5 Replies Latest reply on Oct 4, 2016 5:15 AM by berniemiller
    CF10 Update 20 - Can not install
    creep80209 Level 1
      Working a Window 2008 R2 (64 bit) VM machine running ColdFusion 10. ColdFusion is installed to the D:\ drive. I Have been trying to patch to Update for the last 10 days.
      Initially I was able to update from 19 to 20 via the cfusion instance. Patching all 7 instances at once. The next day I decided to go and double check all the instances. I noticed that one of the instances was not updated. Let's call that one "cTest".
      I had to uninstall Update 20 for all of the instances to try and update cTest. Then I started getting 500 errors for cTest when trying to connect to the site or the CF Administrator for on port 8508.
      I done the following to try resolve this issue.
      1. Rolled back the update from 19 to 17. Then restarted the server. Still having issues. The service restarts. But, CF administrator displays a 500 Error message.
      2. Port scanned to make user there was no conflicts.
      3. Manually downloaded the JAR file from the Adobe site. I did this because I noticed that the file was try to extract from my account and not via the service account for the CF server.
      4. I opened a DOS window with "Run as Administrator" and manually tried to invoke the installer via java -jar hotfix_020.jar this seemed to install properly. But, the service fail to start and I started getting "Error 2" messages about the service.
      5. I have checked ownership of hotfix_010.jar. I made sure that it was set for the right owner invoking the file. And, the file permissions.
      The last update try was just for cTest to be updated from 17 to 20. Here are logs for that:
      Adobe_ColdFusion_10_Update_20_Install_06_28_2016_12_42_13.log
      __________________________________________________________________________
      Tue Jun 28 12:42:38 MDT 2016
      Free Memory: 216592 kB
      Total Memory: 316928 kB
      4 Command Line Args:
      0:  -i
      1:  silent
      2:  -f
      3:  D:\ColdFusion10\cTest\hf-updates/hf-10-00020.properties
      java.class.path:
          D:\ColdFusion10\cTest\hf-updates/hotfix_020.jar
      ZGUtil.CLASS_PATH:
      sun.boot.class.path:
          D:\Program Files\Java\jdk1.8.0_51\jre\lib\resources.jar
          D:\Program Files\Java\jdk1.8.0_51\jre\lib\rt.jar
          D:\Program Files\Java\jdk1.8.0_51\jre\lib\sunrsasign.jar
          D:\Program Files\Java\jdk1.8.0_51\jre\lib\jsse.jar
          D:\Program Files\Java\jdk1.8.0_51\jre\lib\jce.jar
          D:\Program Files\Java\jdk1.8.0_51\jre\lib\charsets.jar
          D:\Program Files\Java\jdk1.8.0_51\jre\lib\jfr.jar
          D:\Program Files\Java\jdk1.8.0_51\jre\classes
      java.ext.dirs:
          D:\Program Files\Java\jdk1.8.0_51\jre\lib\ext
          C:\Windows\Sun\Java\lib\ext
      java.version                  == 1.8.0_51 (Java 1)
      java.vm.name                  == Java HotSpot(TM) 64-Bit Server VM
      java.vm.vendor                == Oracle Corporation
      java.vm.version               == 25.51-b03
      java.vm.specification.name    == Java Virtual Machine Specification
      java.vm.specification.vendor  == Oracle Corporation
      java.vm.specification.version == 1.8
      java.specification.name       == Java Platform API Specification
      java.specification.vendor     == Oracle Corporation
      java.specification.version    == 1.8
      java.vendor                   == Oracle Corporation
      java.vendor.url               == http://java.oracle.com/
      java.class.version            == 52.0
      java.library.path             == D:\Program Files\Java\jdk1.8.0_51\jre\bin;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:\ Program Files (x86)\Java\jre1.8.0_91\bin;C:\Program Files\PHP\v5.3;C:\Program Files\PHP\v5.3;C:\Perl64\site\bin;C:\Perl64\bin;C:\Windows\system32;C:\Windows;C:\Windows \System32\Wbem;C:\Windows\System32\WindowsPowerShell\v1.0\;C:\Windows\idmu\common;C:\Progr am Files\Microsoft\Web Platform Installer\;C:\Program Files (x86)\Microsoft ASP.NET\ASP.NET Web Pages\v1.0\;C:\Program Files\Microsoft SQL Server\110\Tools\Binn\;D:\Program Files\ANT\bin;D:\php;;;D:\ColdFusion10\cTest\lib;D:\ColdFusion10\cTest\jintegra\bin;D:\Co ldFusion10\cTest\jintegra\bin\international;D:\ColdFusion10\cTest\lib\oosdk\classes\win;.
      java.compiler                 == null
      java.home                     == D:\Program Files\Java\jdk1.8.0_51\jre
      java.io.tmpdir                == C:\Users\INPNRP~1\AppData\Local\Temp\
      os.name                       == Windows Server 2008 R2
      os.arch                       == amd64
      os.version                    == 6.1
      path.separator                == ;
      file.separator                == \
      file.encoding                 == Cp1252
      user.name                     == CFRunAccount
      user.home                     == C:\Users\CFRunAccount
      user.dir                      == D:\ColdFusion10\cTest\bin
      user.language                 == en
      user.region                   == null
      Installed Feature(s) Multi, J2EE of Adobe ColdFusion 10 Update 20
      Install Begin: JUNE 28, 2016 12:42:01 PM MDT
      Install End: JUNE 28, 2016 12:42:37 PM MDT
      Installed by InstallAnywhere 17.0 Premier Build 5123
      User Interactions
      Summary
      Installation: Unsuccessful.
      350 Successes
      0 Warnings
      5 NonFatalErrors
      7 FatalErrors
      Action Notes:
      Moving files failed:: Failed to back up the previous hotfix files. Retry installation after ensuring that the server is not running or files are not locked by the server.
      Failed to copy hotfix files:C:\Users\CFRunAccount\844358.tmp\dist\cfusion: Failed to copy the hotfix files to the target location. Retry installation after ensuring that the server is not running or files are not locked by the server.
      Failed to delete directory: Ensure that the server is not running or files are not locked by the server.
      Install Log Detail:
      Check Disk Space:         D:\ColdFusion10
                                Status: SUCCESSFUL
                                Additional Notes: NOTE - Required Disk Space:73,318,334 Bytes Free Disk Space:-1 Bytes
      Get Registry Entry:       Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\DevDiv\VC\Servicing\11.0\RuntimeMinimum
                                Value Name: Version
                                Status: SUCCESSFUL
                                Value Name: Version
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.utils.HotFixProps
                                Status: SUCCESSFUL
      Get Registry Entry:       Key: HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\Adobe\Install Data\Adobe ColdFusion 10
                                Value Name: CFMXRoot
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.ia.customrule.DocRootValidate
                                Status: SUCCESSFUL
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.ia.customrule.ReadXML
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.ia.action.UpdatableInstances
                                Status: SUCCESSFUL
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.ia.action.LoggableInstance
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.ia.action.VersionCheck
                                Status: SUCCESSFUL
      Modify Text File - Single File:   New File \cfhotfix.txt
                                Status: SUCCESSFUL
      Stopping Windows Service: ColdFusion 10 Jetty Service
                                Status: SUCCESSFUL
      Stopping Windows Service: ColdFusion 10 .NET Service
                                Status: SUCCESSFUL
      Stopping Windows Service: ColdFusion 10 ODBC Server
                                Status: SUCCESSFUL
      Stopping Windows Service: ColdFusion 10 ODBC Agent
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.ia.action.ServersStartStopAction
                                Status: SUCCESSFUL
      Stopping Windows Service: ColdFusion 10 Application Server $STARTSTOP_SERVER_NAME$
                                Status: SUCCESSFUL
      Execute Command:          D:\ColdFusion10\cTest\bin\coldfusion stop
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.utils.InstallDateTime
                                Status: SUCCESSFUL
                                Status: SUCCESSFUL
      Install Directory:        C:\Users\CFRunAccount\844358.tmp\
                                Status: SUCCESSFUL
                                Additional Notes: NOTE - Directory already existed
      Delete File:              Source:cfhotfix.txt
                                Status: SUCCESSFUL
                                Additional Notes: NOTE - Source file cfhotfix.txt does not exist.
      Install File:             C:\Users\CFRunAccount\844358.tmp\update.xml
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\updates.xml
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cf-bootstrap.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cf-init-run.sh
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cf-startup.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cfcompile.bat
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cfcompile.sh
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cfinfo
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cfinfo.bat
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\cfinfo.sh
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\coldfusion.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\coldfusionsvc.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\bin\msvcr100.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\jetty\cfjetty
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\auth-ehcache.xml
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\axis2\httpcore-4.0.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\cf-logging.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\commons-codec-1.6.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\commons-collections-3.2.2.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\commons-logging-1.1.3.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\commons-logging-api-1.1.1.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\commons-net-3.4.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\ehcache-core-2.6.6.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\flex-messaging-common.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\flex-messaging-core.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\flex-messaging-opt.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\flex-messaging-proxy.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\flex-messaging-remoting.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\fluent-hc-4.5.2.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\httpclient-4.5.2.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\httpclient-cache-4.5.2.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\httpcore-4.4.4.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\httpmime-4.5.2.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\ib6core.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\ib6http.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\ib6swing.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\ib6util.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\jai_codec.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\jai_core.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\jai_imageio.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\log4j.properties
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\macromedia_drivers.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\mail.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\mysql-connector-java-commercial-5.1.17- bin.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\neo-drivers.xml
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\neo_updates.xml
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\postgresql-9.3-1101.jdbc41.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\lib\threaddump.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\bootstrap.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\catalina-tasks.xml
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\catalina.bat
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\catalina.sh
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\daemon.sh
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\service.bat
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\setclasspath.bat
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\setclasspath.sh
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\tomcat-juli.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\bin\tomcat-native.tar.gz
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\annotations-api.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\ant-launcher.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\ant.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\catalina-ant.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\catalina-ha.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\catalina-tribes.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\catalina.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\ecj-4.4.2.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\el-api.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\jasper-el.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\jasper.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\jsp-api.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\jta.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\servlet-api.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-api.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-coyote.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-dbcp.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-i18n-es.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-i18n-fr.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-i18n-ja.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-jdbc.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\tomcat-util.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\runtime\lib\wsconfig.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\bin\coldfusion.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\bin\coldfusionsvc.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\bin\msvcr100.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\cfperfmon_10.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\cfregistry.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\CFWindowsLogin.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\CFXNeo.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\DDJDBCAuth05.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\NeoUUID.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\PerfmonClient.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win32\lib\TypeViewer.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\bin\mfc100.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\CheckConfig.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\com2java.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\com2java.xml
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\com2javacmd.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\install_license.bat
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\CheckConf igEnglishResourceDll.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\com2javaE nglishResourceDll.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\ntvauthEn glishResourceDll.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\ntvinvEng lishResourceDll.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\regjvmcmd EnglishResourceDll.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\regjvmEng lishResourceDll.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\regprogid EnglishResourceDll.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\regtlbEng lishResourceDll.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\international\setdllhos tEnglishResourceDll.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\java2com.bat
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\jintmk.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\ntvauth.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\ntvinv.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\ntvocx.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\regjvm.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\regjvmcmd.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\regprogid.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\regtlb.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\bin\setdllhost.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\jintegra_changelist.txt
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\jintegra\version.txt
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\lib\jintegra.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\_win64\lib\TypeViewer.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\updates\chf10000020.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\adminapi\administrator.cfc
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\adminapi\customtags\l10n.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\adminapi\runtime.cfc
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\adminapi\security.cfc
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\aboutcf.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\appinstaller\uninstall. cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\Application.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\Application.cf m
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\deploywizard.c fm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\index.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\security.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv eSummary.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_applets.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_archivesummary.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_cfdirectorymappings.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_cfxtags.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_datasources.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_eventgateways.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_filelocations.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_information.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_pdfservice.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_restservices.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_scheduledtasks.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_settings.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_todolist.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_veritycollections.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\archiv ewizard_page_webservices.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\buildw izard_page_buildstatus.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\buildw izard_page_pickfile.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\contro ludfs.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\deploy wizard_page_locations.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\deploy wizard_page_status.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\archives\wizards\deploy wizard_page_summary.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\cftags\l10n.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\cftags\l10n_testing.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\cftags\resources\archiv es_en.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\cftags\resources\settin gs_en.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\db2.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\derbyClient .cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\index.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\informix.cf m
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\j2ee.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\jdbcodbc.cf m
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\mysql5.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\mysql_dd.cf m
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\odbcsocket. cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\oracle.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\postgresql. cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\sqlserver.c fm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\sybase.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\datasources\udflibrary. cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\debugging\index.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\extensions\applets.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\extensions\cfx.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\extensions\corba.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\extensions\webservices. cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\filedialog\index.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\header.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\homepage.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\include\udflibrary.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\index.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\j2eepackaging\editarchi ve.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\j2eepackaging\index.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\login.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\login_migration.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\logviewer\_searchloglog ic.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\logviewer\_searchloglog ic_other.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\monitor\index.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\monitor\launch-monitor. cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\reports\index.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\reports\_report.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\scheduler\probes.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\scheduler\scheduleedit. cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\scheduler\scheduletasks .cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\security\cfadminpasswor d.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\security\index.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\security\useredit.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\security\userpassword.c fm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\security\_fileoptions.c fm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\settings\memoryvariable s.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\settings\server_setting s.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\settings\version.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\setup\migrationcf8_impo rt.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\setup\migrationcf9_impo rt.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\templates\missing_templ ate_error.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\templates\request_timeo ut_error.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\templates\request_timeo ut_error.htm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\templates\secure_profil e_error.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\Application.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\download.cfc
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\download_info.c fm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\error.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\index.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\info.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\installer_input .cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\overwrite.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\task\checkupdat es.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\uninstall.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\_settings.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\_sysinfo.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\administrator\updates\_updates.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\classes\cfapplets.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\componentutils\cfcexplorer.cfc
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\gettingstarted\community\webroot\shar ed\error.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\cfajax.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\cfcalendar.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\cfgrid.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\cfwebsocketCore.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\ext\map\GMapPanel3.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\ext\map\mapiconmaker.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\FCKeditor\fckeditor.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfajax.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfcalendar.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfgrid.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cflayout.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfmap.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfwebsocketChann el.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\package\cfwebsocketCore. js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\resources\cf\map\marker. png
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\resources\cf\skins\smart phone-skin.xml
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\resources\cf\skins\table t-skin.xml
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\resources\cf\uploadfile. css
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\CFIDE\scripts\ajax\smp\StrobeMediaPlayer.js
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\WEB-INF\cftags\META-INF\taglib.cftld
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\WEB-INF\debug\dockable.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\WEB-INF\exception\coldfusion\filter\FormVal idationException.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\WEB-INF\exception\detail.cfm
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\wwwroot\WEB-INF\lib\cfmx_bootstrap.jar
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\admin\mmcslx.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\admin\openssl600.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\admin\swcla.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\bin\openssl600.dll
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\bin\swagent.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\bin\swsoc.exe
                                Status: SUCCESSFUL
      Install File:             C:\Users\CFRunAccount\844358.tmp\dist\cfusion\db\slserver54\bin\swsocw.exe
                                Status: SUCCESSFUL
      Delete Folder:            Source:_win32
                                Status: SUCCESSFUL
      Move Folder:              Destination: C:\Users\CFRunAccount\844358.tmp\dist\cfusion
                                Status: SUCCESSFUL
      Install Directory:        D:\ColdFusion10\
                                Status: SUCCESSFUL
                                Status: FATAL ERROR
                                Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest\lib\updates\chf10000017.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup\lib\updates\chf10000017.jar
                                Status: FATAL ERROR
                                Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest/lib/httpclient-4.3.5.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup/lib/httpclient-4.3.5.jar
                                Status: FATAL ERROR
                                Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest/lib/httpclient-cache-4.3.5.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup/lib/httpclient-cache-4.3.5.jar
                                Status: FATAL ERROR
                                Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest/lib/httpcore-4.3.2.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup/lib/httpcore-4.3.2.jar
                                Status: FATAL ERROR
                                Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest/lib/httpmime-4.3.5.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup/lib/httpmime-4.3.5.jar
                                Status: FATAL ERROR
                                Additional Notes: FATAL ERROR - Could not move the file D:\ColdFusion10\cTest/runtime/lib/ecj-P20140317-1600.jar to the backup location D:\ColdFusion10\cTest\hf-updates\hf-10-00020\backup/runtime/lib/ecj-P20140317-1600.jar
      Custom Action:            com.adobe.utils.Logger
                                Status: SUCCESSFUL
                                Status: SUCCESSFUL
                                Status: SUCCESSFUL
                                Status: FATAL ERROR
                                Additional Notes: FATAL ERROR - Failed to copy the hotfix files to the target location:D:\ColdFusion10\cTest
                                                  FATAL ERROR - D:\ColdFusion10\cTest\bin\coldfusion.exe (The process cannot access the file because it is being used by another process)
                                Status: ERROR
                                Additional Notes: ERROR - Failed to delete directory:D:\ColdFusion10\cTest/lib/httpclient-4.3.5.jar
                                                  ERROR - Unable to delete file: D:\ColdFusion10\cTest\lib\httpclient-4.3.5.jar
                                Status: ERROR
                                Additional Notes: ERROR - Failed to delete directory:D:\ColdFusion10\cTest/lib/httpclient-cache-4.3.5.jar
                                                  ERROR - Unable to delete file: D:\ColdFusion10\cTest\lib\httpclient-cache-4.3.5.jar
                                Status: ERROR
                                Additional Notes: ERROR - Failed to delete directory:D:\ColdFusion10\cTest/lib/httpcore-4.3.2.jar
                                                  ERROR - Unable to delete file: D:\ColdFusion10\cTest\lib\httpcore-4.3.2.jar
                                Status: ERROR
                                Additional Notes: ERROR - Failed to delete directory:D:\ColdFusion10\cTest/lib/httpmime-4.3.5.jar
                                                  ERROR - Unable to delete file: D:\ColdFusion10\cTest\lib\httpmime-4.3.5.jar
                                Status: ERROR
                                Additional Notes: ERROR - Failed to delete directory:D:\ColdFusion10\cTest/runtime/lib/ecj-P20140317-1600.jar
                                                  ERROR - Unable to delete file: D:\ColdFusion10\cTest\runtime\lib\ecj-P20140317-1600.jar
      Custom Action:            com.adobe.ia.action.InstallData
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.utils.XMLUpdate
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.ia.action.UpdateConfigs
                                Status: SUCCESSFUL
      Execute Command:          regsvr32.exe /s D:\ColdFusion10\cTest\lib\TypeViewer.dll
                                Status: SUCCESSFUL
      Install Directory:        D:\ColdFusion10\cTest\hf-updates\hf-10-00020\uninstall\
                                Status: SUCCESSFUL
      Install Uninstaller:      Adobe ColdFusion 10 Update 20(Install All Uninstaller Components)
                                Status: SUCCESSFUL
                                Status: SUCCESSFUL
      Modify Text File - Single File:   New File D:\ColdFusion10\cTest\hf-updates\hf-10-00020\uninstall\installvariables.properties
                                Status: SUCCESSFUL
      Custom Action:            com.adobe.ia.action.StartServersAction
                                Status: SUCCESSFUL
      Starting Windows Service: ColdFusion 10 Jetty Service
                                Status: SUCCESSFUL
      Starting Windows Service: ColdFusion 10 .NET Service
                                Status: SUCCESSFUL
      Starting Windows Service: ColdFusion 10 ODBC Server
                                Status: SUCCESSFUL
      Starting Windows Service: ColdFusion 10 ODBC Agent
                                Status: SUCCESSFUL
