5 Replies Latest reply on Apr 9, 2017 7:03 PM by CEJLLC
    Can't install DUIK
    olic25988849
      I'm new to AE and am trying to install the Duik plugin.
      I've downloaded the installer for Mac, but when I run it, it says it can't find a valid version of AE.
      I click on the '...' button and navigate to the App folder
      And then get the following message
      As you can see from the screenshot, I clearly have AE installed.
      I am running OSX El Capitan with AE CC 2015.3 and trying to install Duik 15.08.
      Can anyone help please?
      Thanks in advance!
      Oli
        • 1. Re: Can't install DUIK
          I'm assuming that you checked with the manufacturer. If you have not I would install a previous version of AE, run the installer, then either create an alias to the folder if you are going to keep a previous version installed. or move it to the new location. It would seem the  only other option would be to wait for an updated installer.
          • 2. Re: Can't install DUIK
            olic25988849 Level 1
            Hi Rick,
            Thanks for the reply (and apologies for my late one.
            I haven't contacted the manufacturer yet, but that's a good idea so I will do now.
            Cheers
            • 3. Re: Can't install DUIK
              yoyoisjin Level 1
              Hi olic
              I had same problem
              but if you have Duik files in CC 2015 you can just copy and paste to cc2015.3
              It seems work
              but still when i try to make Auto body connect after effect just turned off...
              hm...
              • 4. Re: Can't install DUIK
                tagorixxx
                Yeah, same here, DUIK is a huge part of my workflow, at the website DUIK says this:
                So people at Adobe, can you please check this? I'm sure that a lot of character animators and motion designers would like to see this fixed.
                • 5. Re: Can't install DUIK
                  CEJLLC Level 1
                  The Installer did not work for Windows 10 either.  The Solution was:
                  • Custom Path/Program Files/Adobe/Adobe After Effects CC 2017/Support Files/Scripts/ScriptUI Panels/
                  I am not certain what the Mac equivalent is [been a while] but I do not think Duik is handled like a plug-in on a Mac either.  It is a script.  In theory I would determine where the scripts are located.
