1. Re: Size issue with HTML5 banners for Adform
resdesign Jun 29, 2016 9:56 AM (in response to Martiniho)If you are not using jquery then you do not need to have a js folder. Did you update your files from the previous version of Edge Animate or are you using the previous version?
The js folder is created only when you are using jquery (in the current version because you would need jquery) or because you are using a plugin.
If you are not using any of these then you can remove the jquery file from the script panel or any other plugin and then delete the js folder.
Hope this helps.
2. Re: Size issue with HTML5 banners for Adform
Martiniho Jun 29, 2016 10:06 AM (in response to resdesign)I did update from a previous version. But Im not aware that im using jquery. I tried to delete the folder though and then nothing appears in the browser when previewing the files.
But is there an error creating a js folder when updating files from and older version of Animate? -
3. Re: Size issue with HTML5 banners for Adform
resdesign Jun 29, 2016 10:14 AM (in response to Martiniho)Since you updated from a previous version, if you are using any jquery it will add the file in your script panel and a js folder to put jquery.
What kind of code do you have. If you are doing simple animations, there should be no need for jquery.
If jquery is still reference in the script panel and your delete the js folder it will create an error. So make sure to remove the jquery reference in the script panel if you delete the js folder. then you should be OK.
4. Re: Size issue with HTML5 banners for Adform
Martiniho Jun 29, 2016 11:20 AM (in response to resdesign)thanks a lot this seems to sove the issue. thanks so much for your amazing support!
5. Re: Size issue with HTML5 banners for Adform
resdesign Jun 29, 2016 1:17 PM (in response to Martiniho)My pleasure! As long as you do not use jquery, your files should be small.
