkndu1$dlq$1@forums.macromedia.com...
            > if (z == 0)
            > z=1;
            > z=0;
            >> Greetings,
            >> called, this can result in the sound being played multiple
            >> Thanks
            >> Rob
