0 Replies Latest reply on Jun 29, 2016 9:35 AM by İhsan Gerçelman
    It can not CreateObject("Photoshop.Application")" in Photoshop CC 2015.5
    İhsan Gerçelman Level 1
      My VBS script does not work with Photoshop 2015.5.
      I was use it by years with lots of Photoshop versions.
      Last week I updated myy Photoshop to 2015.5 than scripts does not work.
      My OS is Windows 10 64 bit.
      My sample script is below.
      It gives error on tle line "Set appRef = CreateObject("Photoshop.Application")"
      And it can not create object. Error code is 800A01AD
      How can I solve the problem?
      Thanking you in advance.
      resize.vbs
      Public Const RESIZEWIDTH = 800
      Public Const RESIZEHEIGHT = 800
      Public Const IGNOREVERTICAL = false
      Public Const SAVE_TH = false
      Public Const SUFFIX = "_"
      Dim spath
      spath = Mid(WScript.ScriptFullName, 1, InStrRev(WScript.ScriptFullName, "\", -1, vbBinaryCompare))
      Dim fso
      Set fso = CreateObject("Scripting.FileSystemObject")
      Dim foldero
      Set foldero = fso.GetFolder(spath)
      Dim fileo
      Dim sfile
      For Each fileo In foldero.Files
          'only modify jpg files
          sfile = fileo.Name
          If InStrRev(sfile, ".jpg", -1, vbTextCompare) = Len(sfile) - 3 Then
              resize spath & sfile
          End If
      Next
      MsgBox "Complete."
      Sub resize(sfilename)
          Set WshShell = WScript.CreateObject("WScript.Shell")
          Set colProcessList = GetObject("Winmgmts:").ExecQuery("Select * from Win32_Process")
          Dim found
          found = False
          For Each objProcess In colProcessList
              If StrComp(objProcess.Name, "photoshop.exe", vbTextCompare) = 0 Then
                  found = True
                  Exit For
              End If
          Next
          Dim appRef
          If found Then
              Set appRef = GetObject(, "Photoshop.Application")
          Else
          End If
          Do While appRef.documents.Count
             appRef.activeDocument.Close 2 'dont' save
          Loop
          Dim originalRulerUnits
          originalRulerUnits = appRef.Preferences.RulerUnits
          appRef.Preferences.RulerUnits = 1 'pixels
          Dim docRef
          Set docRef = appRef.Open(sfilename)
          Dim modified
          modified = False
          If docRef.Width >= docRef.Height Then 'horizontal photo
        If docRef.Width <> RESIZEWIDTH  Then
        If docRef.Width > RESIZEWIDTH or docRef.Width < 480 Then
        docRef.ResizeImage RESIZEWIDTH 'preserves aspect ratio
        modified = True
        End If
                  End If
          Else 'verticle photo
              If Not IGNOREVERTICAL Then 'proceed
                  If docRef.Height <> RESIZEHEIGHT Then
        If docRef.Height > RESIZEHEIGHT or docRef.Height < 480 Then
        docRef.ResizeImage , RESIZEHEIGHT 'preserves aspect ratio
        modified = True
        End If
                  End If
              End If
          End If
          If modified Then 'only save if the image was modified
              Dim jpgSaveOptions
              Set jpgSaveOptions = CreateObject("Photoshop.JPEGSaveOptions")
              jpgSaveOptions.Quality = 8
              'calculate the new file name
              Dim newfilename
        if SAVE_TH then
               newfilename = Mid(sfilename, 1, Len(sfilename) - 4) & SUFFIX & ".jpg"
        else
               newfilename = sfilename
        end if
              docRef.SaveAs newfilename, jpgSaveOptions, True, 2 'for psLowercase
          End If
          docRef.Close 2 'dont' save
          appRef.Preferences.RulerUnits = originalRulerUnits
      End Sub
