5 Replies Latest reply on Jun 27, 2016 9:14 AM by Code One Films
    Mask offsets?
    Code One Films
      in the videocopilot plugin Saber you can select a text layer and it will make a mask outline of the text and put the saber effect on that. Then by using the 'offset end' and 'offset start' in the plugin you can make the end or start of the line shorter. as short as can be like until there is nothing left. This way you can easily make moving lines along text and stuff. I was wondering if I could use this offset thing on regular masks aswell? So completely outside of saber, nothing to do with saber, just create a mask and controll the offset? Any way to do this? Thanks a lot in advance.
